(Topic ID: 109931)
The SprayMax 2K Auto Clear in a Can Club!
By Curbfeeler
  • 979 posts
  • 166 Pinsiders participating
  • Latest reply 2 days ago by PinballAir
  • Topic is favorited by 274 Pinsiders
There have been 277 images uploaded to this topic. (View topic image gallery).
There are 979 posts in this topic. You are on page 20 of 20.
#951 8 days ago
You don't plan on sanding that flat to get the wrinkles out? Your post sounds like you want to just let it dry and then just spray it again. My apologies if I misunderstood
#952 8 days ago
Quoted from sohchx:
so whats funny is the surface is as flat as can be, if you look from an angle it looks like glass, but that texture that you see seems to be under the surface. So it sounds like i need to sand it all off it thats the case?
#953 8 days ago
Screw it, ill just sand it with 800 tomorrow and lay another coat on friday if it works it works, if not im used to this not working out so whatever. I'll report back Saturday morning with good or bad news
#954 8 days ago
Can you put an opened can of 2k into the refrigerator to extend its life?
#955 8 days ago
Quoted from ktownhero:
Yes, some guys report putting it in the freezer for weeks too.
#956 8 days ago
I have half a can in the mini fridge in my basement
#957 7 days ago
Freezer would be best bet. But I would be shocked if lasted more than a few days. Its a chemical reaction occuring inside the can. Even if its still in liquid form, you are applying a material that is partly cured. I would think adhesion might be a issue but try and see. Only one way to find out.
#958 7 days ago
Putting an already mixed can in the freezer sounds like a penny wise pound foolish decision. I personally would not jeopardize hours of work just to save half of a $20 can of 2PAC.
#959 7 days ago
Yeah I didn't mean for like weeks or months, just like if you can get an extra day or two out of it.
#960 7 days ago
That’s exactly what I was wanting to get out of it. Just enough buy more time.
On Tuesday as I did the saucer I also sprayed a test board to get the feel of the can. So I took that board and sanded it last night. Today I took my can from Tuesday out of the fridge and laid down an application the same way I did on Tuesday but instead of waiting 15 minutes between coats I only waited about five. Minus the impact craters in the wood from doing a drop test a few weeks ago this application looks like glass and has dried like glass too. So what I’ve learned here is this stuff can be laid down one day, sanded the next day and coats added on day 2 with no wrinkles or other issues.
Sanded after 1 day
3 passes 1 day after sanding.
Ignore the crater like mentioned before.
#961 7 days ago
Saucer sanded with 800 grit and now I’ll give it 24 hours for the exposed sanded clear to dry and tomorrow I’ll finish this up. But tomorrow I’m using a new can. I’m not going to experiment with how long this refrigerator practice works.
Edit after posting this I realized I should sand around that lip to give the new clear something to bite on to.
#962 6 days ago
Quoted from mrm_4:
Question?
What are you trying to do with the center eject to a Bally Mata Hari?
Just curious.
Regards.
#963 6 days ago
Quoted from vec-tor:
Question?
Just curious.
Regards.
I restored a Mata Hari last year, had it clear coated. The clear ghosted over almost all the inserts and several other parts of the playfield. So I’m taking this extra blown out playfield and getting it ready for a hardtop.
This thread explains where painting the saucer black originally came from:
https://pinside.com/pinball/forum/topic/did-i-ruin-my-playfield-by-accidentally-sanded-down-to-the-next-ply
This thread is for the full restoration:
https://pinside.com/pinball/forum/topic/i-thought-she-was-a-dirty-girl-before-i-stripped-her-down
I’m only clearing the saucer and shooter lane because I’m not risking the same thing happening to the inserts again under the hardtop.
#964 6 days ago
I am going to bite the bullet and get a air system. I’ve tried several different masks and filters and I can still smell the stuff when I spray.
I was thinking of this one, not too expensive : Electric Constant Flow Supplied Air Fed Full Face Gas Mask Respirator System amazon.com link »
The tube is short, what is the point of a respirator system when you carry the filter around with you, why not just get a mask? I was thinking if I can put a 10-20 foot tube on it I can keep the intake outside the paint booth and be safe
#965 6 days ago
Quoted from mark532011:
That ought to do it!
I got the higher end respirator from Ace hardware. It’s was like $45. Has the pink filters. I don’t smell anything when I used this stuff or other spray paints prior to this. And I have an annoyingly great sense of smell. I hope this ace brand mask is working for me. Guess I’ll know in a decade.....
#966 6 days ago
Damn, this stuff is really that bad? I find it really onerous to have to gear up like that just to put a thin coat of clear on like 6 sq ft of wood.
#967 6 days ago
Yes. The stuff is really that bad. There was quite a lot of discussion on proper PPE in this thread several months ago. Please take good care when working with this chemistry.
#968 6 days ago
Yeah I'd rather risk raw-doggin' one of Charlie Sheen's ex's than breathe this stuff in
#969 6 days ago
Alright it’s done. Looks perfect minus the 2 pieces of dust that settled on it during the last coat. Nothing can ever be easy for me I swear.
C360A9B6-D9FA-4A89-8ABB-892E161EB8E1 (resized).jpegD025B5D4-AFE5-4D37-9EF0-CB9EFD409ED1 (resized).jpeg
#970 6 days ago
For a couple hundred bucks more this one will last way longer and won't need to be modified... and won't suffocate you when the Chinesium-Ion battery dies: amazon.com link »
I also really like the blurb about FDA testing that they're really proud about receiving... The FDA doesn't test respirators. Amazing what they'll sell on Amazon.
#971 6 days ago
Quoted from mrm_4:
Sheeeet, no one but you will ever notice. Turned out great!
#972 6 days ago
Quoted from Atari_Daze:
Lol thanks George! I’m such a cry baby.
#973 6 days ago
Quoted from mrm_4:
Naw, your just a perfectionist. It has taken me quite a while to accept very minute things like dust particles.
#974 6 days ago
So even though I only did a 4” square with this stuff I can see why everyone loves it. Minus the toxic dangers it’s a pretty affordable way for a common joe to clear a playfield and get some really nice results. It’s making me contemplate touching up the playfield in my Shangri La and giving it a go. That would have to be a spring project though. Pretty sure the temps are locked out of range after today.
What happens if you spray this stuff in the 40s and 50s? I’m just wondering the harm of laying down the coats, letting it set for about and hour and then bringing it in doors like I just did today?
-1
#975 6 days ago
Quoted from mrm_4:
Don't bring it inside for months. It is still releasing harmfull gases
#976 6 days ago
Quoted from yellowghost:
I think that might be a little over zealous, this stuff cures in a couple days and their website states the flash period is like 15 minutes. There’s a bit of a difference in smelling the product after it dries versus directly inhaling fumes from the aerosol.
#977 6 days ago
oh no.
This kind of talk will bring out the safety police.
Buckle up.
#978 4 days ago
Today was the first time I used this stuff, and I really like it. I have a HVLP setup for when I'm painting cars, but for something as small as a playfield I wanted to try something more convenient. I have to say... I'm really impressed with this!
I wanted to seal in all of the work I've done on a playfield out of a Grand Prix. After all of my touch-ups with acrylic paint, and the releveling of inserts. I picked up 2 cans off Amazon for $45ish.
With one can I was able to lay down 3 coats with the first being a really light one, and a recoat after a 15 minute flash time.
These aerosols are awesome. Soooo much easier (no measuring, mixing, and cleaning).
I'm definitely going to get more.
-Paul
#979 2 days ago
Quoted from Pablito350:
I agree. I have everything needed to mix and spray but choose the 2K because it is quick and easy.
Nothing to store, nothing to clean.
Results are equal to anything that could be done with a gun and at $22 a can.
$ 26.50
2,150
Olive Branch, MS
$ 89.99
$ 79.95
$ 289.00
Third Coast Pinball
Cumberland, RI
$ 99.00
Pinball Sales
Knoxville, TN
$ 149.00
$ 149.00
$ 24.95
$ 87.00
$ 16.95
$ 40.00
$ 135.00
LED OCD
TheDudeMods
10,300 (OBO)
Los Angeles, CA
$ 1,400.00
