"Old" pinball tech here.
I have a Shadow that has a partial column (vertical) failure of all switches after the plumb bob tilt, basically the last four switches on the column (all return and outlanes, switches 15-18 ).
All remaining switches on the machine work, including optos, normally closed switches, and no “phantom” switches are occuring.
Should be a straight forward fix.
I have not found a wiring problem, and continuity has been tested downstream successfully up to the point of break (Switch 15, Right Outlane)
Is it possible that the cabinet interconnect board could be causing issues after running back from the plumb bob?
Alternatively is this an IC U20 issue? (unlikely, but I guess it *could* happen)
This is not a diode failure, if there is no continuity problems based on this particularly common issue.
