Life will be settling down for me shortly, and Ill get some time to take new pics.
Lighting the Shadow.
The lower Playfield, flipper, sling, I have illuminated with either Reg or Opmax bulbs, but two frosted Matrix white strips,
on the Apron, (or 1 above the Drain), dimming switch, quick connect to GI.
Reason I went this way.....Lower cost, No blocking vision with spots, not too "bright" or "spotty" works with GI Fade and features tied in.
I have done the same on the Back. I preferred a 10" Purple above the Right side, but have done white, and 45 degree strip lighting, which might need a PM to Ryan to get.
Any of these light the right rear to taste, ties into GI, affordable, reversible, takes a couple minutes.
Above the battlefield, I have Grumpys Product, which I need to install, and move my strip/lighting to the front to share.
(I dont mind the reflection on the battlefield, as again, I am using frosted, and dimmed to my taste.)
The issue for many is not diffusing the strip, or no brightness controlled.
In testing Ive put 20" down the side for "Stadium" like lighting, or a poor mans version I have yet to share, and need to check with the Boss first.
In any direction, Shadow is a great example for creative lighting solutions.
As always, Id recommend it tied to GI, diffused, and brightness adjusted for the balance of the experience.
