Quoted from RTS:Is the switch to the right side of the left ramp causing the interference with the ball?
If so, you might try replacing the micro switch with an MRS, which works without touching the ball.
https://pinside.com/pinball/biz/directory/1772-mampm-creations
Thanks - I have the MRS switch installed. Slower shots were getting stuck on that switch. One problem solved - now it’s the fast shots that are a problem.
