Quoted from gmkalos:
On that last coat you just layed down it looks like you did a mist coat and sprayed too light, see the mist coat is only good as the initial coat because your going to fill in all that with a heavy coat next while that mist coat is wet and hasn't flashed off completely yet (2-3 min). All coats should be generally heavy after that otherwise like now you are just creating more work for yourself knocking all those little pinholes down.
First, this was a super-helpful post. Thank you!
Second...Eureka! This is it! I'm going to sound stupid, but I always thought it was a terrible idea to spray anything BEFORE the minimum flash-off has happend (10-15 minutes). I think I had read somewhere that you can get clouds or fisheyes or worse if you don't wait for the 'flash off'. So basically I was under the impression that you NEVER do anything before the flash off is done.
ugh. Yeah, knowing this would have saved me a couple of hours of sanding.
I don't want to assume anything more, but so I understand this better Typically when you are laying down coats of clear you generaly want to wait for the previous coat to 'flash off' (e.g. 10-15 min between coats) - the big exception being when clearing over decals. Because it needs to be light so the decals don't 'burn, you don't want to wait more than 2-3 minutes with thicker coats.
The logic being that those first 4 minutes or so that your 'light/mist' coat sits on the decals is enough to 'insulate' (or chemically change/) the decal and your then okay to apply a thicker coat? My only problem with this is that was kind of what I did the first time, but my second coat was very, very thick.
Do I have that right?
