Currently, I light my battlefield with a frosted 20 smd strip found in our Matrix
Product line, with a brightness adjuster, and Matrix bulb. I do the same to the other side. I dim them both to the brightness I want to achieve.
Looks fantastic, IMO.
To get longer wire lengths as asked earlier, Matrix has multiple wire lengths, that plug right in. I am sorry that this was not noticed. Clean the underside of the plastic trim and press and stick facing down. This stays on all the time, but when dimmed, it's sweet.
45 degree micro strips....just passed first inspection, and are insane at what can be done. As this sample arrived 2 days ago, we have tested on a ramp, only by hand, and I'm thrilled. Production is happening, these and much more will be tripling the stuff in Matrix.
Regarding other methods, such as Only
when the ball is in the battlefield....
Well first. I have seen people put the strip
on the metal bar, facing forward.
When I get the strength, I'll do this and take pics, but I have been working on 6
Different, new, and not seen before spotlights. I can't say more, but enough that they will fill lots of demands for many games, including Shadow.
These are all in CAD, and pre proto.
I may have something to share in a couple weeks. Currently, these are
always on.
To create an on only when in use,
I do have a board, not in proto yet, that
Might do the job. It's again a universal use, for many games.
The short answer, is yes, someone could or should make a custom board, charge like $100 for it, sell maybe 50, and then
trickled in orders.
I suppose it may not have happened, as the work/reward, may not be desirable.
I hear weekly in emails, great ideas, things to make, it just takes more time and money, then those that say, "make it"
Some products I have now in testing started over a year ago.
How to do it faster? Work more or pay more.
Some products, I sneek into sample production, rather then throwing 5k at.
This keeps prices down, and I sometimes
feel a GB pin is better then another product. Sorry about that.
Whether it's Matrix Strips, or new spots,
Both are designed to be plug and play, minutes to install, under $20, and can be
used in any game.
That's my goal at least, and no harm in
trying out.
A $100 mod that isn't perfect,
with a couple negative posts, would be so detrimental, I error on the side of caution.
Even a post that states the wires aren't long enough, created a few emails, and all that happened, was a product was not seen.
So plenty ways to light right now, and see
if it's the look you want.
There are pictures in the Matrix section of Shadow lit by nom frosted strip.
Ary
