(Topic ID: 46571)
The Shadow Club
By marsgnu
8 years ago
  • 8,511 posts
  • 642 Pinsiders participating
  • Latest reply 1 hour ago by Damonator
  • Topic is favorited by 231 Pinsiders
There are 8511 posts in this topic. You are on page 150 of 171.
#7451 8 months ago
Quoted from delt31:
Hey guys.... On a dead stop/trapt ball left flipper - can you consistently hit the right ramp shot or is it random?
My flipper seems perfectly fine but I swear on a dead ball, it doesn't make it up ever single time....I have the right cool and all checks out with the typical issues including dirty opto.
It hits majority but not 100% assuming I got the ball right
No issues for me on that shot. I tried it out and it made it easy
#7452 8 months ago
Quoted from delt31:
The other thing I've read (think it was in this thread) is that the Mantis ramps are slightly steeper - I thought this might be worth mentioning, in case you have replacement ramps and the flipper rebuild doesn't address the issue.
I struggle with my ramps however that's because my machine is in need for some TLC
10
#7453 8 months ago
A little bit of a teaser, but on M&M Creations whiteboard we had a solution for a Shadow to explore. Finally a couple a weeks ago - someone came forward asking for a solution via an MRS to the infamous left ramp/diverted to the right switch register issue. Well, it took a lot of R&D, but we think we nailed it and it's out for beta testing with Wmsfan if all is good - we'll begin offering the solution next week. I've included some pics of the long-lever solution most folks employ and some pics of our solution installed and by itself for visualization.
Matt
Resized_20200829_105329 (resized).jpeg20200908_161555 (resized).jpg20200910_080048 (resized).jpg
#7454 8 months ago
Quoted from Sonic:
A little bit of a teaser, but on M&M Creations whiteboard we had a solution for a Shadow to explore. Finally a couple a weeks ago - someone came forward asking for a solution via an MRS to the infamous left ramp/diverted to the right switch register issue. Well, it took a lot of R&D, but we think we nailed it and it's out for beta testing with wmsfan if all is good - we'll begin offering the solution next week. I've included some pics of the long-lever solution most folks employ and some pics of our solution installed and by itself for visualization.
Matt
sweet. I am in on this
#7455 8 months ago
Dude that is genius. So simple and clean.
#7456 8 months ago
Quoted from gunstarhero:
And hidden - we didn't like the idea of cantilevering where the switch normally is (it was too much in view) - that was the lengthy part of the R&D - moving it over where it was more hidden and the ball was traveling in a more stable vector - made sense - but made the engineering tricky....we must have made 8 or 9 iterations I think?
#7457 8 months ago
Quoted from Sonic:
Matt
Looks promising. I've been spending a lot of time with my Shadow the last few weeks on a project I'll be sharing hopefully soon (Pinsound related) and I tackled this issue by extending the switch location further with Lexan. The only issue I'm having now is the ball jumping the ramp occasionally. I may end up trying to reseat the wireform and if I do, this may be a good time to install this mod. In the photo the wires are running back the long way towards the left diverter instead of the right side of the machine, since it's mounted near the upper flipper. Is there a way to run the wires out the right side to hide them better?
#7458 8 months ago
Quoted from jedimastermatt:
That's just pics from testing...the leads are long enough to run to the right and underneath the playfield to the left again for connection....
#7459 8 months ago
I am in on a MRS solution for that shot. The lexan extender has helped but I find that it moves around when it gets hit by airballs, so I still end up with either stuck balls or the switch not registering occasionally.
#7460 8 months ago
Sonic I am very interested in this as well! Please let me know when the testing is complete and how it perfect. I’ll likely be buying one...looks great!
#7461 8 months ago
Quoted from Sonic:
Matt
These work great. With Matt’s help I converted all 3 of my main physical switches on my Who Dunnit 3-way ramp to MRS several months ago. They are fantastic. Sensitive enough to register even fast-moving balls through the side of the plastic ramp. I was nervous about cutting the green and white wires on my stock switches to attach 3 MRS switches, but it’s been well worth it! I’m in on these for my Shadow for sure. Nice work, Matt.
064C242C-4320-4668-BC00-2AAF8F5F6C08 (resized).jpegBA7095D1-72D6-4343-9D5F-5525DA7196A5 (resized).jpeg
#7462 8 months ago
Quoted from Sonic:
Matt
Put me down for one as well please
#7463 8 months ago
Wow, great idea!
#7464 8 months ago
Quoted from Pinkitten:
How much we talking per switch?
#7465 8 months ago
Quoted from Chitownpinball:
$30 plus shipping....
#7466 8 months ago
Quoted from Sonic:
Go ahead and get me on list. I for sure want one.
#7467 8 months ago
I'm in as well!
#7468 8 months ago
Quoted from Sonic:
#7469 8 months ago
So I was fortunate enough to beta test the MRS switch from Sonic for The Shadow, and all I can say is wow!
No more ball hang-ups. Heck, no more switch actuator that even slightly slows the ball down. The flow of the game just feels nicer! You can remove those 'extenders' and the microswitch- I would make sure the MRS switch does work before you remove the microswitch. We probably have 25-30 games on it with it installed, with no issues at all.
I would recommend this switch upgrade to any Shadow owner.
Thank you M & M Creations for this! Now to figure out what other games could use one of these style of switches...
#7470 8 months ago
Quoted from Wmsfan:
I would make sure the MRS switch does work before you remove the microswitch. We probably have 25-30 games with it installed, with no issues at all.
So, whats the deal with this? It doesnt work for every game?
#7471 8 months ago
I don't see why it wouldn't in places it logistically can fit, but it's kinda pricey compared to a standard mechanical switch so I imagine it's probably a waste of money to replace random switches for no reason.
#7472 8 months ago
The body shape of this one is designed to fit this game in the location that was decided on. I also got switches for my Diners, that have a different shape body that allows fit on the curved Diner cup. So it’s kind of a game specific design.
#7473 8 months ago
Quoted from Wmsfan:
That's exactly correct....some are universal - like the original OEM MRS, and the plastic ramp MRS...but some are specific to a solution....We have MRS' for the bowls of CC, TTR, Diner, Taxi, CFTBL...and specific ramp solutions on Taxi and IJ....all kinds of solutions....
#7474 8 months ago
Quoted from Sonic:
Gotcha.
#7475 8 months ago
Quoted from Spacemanratso09:
Thanks for the leads I will email them much appreciated
did you have any luck finding that ramp?
I used plastic welder to get the left side back on a year or so ago, even stuck a finishing nail below the ramp to support it. A few days ago I found both the right and left side broke off .
I took it apart and am welding it back together, gonna try to use epoxy and maybe even bedliner to coat the seams. But It'd be nice to have a new one.
#7476 8 months ago
Alright, we've got our testing feedback (thanks Wmsfan ) thus we are ready for Shadow orders....just shoot me a PM and I'll put you on the wait-list and provide payment details and such! Ask any questions, you can find A LOT of posts/info on Pinside about our MRS'....we've got all kinds of different variations - most popular being the OEM of course as they were stock in 7 WMS pins...followed by the popular CFTBL whirlpool MRS....Diner has been very popular, Taxi, IJ, Cactus, Transporter...and the ramp ones that Pinkitten noted which are universal and have been used in W?D ...and several homebrew pins....
Matt
#7477 7 months ago
On topic? Off topic?... My Shadow now has a friend!
#7478 7 months ago
Quoted from jonesjb:
On topic? Off topic?... My Shadow now has a friend.[quoted image]
Comes off as a bit of a brag, but there’s worse things I guess. Congrats of the R&M!
#7479 7 months ago
Thank you!
And fair, just enthused to have my second pin to put with my Shadow. I’ve been part of this thread community for a few years now and have hopefully supported fellow Shadow owners to have generated good will and trust to not be bragging.
#7480 7 months ago
Cool duo - congrats!
#7481 7 months ago
Thank you!
not bragging at all. about time you added a second pin.
#7482 7 months ago
It's nice to have such cool friends, congrats!!
#7483 7 months ago
Just thinking about the Battlefield plastic replacement? I’m about ready to tear down my Shadow for a refresh and cabinet restore. I remember a list was started for black chrome awhile back. I Will be sending the wire guides down for a swap I remember that there was a project on this as well.
#7484 7 months ago
Quoted from MG7322:
Yes, they are very close to being ready.
#7485 7 months ago
Quoted from MG7322:
Maybe PM sc93cobra who was making them to see if he was making any spare ones or if you can go on a waiting list in case someone pulls out
#7486 7 months ago
Quoted from Manny65:
there are spares.
#7487 7 months ago
I was on the original list for one way back, did I get bumped?
#7488 7 months ago
Quoted from MG7322:
No, I passed that list on to Chris when I started it. My house got hit by a tornado and Chris stepped in and took the project over. It is getting close. I have the decals ready. Should be all done in the next 2-3 weeks - fingers crossed.
#7489 7 months ago
Quoted from woody76:
Really looking forward to this upgrade ... might be time for a complete resto
Have you been able to get started on rebuilding your house or has Covid delayed everything?
#7490 7 months ago
We are 7 weeks from moving in. TN has pretty much stayed open except for nashville. The nashville mayor made headline news today for lying about COVID numbers to keep businesses closed. he is about to be in deep crap.
#7491 7 months ago
I’ll be sending my shadow rails for swap out so maybe the timing will be close to get them plus the battlefield in one box!
#7492 7 months ago
What do you guys think: if I was to only have two machines, what is the perfect compliment to the Shadow?
#7493 7 months ago
Quoted from aFineMoose:
Shadow is a very unique game. Any modern pin that you enjoy will pair nicely.
#7494 7 months ago
Quoted from MG7322:
Anyone on the list before should still be on it, although I did ask everyone to verify their info with me -- sending me their username on here, address, phone and which plating they want. If you haven't done that do it - AND PLEASE DON'T MESSAGE ME ON PINSIDE -- but at my email -- chris@hotrodarcade.com
Hoping soon. The weather has not be friendly to our platers lately, but they parts are made, just waiting for plating to be done.
Chris
#7495 7 months ago
Quoted from Mad_Dog_Coin_Op:
I find it goes well with my Dr Who
#7496 7 months ago
Something with pop bumpers.
#7497 7 months ago
Quoted from LOTR_breath:
Is there another common feature lacking on The Shadow? It has so much going on, but you can't have everything.
#7498 7 months ago
Not super common, but it lacks a 3rd or 4th flipper.
12
#7499 7 months ago
You might want to see if your machine is missing the 3rd flipper and reinstall it.
#7500 7 months ago
Yes, it doesn't have...
-An (often boring) lower playfield
-A vari-target (like in Ripley's, although Ripley's is the only other pin that has a lock similar to Shadow)
-Drop targets
-A shooter (like Dirty Harry, T2, Aerosmith).
-A subway
-A bash toy
-And pops, as mentioned
-Playfield multipliers (Code)
-A captive ball
-A spinning disk, like Whirl Wind, X-Men, TMNT
-A spinner
-A plunger
-Midnight madness
Based on the above gaps, Walking Dead Premium may be a good one, or possibly Avengers.
Wow, this list is longer than I thought it'd be.
