Quoted from Brad76:Two battlefield questions
1. Once every few games, the back wall targets will drop when hit and do not reset quick enough before the shot is kicked back up (forward) and it goes out the back of the battlefield before it gets to the magic number, say 30.
Should these back wall targets be dropping at all before it gets to 30 or is this just a glitch of The Shadow in general?
2. Occasionally when a ball is going to the right on the upper playfield, if I am bit late in moving the kicker to the right, it will get stuck as it drops down and gets wedged in the divertor and something below. After about 2 seconds the kicker moves itself back to the middle postion and the ball falls normally. Is this another common issue? Can it be fixed or again is this just a symptom to seal with on TS? Thanks
Both of these are normal, they happen on every Shadow I've played, including my own.
