(Topic ID: 46571)
The Shadow Club
By marsgnu
6 years ago
  • 6,666 posts
  • 558 Pinsiders participating
  • Latest reply 3 days ago by Graysonsdad
  • Topic is favorited by 193 Pinsiders
There have been 1,771 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 6666 posts in this topic. You are on page 96 of 134.
#4751 1 year ago
I encountered a problem tonight with my upper playfield paddle. It stopped kicking the ball forward. I checked the switches and everything is ok except when I go into solenoid T.4 15 Mini Kicker it is not pulsing. Is this the paddle kick? I'm assuming either a wire came loose from the coil or the coil is bad? I just wanted some opinions before i tear the playfield off and try to diagnose.
#4752 1 year ago
Quoted from Mudflaps:
I posted earlier with some speaker woes. Bottom line, the sound board is good. I have FF speakers.
The problem: on boot up, the back box speakers give a steady pop, like a rapid drumbeat. I believe I’ve narrowed the problem to a grounding issue.
When I touch both speakers at the same time, the problem goes away.
Can someone post a picture of where the grounding cables are located in the backbox? Maybe I have something backwards.
This is my backbox:[quoted image]
Pretty sure it's the green/yellow wire but not real experienced with this sort of thing. I would check that wire on the left speaker and see if connection is loose.
#4753 1 year ago
Quoted from Squeakman:
You don't need to "tear the playfield off" to check for a loose or broken wire on the battlefield.
The upper pf will lift up like a car hood. Just remove the thumb screws, before lifting it up. No tools required.
#4754 1 year ago
It's possible that the coil "froze." So, you can check that the sleeve is still sliding in the coil like it should. Since that mechanism moves around the wires that go to that coil are susceptible to breaking. I had an intermittent issue with that coil and it turned out the wire are broken about in inch or so away from the coil, but the wire sheathing was still in tacked. So, I ran new wires to the coil and problem solved.
#4755 1 year ago
Quoted from RTS:
I should have researched this in the manual. I figured it would be a pain to open up.
Lamprey, that was my thinking on the issue. Thanks for the input.
#4757 1 year ago
I picked up a shadow last week and have been shopping for parts.
Are the cab decals available? I can’t find them anywhere.
Does anyone have a spare Aurich translite/speaker panel?
#4758 1 year ago
Does Retro Refurbs sell decals?
#4759 1 year ago
4 shots away from completing the Final Battle a few minutes ago! Argh!
#4760 1 year ago
Quoted from PoMC:
Thats hard to complete. Once you get near the end. Just keep shooting your balls into the saucers. They will give you credit for targets you are missing.
#4761 1 year ago
The key to Final Battle is going for the Battlefield first while the ball saver is on. It's still very hard, and I've only ever beaten it once.
#4762 1 year ago
Quoted from gweempose:
This. Have only beaten it once as well. Thought the game had reset!
#4763 1 year ago
Quoted from jonesjb:
I've only seen the decals for the back box available.
#4764 1 year ago
pinball pt possibly!
#4765 1 year ago
Just finished a game where I was 2 shots away from completing Final Battle. The mode start scoop and the right orbit. Easy shots and I failed. Arrrrgh!!!
#4766 1 year ago
Quoted from PinballNewb:
Brutal!
I need to get back into form on my Shadow so I can try to make a run at the Final Battle.
#4767 1 year ago
The only time I got to final battle; I lost with 2 switches to go too. I forgot to switch the ramps, and these were the shots I missed
#4768 1 year ago
Hi, Bought a Shadow and shopping it. I have 2 rings that are burnt out. What is the procedure for installing new bulbs? Thanks
#4769 1 year ago
Quoted from Demoman1:
Step 1: get bulbs. Marco and pinballlife sell them.
Step 2: pull wires out of ring. The bulbs are socketed, so they should just be held in with a friction fit.
Step 3: shove bulb back into ring.
Though, if your game is like mine, the sockets will be missing. I should’ve replaced the bulbs with LEDs, but I didn’t. I just soldered in new bulbs where I didn’t have a socket and used heatshrink tubing to insulate. It’s not recommended, but it’s clean looking, and the game is on so infrequently, I don’t anticipate having to replace the bulbs any time soon.
#4770 1 year ago
Looking for an Aurich set, if anyone is holding and wants to let it go please message me!
#4771 1 year ago
PM Aurich, maybe if he gets enough requests he will print more. I would love a set too.
#4773 1 year ago
Quoted from Nds777:
Thanks, I have, but just hoping I might get lucky.
#4774 1 year ago
You just missed his last print of the art package by like a month or two. He might have some leftovers though from the run.
#4775 1 year ago
Is it ok that I join he club? My first wishlist pin!
Thanks to fellow pinsider ScottinSGFNY for the sale!
#4776 1 year ago
Quoted from Scoot:
My Favorite Playing Stance! Enjoy!
#4777 1 year ago
Quoted from Scoot:
Congrats and welcome the club!
#4778 1 year ago
After 10 years + of Shadow ownership I had reached the final battle a few times but always been 1 or 2 shots away from completing it, until last week when I finally did it (including the secret mode) and got my highest ever score Fantastic game, I am always amazed that it sells relatively cheaply compared to others.
#4779 1 year ago
I decided to stay in the club longer. It was Shadow vs Mustang since I could sell either for comparable price. Shadow is SO my style of gameplay, fast and flowing, great loops, orbits and ramps. Plus the various ways you can physically control the pinball via the diverters and Battlefield is fantastic. I have two Shadows and one has been torn down for 2 years and this one I got a few months back. Still have to do a full shop job, but have it fully working and pretty cleaned up. So just recently got back into playing it and now that I've played other games in the past two years I can REALLY appreciate how terrific Shadow is.
We really enjoy Mustang and my wife preferred it stayed, but she has her keeper in Baywatch, so I said I need to keep I game I really have fun on all the time. So she said go for it then and Mustang has been sold awaiting pickup.
#4780 1 year ago
Quoted from matt_adams:
Nice! Huge score to boot.
#4781 1 year ago
I thought I'd refresh a few things on my newly purchased ts. I didn't like looking at the back of the battlefield kicker head so I covered it up. Thinking of putting a decal or something on it. Also had to reduce the thickness of the blades and repaint the little samurai.
20180810_144625 (resized).jpg20180811_225419 (resized).jpg20180812_150803 (resized).jpg
#4782 1 year ago
If anyone ever has some used Mongol figures please send me a PM.
#4783 1 year ago
I just did a refurb on my Shadow. Have this post left over??
Any idea where it might go. Have taken off all ramps and plasticsduring the refurb.
#4784 1 year ago
Quoted from BioBa:
Do you have a post between the trough and shooter lane?
#4785 1 year ago
Looks like lower left of the left side target bank maybe?
#4786 1 year ago
Like onemoresean said, I think it’s the post kind of under the apron, right where the ball ejects into the shooter lane.
#4787 1 year ago
The post next to the ball eject only has one rubber ring on my game. Only posts with double rings is the outlane posts but those should be metal.
#4788 1 year ago
Quoted from jawjaw:
Yes the kick out post under the apron has only one rubber and is installed.
#4789 1 year ago
Quoted from gjm7777:
Do you mean this one?
#4791 1 year ago
I took a gander at my game. I don't see a post like that anywhere. When in doubt, leave it out? You can always play-test and see what happens
#4792 1 year ago
I looked again at my game and there are no double ring star posts. There is a hidden single ring star post under the left diverter. Looks like it is used to prevent the ball from getting stuck there.
#4793 1 year ago
Quoted from BioBa:
Shadow has no star posts like that at all. It must have dropped into a nook or crannie at some point in time. Where you found it dissasembling
#4794 1 year ago
Hey I found the spot where it was. Do you guys have one there too? Back panel (the bricks are a mod I installed)
#4795 1 year ago
Quoted from BioBa:
no
#4796 1 year ago
Quoted from BioBa:
Nope, not on either of the Shadows I’ve had. From the pic it looks like it was added to support the mini PF exit ramp.
#4797 1 year ago
I have two Shadows right now and neither has a post installed there under the exit ramp.
#4798 1 year ago
Quoted from BioBa:
Aren’t you going to show us the rest of that refurb? The brass ramps and color matching lock nuts are all that I can see.
#4799 1 year ago
Sorry. Yes I had the gun, side rails and lock down bar chromed. All wire ramps brass plated and clear coated. Added some red star post lights. Red brick wall paper at the back panel. Red and blue 6V led strips used to light up the back panel. All leds with colour GI leds to highlight plastics. Alternative translite. New plastics.
It plays very well. Wow I really like it. I had heard a lot of good comments regarding the game and I am very impressed. Great call outs. Great flow. Great rule set. Great shots. I really can't fault it. Don't even miss pop bumpers lol
Not quite sure why someone put that post there. Maybe to protect or support the Perspex rear ramp?
IMG_20180815_160323 (resized).jpgIMG_20180815_220311 (resized).jpgIMG_20180815_220446 (resized).jpgIMG_20180815_220532 (resized).jpgIMG_20180815_220742 (resized).jpgIMG_20180815_220839 (resized).jpgIMG_20180815_220917 (resized).jpgIMG_20180815_220937 (resized).jpg
-1
#4800 1 year ago
Beautiful photos.
I think if one pin would work as a reskinned Batman (in particular the 89 Tim Burton Movie), it would be The Shadow. The character Batman was inspired by Shadow... The Battlefield would work as the bell tower, I'm sure there is something you could do with the phurbas. The Sanctum/Batcave, Shiwan Khan/Nicholson's Joker, Rings/gadgets/Joker pranks. It would be amazing.
$ 40.00
