Confucious said - Is the sun half shining or is the ice half slippery?
Calling all Shadow Agents for some help. I'm in the final polishing of a Pin2DMD colorization for the Shadow and I've going nuts trying to capture some animation frames I'm missing. In the Punish the Guilty mode, there is a scene on the bridge with a gangster is turning left/right and occasionally firing his gun. 90%+ of the time, this guy is on the left side of the screen. Very, very rarely the gangster with the gun appears on the right side in front of the car.
In order to do the colorization, I need to get the animation frames captured from a real pin or virtual pin. So far, out of countless times I've had the game set to capture on the real machine or the virtual - I've got exactly ONCE where the mode triggered with the dude on the right. Unfortunately, when this happened, Vengeance was also running and I got precisely 3 seconds of animation once the that mode ended before Guilty timed out (see the attached screenshot). The good news is that 3 seconds contains all of the frames needed to smoothly get the gangster colorized and animated turning left/right. Unfortunately, he didn't fire off any shots, which can be done in three positions, and I need to get those 3 frames.
Using Vpin, I can set the game to 1 ball and have made some wall "guides" to quickly get the shot into the mode start hole; but, even with that - I've only triggered the right side location once.
This is literally the only mode that's not finished in my project. I've got everything else colorized and simply need to work on the timing triggers. The attract mode needs some work on transistions; but, I'm so close now that it's frustrating to be minus these 3 frames.
Does anyone know if there is some sort of logic behind the gangster's position in this mode? I've tried holding buttons, divertor positions, and even thinking it may be something related to what ball is in play; but, I've got the mode before on 1 ball.
Any help or suggestions would be appreciated.
punishtheguilty (resized).pngpunishtheguilty.gifpunishtheguilty_rightside (resized).JPG
