I'm having a problem with the right hand side shot registering on the left phurba ramp, the balls appears to actually jump the switch on the wire form, I can't see an obvious fix for it, is this a common problem?
Very common problem. Replace the factory switch with a straight wire switch from Pinball Life. The extra length of the wire will insure the switch is triggered every time.
Steve (in Escalon, CA)
You can replace the switch with a 12-smsb or 12-smsw (which is longer). These are available at Marco. Or you can make the modification shown in the following thread.
https://pinside.com/pinball/forum/topic/the-shadow-left-ramp-switch-mod
^^^Have same issue... Love your idea, Thanks!!!
HELP : On another note, I'm having an issue when the game has been played for a while, the machine starts to act strangely. It seems like its warming up and the coils start to act funny. The lock ball magnet won't through the ball forward, even though it's done it previously during play. The left flipper starts to hesitate and the upper playfield action does the same. All this happens at the same time during the game play after we've been at it for at least 10-20 games. Any insight would help. If it was only one issue with a single coil, I think it would be more mechanical. But with several issues happening randomly during extensive game play, I'm thinking it's something more involved.
Quoted from TaTa:^^^Have same issue... Love your idea, Thanks!!!
HELP : On another note, I'm having an issue when the game has been played for a while...
You may need Lloyd for this one, but check the white molex connectors where they attach to the power board. Look for discoloration which could be a sign of overheating and a pin socket that needs replacing. Make sure all molexes are fully inserted by removing and re-attaching.
Also check molexes at fliptronics board, especially J901 I have had a similar magnet problem that was caused by a bad opto in the ball through. Don't forget to run switch and solenoid tests. If you don't have a manual you can download one from the Internet Pinball Database.
Quoted from Pinmeister:You may need Lloyd for this one, but check the white molex connectors where they attach to the power board. Look for discoloration which could be a sign of overheating and a pin socket that needs replacing. Make sure all molexes are fully inserted by removing and re-attaching.
Thanks! I'll try that first... Lloyd second, it's Sunday and even Lloyd needs a day off here and there.
Quoted from Pinmeister:Also check molexes at fliptronics board, especially J901 I have had a similar magnet problem that was caused by a bad opto in the ball through. Don't forget to run switch and solenoid tests. If you don't have a manual you can download one from the Internet Pinball Database.
Will do...
This page was printed from https://pinside.com/pinball/forum/topic/the-shadow-left-phurba-ramp and we tried optimising it for printing. Some page elements may have been deliberately hidden.
