My Shadow developed an issue awhile back. The wife and daughter were playing it and I was told it "smoked" from the left side of the PF. I shut it off pulled the PF up, saw nothing but smelled burnt electrical smell. Lifted the mini PF and saw the rear target bank coil (solenoid 24) was toast.
I began checking it out and did the following first:
-replaced the coil
-replaced the blown fuse - f103
Yes I should have checked the drive transistor but I had the coil and fuse on hand and my DMM was at work. I started the game up and the coil of course started to burn up again. I shut if off ASAP. I then:
-replaced the driver transistor - q32
- i don't think the fuse blew this time, but it might have and if so was replaced.
- did not replace the coil, it ohmed around 7.2-ish which is what the other 25-1000 near it ohms to
Started game up and watched the coil, it didn't appear to be getting hot. Next thing I know, smoke is coming from the Q32 transistor area and it was burning up. It got so hot it melted the solder and almost fell out of the through holes of the board. It was shorted ground leg to middle leg again and had physically burned the three components above it, r49, r48 and q31.
I then replaced :
- q31
- q32
- r48
- r49
- q32
- and r46 and r47 because I figured what the hell, the heat was moving upward
Start the game up and the same thing begins to happen. I can see the solder start to melt on the right side ground leg. I shut the game off and the transistor was again shorted outer leg to middle. I removed the board and replaced:
- q32
- D11... As I see it this diode is in line with q32 and I guess has to do with the tieback diode stuff. It tested good but I figured what the hell at this point.
- Disconnected the grounding wire at the coil, wanted to see what would happen in this scenario since this is the circuit in question.
Stated the game up and nothing abnormal happened. Of course the coil doesn't work but it ran for awhile and the q32 wasn't hot at all. I then re-soldered the blue wire back to the coil, started the game up and before I could shut it off it shorted the transistor again (did not blow the fuse).
Could the coil be bad and causing this since it was originally installed with a shorted transistor and DID get hot? It still ohms 7.2-ish like another 25-1000 coil I checked. Could the 74ls374 chip that is in circuit ahead of these components I replaced cause this? As far as I can tell I've replace everything else in this circuit, unless I'm missing something.
