(Topic ID: 46571)
The Shadow Club
By marsgnu
6 years ago
  • 6,672 posts
  • 558 Pinsiders participating
  • Latest reply 2 days ago by Stuieb84
  • Topic is favorited by 193 Pinsiders
There have been 1,772 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 6672 posts in this topic. You are on page 70 of 134.
#3451 3 years ago
Does anyone have problems with an inconsistent ball launcher, and does anyone know what to do to fix it? Mine is failing to shoot the ball from the shooter lane all the way up the wireform about 10-20% of the time. I tried a new coil sleeve and new plunger assy. It seemed to get better for a while but that may have been my imagination. It does look as though the plunger is striking the center of the ball as it sits in the shooter lane. This especially sucks when you get into MB. Any thoughts?
#3452 3 years ago
Quoted from LOTR_breath:
Definitely the most likely thing to check. Sometimes it'll look centered but still be striking the ball high or low.
#3453 3 years ago
AE 23-800 for the coil? I know... dumb question but I figured I would ask.
#3454 3 years ago
Quoted from Bwilson:
I will double check the coil. Funny that I just assumed it had the correct one in there.
#3455 3 years ago
I would check the plunger tip as well. Make sure it is not coming apart and causing inconsistent hits.
#3456 3 years ago
Quoted from jawjaw:
It's brand new.
#3457 3 years ago
Hello Fellow Shadow Owners,
My Shadow is giving me fits. My mini playfield motor is under-powered when moving to the right. Optos work great and it moves but so sloooooooowly. Moving to the left is no problem but right is so painfully slow.
I have a brand new motor installed so would it be the pcb under the playfied controlling the motor? Any test procedures would be great as it passes in the service menu.
#3458 3 years ago
Check the pinion gear condition. A broken ow worn gear will cause that. Or, the roll pin is missing.
The rack and pinion is available as as matched set:
http://www.casperselectronics.com/cart/index.php?route=product/product&product_id=945&search=pinion
#3459 3 years ago
Quoted from BillPinball:
I had a similar issue where it would stutter slowly in one direction. My fix ended up being a new flipper opto board even though it seemed fine. An easy way to test is to switch your flipper opto boards and see if it becomes slow in the other direction.
#3460 3 years ago
Had final battle lit but drained
Still a new GC
#3461 3 years ago
Quoted from dudah:
Looks great next to JD!
Nice. Where did you get the speaker lights?
#3462 3 years ago
Just wanted to feedback and say I got it fixed. I did two things and not sure which one fixed it but it works 100% now. The solder connections to the coil looked a little sketchy so I cut, stripped, and re-soldered the wires to the coil. Also the plunger was striking the ball very slightly below center. The way I corrected this was to put a washer between the coil bracket and playfield at both of the two screw locations to raise the whole plunger assy up slightly. Works great now!
#3463 3 years ago
Quoted from Cserold:
Thanks! I made em. Well, I bought em off eBay and wired them up to 12V.
Toughest part was finding ones the right size. They're 90mm and on eBay as "car halo angel eyes". People stick em in their headlights.
The newest rage is these COB (chip on board) ones, all integrated into the circuit board and much thinner.
ebay.com link » Us 90mm 2pcs Red 105 Cob Leds For Angel Eyes Halo Ring Headlight Fog Light
12
#3464 3 years ago
Man, I've been trying for three years to get into this club, and missed two nice games. Well today, I'm in! Thanks to the new coolest guy on the planet, Nate, for this beauty of an example. Working perfectly and PF in super condition! I'm in pinball heaven right now.
#3465 3 years ago
So, what's the usual bounce-out rate from the battlefield after the VUK fires? I'm finding about fifty percent of battlefield entries are bouncing out straight away and flying around the back half of the playfield.
Do I need to align my VUK wireform up a bit? Looks like it could be out, but it might be normal. I wouldn't know.
#3466 3 years ago
Quoted from TimeBandit:
Yes you'll want to adjust that. I don't think I've had any bounce outs. Is it hitting the yellow standup?
#3467 3 years ago
The wireform on my machine is virtually touching the battlefield. In fact, when I remove the stud to swing the battlefield up for maintenance, the wireform prevents it from lifting; I need to slightly bend it out of the way to lift the assembly completely.
No problems with the ball returning back to the VUK.
#3468 3 years ago
I'm not in front of my Shadow to check, but I believe there may be a washer under the wireform base under one of the nuts. You can try to put a washer under here and it should tilt the wireform forward. Don't go bending the wireforms, you should be able to fix everything at the base.
#3469 3 years ago
Quoted from jonesjb:
Quoted from ramegoom:
Thanks guys. I'll line it up.
#3471 3 years ago
In the club as of last Thursday. Want to bronze coat Wire forms and gun. You think legs would also look good with bronze coating or is that gaudy?
#3472 2 years ago
Quoted from RTS:
Your lit battlefield is nice, but when is someone gonna figure out how to only light the upper playfield when it is active?
A mod like that would probably sell to almost everyone who owns a Shadow
Just to let everyone know I'm done with the prototype and am ready to order parts and get circuit boards screened.
I have a few questions for the group, how long of a delay on should there be? Right now I have it at 4 seconds. Also on the prototype I used a double throw relay and a second light wire so I can have one set of leds on all the time and when the relay activates the second set of leds turn on and first set turns off. My first set are dim UV bulbs for the mood and the second set turns on brighter white leds for better viewing. This adds to the cost @ 1.50 so what do you think? Lastly does it matter if this turns on with the left or right flipper button?
#3473 2 years ago
Quoted from GRUMPY:
The lighting scheme sounds great to me. I would definitely pay the extra couple bucks for dual lighting. Could the VUK be the trigger to turn on the lights instead of a flipper? That seems to be the most predictable event.
What delay are you talking about, the lights turning off after falling off the battlefield? I would think shorter than 4 seconds. I would think the light should turn off about the time the bumper re-centers itself afterwards. I'd guess this is only a couple seconds.
#3474 2 years ago
Quoted from Cheeks:
The lights get triggered from the the paddle moving back and forth when you press the flipper button. The delay is for when you don't move the paddle for a period of time but still need the lights activated.
#3475 2 years ago
Quoted from GRUMPY:
I would think that would work then. I always move the paddle before the ball actually gets up there. Four seconds might be a little long on the delay, but it shouldn't be a big deal if it's on slightly after losing the ball.
I'm in!
#3476 2 years ago
Quoted from Cheeks:
This is why I thought I would ask. I got you down for two seconds.
#3477 2 years ago
I also need to get an idea of how many I need to build so I can order parts. The more kits the better the discount on the parts will be which translates in a lower cost for everyone.
#3478 2 years ago
Quoted from GRUMPY:
Put me on the list...cool project! I also think 4 seconds is a little long.
#3479 2 years ago
Quoted from GRUMPY:
I'm in.
#3480 2 years ago
Plus 1. Pm sent
#3481 2 years ago
I'm in too! Thanks!
#3482 2 years ago
I had sold my Shadow (with Aurich translite) and have been hating myself ever since. I just purchased one in a container buy from Italy and while I know it is rough, I can start at the beginning and bring it back to glory. I have been getting parts together and reading this thread. Hope to post pics soon when the container arrives and as I start the restoration.
#3483 2 years ago
Quoted from GRUMPY:
Wait, what's going on? Is this some sort of device that activates lights in the battlefield when the ball is up there? If so count me in.
#3484 2 years ago
Quoted from Cheeks:
Some of my most successful battlefields happen when I keep the paddle still and it bounces back and forth multiple times. Not sure if 4 seconds might not be a safer default. I'd hate to have to move the paddle to keep the lights on when keeping it still is working on the hit total.
It's tough to know for sure. But in any case, I'm interested as well.
#3485 2 years ago
Quoted from GRUMPY:
Take a risk. Make 25-50. If you are confident that you have designed it well then you will sell them easily. They have infinite shelf life so if it takes a year to sell them then no problem. I find the price break on DigiKey at 50 lots is usually good enough to get going. Good luck. Great idea!
And if you don't, I will.
Kidding!
#3486 2 years ago
Why not incorporate a small pot instead of a fixed resister so you could adjust the delay to your liking. Might be worth the extra cost?
#3487 2 years ago
I'll be lucky if there are 25 commitments, but 50 would sure reduce some cost.
Quoted from TimeBandit:And if you don't, I will.
Sounds like you want to be a partner, maybe be the money front man.
#3488 2 years ago
Everything is going to be SMT to keep the size to a minimum. I also think we will come up with a number that everyone will like. Most likely 3 seconds.
#3489 2 years ago
I would also be keen on one.
#3490 2 years ago
Put me on the list Grumpy
#3491 2 years ago
Quoted from GRUMPY:
I'm just nudging you to make 'em. I want one!
#3492 2 years ago
grumpy, i am in!
#3493 2 years ago
Quoted from GRUMPY:
If I wasn't explicit in my feedback, I definitely want this.
As to only getting 25 or 50 commits...if this is implemented well, I can't imagine what Shadow owner in their right mind WOULDN'T buy this. People have been looking for a good way to light the battlefield for years.
#3494 2 years ago
Quoted from damadczar:
I have this exact same problem.
The yellow drop target will raise and lower in test, but on startup it seems like it tries to raise 3 times then gives up.
Just like to say that mine was a switch problem. Bought a new switch and all is now working again.
#3495 2 years ago
Please add me to the list for battlefield lights
#3496 2 years ago
Grumpy I'll take one too!
#3497 2 years ago
I'd like a Grumpy light.
#3498 2 years ago
I'd take one also but would want to see it in Action first.
#3499 2 years ago
I would be interested as well, what is the target price range for the completed mod?
#3500 2 years ago
I'm interested in the battlefield light mod for sure.
$ 12.00
Slap Save Creations
$ 14.50
PinballElectronics.com
$ 279.95
Pin Stadium Pinball LEDs
PCB Emporium
$ 135.00
LED OCD
