Does anyone have a Shadow keychain and/or any promo plastics?
Quoted from joelbob:
Yeah the inner loop under the battle field. I could use one of those extras if you wouldn't mind shipping it out to me. I'd be happy to pay for it.
I cant definitely do that. Send me a PM.
Quoted from Fish17:
Where is this plastic I don't see it on the inner loop.
Quoted from tiesmasc:
fish17
Here you go
[quoted image][quoted image]
and also... because I'm sure someone will comment on the sanctum wear... it was fixed per below
Quoted from Daditude:
Does anyone have a plastics set for The Shadow?
planetary pinball
Quoted from woody76:
planetary pinball
I was hoping to find a used or a partial set that someone was no longer needing.
Does anyone have any cliffys for The Shadow or have a lead on where I could get them?
I have a partial used set.
I dont think they exist.
https://www.pinball.center/en/
Pinball Center in Germany. Someone is also parting out some used plastics on eBay.
Quoted from 7oxford:
their plastic sets are pretty crappy too.
I can’t seem to find the switch orientation on the yellow target mech to the upper playfield. I’ve had the switch off for months waiting for the parts to finish it and am stuck. Here are a few pics. Any help would be appreciated.
Quoted from Squeakman:
I can’t seem to find the switch orientation on the yellow target mech to the upper playfield. I’ve had the switch off for months waiting for the parts to finish it and am stuck. Here are a few pics. Any help would be appreciated.[quoted image][quoted image]
That's not the original switch actuator arm - but will work assuming it's long enough to make contact with the plastic drop target. The picture is from the drop target on T2 (hence the black target) but it's the same assembly. Also in the 2nd image item 24 is a plastic guide (red arrow points to it as well), this was used to ensure that the actuator arm remained under the plastic tab of the drop target and didn't get pushed to the side. While not shown in the picture the components that were screwed to the switch bracket are - plastic guide (03-8630), switch, insulator (01-8600) and then the bracket it self.
Does anyone have an extra right sling plastic?
https://pinside.com/pinball/market/shops/1026-pinball-haus/02009-the-shadow-sling-shot-plastics
Quoted from Manny65:
That's not the original switch actuator arm - but will work assuming it's long enough to make contact with the plastic drop target. The picture is from the drop target on T2 (hence the black target) but it's the same assembly. Also in the 2nd image item 24 is a plastic guide (red arrow points to it as well), this was used to ensure that the actuator arm remained under the plastic tab of the drop target and didn't get pushed to the side. While not shown in the picture the components that were screwed to the switch bracket are - plastic guide (03-8630), switch, insulator (01-8600) and then the bracket it self.[quoted image][quoted image]
Thanks Manny. That is what I had when I started so it did work before. Whoever worked on it jimmied some screws and such to hold the switch on and I needed to pick up the correct screws. I looked in the Shadow manual and couldn’t find that diagram in there. I’ll check it out when I get home and see if I can get it done.
Yep they missed the diagram in the manual - fortunately the single drop target is used in a few other machines (IJ, JM, NF, STTNG, T2) so leveraged the diagram from one of them
I made a seperate topic, and then realized I might have more chance of a solution in here?
https://pinside.com/pinball/forum/topic/please-help-short-switch-on-the-shadow#post-5470735
So is there anyone who can reliably re-plate or "re-brass" the wireforms at a reasonable price? Some of the prices I've seen are only a few bucks less than buying the whole wireform new...there must be someone more reasonable?
Quoted from mrgregb123:
The problem is there are only a few places left in the united states that still do brass plating with clear coat.
What is price you are seeing? And where can you still buy new wireforms? I am interested too.
Was the original clear coated? I'm guessing no from the fact that they deteriorated over the years, but this is just HUO...will the plating just break off w/o clear?
i am not sure about the original. If the brass plating is not clear coated it will just turn brown in a matter of weeks.
Quoted from dudah:
Learned how to powder coat at the local maker space. Gloss gunmetal plus Art's maple grips! Next up is rails and legs... Torn between metallic purple metallic blue or just gloss black[quoted image]
I did gloss black with purple metallic flake. Looks incredible.
I am still looking for a partial plastics set if anyone has extras or a lead on some (there are about 4-5 that I need). Please pm me
Looking for help rebuilding the battlefield. I've purchased a new motor, bracket, and the pinion gear. Have no idea as far as the steps involved in getting it all together. Any help or input would be appreciated.
Mike
Quoted from mikeflan:
Mike
Download the repair kit instructions PDF from IPDB.org. That should show most, if not all, of what you need.
Full manual is also on there if you don't already have it.
Quoted from ccbiggsoo7:
just powdercoat them. much cheaper.
What kind of powder coat looks like the original brass though?
I had seen this before. Way overpriced. The price is almost the same as what the wireforms cost new.
Their pricing is rather high, but the results are awesome.
I wouldn't even think of powder coating the wire forms on this game as I haven't seen any that look good. The brass is where it is at!
Quoted from Lamprey:
Right? Seems abot $150 over what Id expect to pay. You think it would be cheaper with the swapping...
Quoted from Chitownpinball:
that is the swap price
I used to offer this service. You send your wireforms in and he sends you a set that is redone. The brass does look amazing and they clear coated so will hold up in home environment for a long time.
Does anyone have a 3D model of the phurba dagger? I'm missing one and can't seem to find it for sale anywhere so I guess 3d printing is the only option for now.
Was trying a different soundboard last night and for some reason a fuse blew (see attached photo). This impacted the power to the ball trough, the flippers and the diverters. Is this possible or likely the issues are not connected? Kind of paranoid to try the other SB again as I don’t want to chance messing up the game. Thanks for the help!
Quoted from zezami:
I don't know of a 3D model, but if you want to buy one you might try one of these places:
https://www.pinballinc.com/index.php?route=product/product&product_id=179
https://www.pinballdecals.com/PartsByGamePages/Shadow_Page.html
Quoted from Mad_Dog_Coin_Op:
Bought an entire diverter from a guy in Australia. Got some good parts off it but the shaft of the diverter was cut. Fixable or juck?[quoted image][quoted image]
do you know a good welding/machine shop?
Quoted from Aurich:
If anyone is looking for my translite I'm gonna do a small run, just shoot me a PM. As always these days, every time I do one I say it might be the last, but we'll see.
Does anyone have an aurich speaker panel for sale or know where I can get one?
Pic for reference:
Should be fixable. I'll buy if you junk it and practice welding.
Anyone have glare issues sometimes affecting the battle field kicker? The ball sometimes rests on the kicker on the left side for a bit till the opto kicks in. I didn't have a ton of time to diagnose before heading out of town. Plays great with glass off. Optos register fine in switch test. Actually played fine last night. I pulled the battlefield out to clean the drop targets. I have pinstadium lights I made installed but I've done this on four shadows with no issue. For good measure I covered the lights with tape behind the opto. Thinking this is an easy fix, just wanted to have some ideas lined up for when I get back on Saturday. Wanted to make mechanical adjustments before possibly buying a 24 opto board for under playfield.
FYI, just finished clearing playfield including battlefield. Want it to play perfectly. It is so fast.
Quoted from Djshakes:
Anyone have glare issues sometimes affecting the battle field kicker? The ball sometimes rests on the kicker on the left side for a bit till the opto kicks in. I didn't have a ton of time to diagnose before heading out of town. Plays great with glass off. Optos register fine in switch test. Actually played fine last night. I pulled the battlefield out to clean the drop targets. I have pinstadium lights I made installed but I've done this on four shadows with no issue. For good measure I covered the lights with tape behind the opto. Thinking this is an easy fix, just wanted to have some ideas lined up for when I get back on Saturday. Wanted to make mechanical adjustments before possibly buying a 24 opto board for under playfield.[quoted image][quoted image][quoted image][quoted image][quoted image]
I had this issue when I used invisiglass (could be a coincidence)... I think the opto doesn't realize the beam is broken (maybe due to reflection). What I did to fix was to put some black heat shrink tubing in the holes in front of the opto, so the beam goes straight. It's worth a shot.
