Quoted from BulkOfTheSeries:I dropped the color DMD in mine today and it looks awesome. I'm having three issues though.
1) The Sanctum Wall wont always lock in the 'up' position. Sometimes it fires and tries a few times, never makes it. Sometimes it locks up briefly to fall back down. Sometimes it works. It appears to be able to raise all the way up, but not 'stay' up.
2.) The back row of my battlefield doesnt pop back up after they're knocked down. They stay down. Is this a switch I need to adjust? I think it is but I'm unsure how.
3.) My ball gets stuck on the left ramp too often. It 'dies' on the wire headed to the right side of the machine, where the little switch the ball rolls over is present. Is this common?
1. I had that problem, make sure the bottom of the target is not broken, mine was cracked and I fixed it, works great now, also the silver arm that Keeps the target straight, make sure that is not putting too much pressure on the target, check the spring, make sure it is not too tight. Also clean the assembly with the coil that pulls the target up.
2. Do a switch test and see if all 4 targets register, also do a coil test and make sure the coil is firing.
3. Had the same problem, I actually took a small piece of plastic and screwed it where the switch was, then moved the switch to the end of the plastic, I also put a small bracket under that wire form ramp to give it more lift.. Now with the glass off, I placed the ball at the beginning of the ramp and it rolls by itself past the switch all the way down.
Hope these help you out
