(Topic ID: 46571)
The Shadow Club
By marsgnu
6 years ago
  • 6,208 posts
  • 537 Pinsiders participating
  • Latest reply 9 hours ago by Jeroenos
  • Topic is favorited by 179 Pinsiders
There have been 1,630 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 6208 posts in this topic. You are on page 124 of 125.
#6151 19 days ago
Quoted from mikeflan:
Anyone have a guide or advice for wiring in LEDs into the ring lights
PM rotordave. He has some pics for wiring in a standard led bulb.
#6152 19 days ago
Shout out to ramegoom My Shadow is 99% complete!
#6153 19 days ago
Tired of air balls on this game? Here is a very low tech invisible solution. Picked up these little guys at the hardware store and stuck one each on the problem impact targets. You'll need to adjust the contacts a bit but after that you should be in business.
#6154 19 days ago
Quoted from Johncare07:
Shout out to ramegoom My Shadow is 99% complete![quoted image]
Glad it worked out for you. Looks remarkable.
#6155 19 days ago
Quoted from Mad_Dog_Coin_Op:
[quoted image][quoted image]
I'm not sure that will work long-term. The issue is usually that the metal supports bend backward. I just put flipper rubber plugs in the gap behind the metal after bending it forward. It's been perfect for two years and counting.
#6156 19 days ago
Quoted from Tranquilize:
I forgot to mention that my targets are the reinforced ones. They sit nice and straight but were still generating air balls. The design of the reinforced ones aren't easily modified to bend forward. The extra little pad adds just enough downword pitch on the face of the target when struck to keep the ball on the playfield.
#6157 19 days ago
My back targets on the upper Playfield have not been coming back up once I hit them even though I have more hits to complete. Any ideas where to start looking?
#6158 19 days ago
Quoted from Happy81724:
Yes, likely grimey, try taking them apart, cleaning and waxing.
#6159 17 days ago
Ah, then I’d pull the targets and Bend them forward with some force. My only concern with this is that the rubber stoppers will prematurely wear the foam as it will be affected with each ball hit. More maintenance in the long run. If it works though, good on ya.
#6160 14 days ago
I was just leveling my newly acquired Shadow and heard something drop off the playfield into the cabinet. It was this pivot nut - anyone know where it goes?
#6161 14 days ago
Quoted from shiffdog:
This is the nut that the play field slides on. It screws onto the carriage bolt that is going thru the side of the cabinet.
#6162 14 days ago
Quoted from GRUMPY:
#6163 13 days ago
Sold my game , have just received my CPR gold playfield , Mini playfield and a complete plastics set.
Bought direct for over $1100.00
$800.00 plus shipping takes it!
https://pinside.com/pinball/market/classifieds/ad/83156
#6164 13 days ago
Would you mind posting a picture of your topper. Just picked up the Shadow cars, like to see how you set it up. Thanks.
Was the blue car in the movie?
#6165 13 days ago
Well I’ve finally got the fucker out...lube, punch and hammer didn’t work. Heat didn’t work. Pliers and twisting and brute force finally broke it. I’ve been able to source the parts so breaking the shaft wasn’t the end of the world apart from setting me back quite a few coins. I still don’t really know what made it stick.
Quoted from Manny65:
You'd want to be very careful with a blowtorch - lots of things that could melt around there. I'd suggested heating but was thinking more of soldering iron with a heavy duty tip, as metal expands when heated and heating one bit (eg the crank arm) and not the other (the shaft) can help.
That said seeing the pics, Dave's idea of punch and hammer is the way to go.
#6166 13 days ago
Quoted from dluth:
Wow that was one tough bugger to get apart ... Unfortunate that it ended up breaking but as you said the replacement parts are available and at least you can now move forward
#6167 11 days ago
I’d love to join the club if anyone has a lead on one within a reasonable driving distance of Indianapolis. Project or players condition is totally fine. Thanks!
#6168 11 days ago
Anyone have a working Shadow soundboard they be willing to sell me? If you swapped out for a Pinsound board, etc. Keep having issues with mine and the woofer going out. Thanks.
#6169 9 days ago
Quoted from pinballjah:
why not just get yours fixed? If the cabinet speaker is going in and out. Probably a bad connection to your speaker, the plug going to it, the wires or the wires on the speaker itself. if you have extra speakers with the same ohms sitting around. Hook it up and see if it goes in and out or not.
#6170 9 days ago
Quoted from CaptainNeo:
Thanks. It is the sub woofer, something keeps blowing on the soundboard. It has happened to me once before and also a friend's game. The issue is every time I get a tech to replace it, cost me $50. I figure it might be cheaper just to buy a new soundboard so I don't have to spend on techs anymore. I may just use an external sub woofer.
#6171 8 days ago
It’s not a sub, it’s just a speaker.
(Unless you changed it to a different speaker ... )
If it keeps blowing doesn’t it indicate an issue with the speaker? Why not swap in your Dr Who speaker for a while and see what happens ...
rd
#6172 8 days ago
Calling on experts. Sanctum issue.
I have an odd problem with the wall target (brick wall in the Sanctum). On startup, I occasionally get an error "Wall Target Bad, Check Switch/Coil". Checked the switch, diode and both coils. All work correctly. The manual test for both coils and switch all function normally.
What happens is, the wall doesn't drop during game play. It should drop once you enter the magnet and cross the opto, but isn't happening. Also, it seems the magnet is weak, won't hold the ball even though it does function on the manual test -somewhat. The magnet used to hold the ball solidly, wait a quarter of a second, then shoot it into the Sanctum. Doesn't want to do that now but instead just kind of wobbles the ball when it crosses the opto, and I'm thinking this is the underlying problem. The machine is about as clean as they get, with no real wear at the magnet of the Sanctum entrance.
Any ideas what tree I should be barking up?
#6173 8 days ago
Quoted from rotordave:
rd
Thanks, it is a Fiipper Fidelity speaker.
#6175 8 days ago
I’d do the swap - it’ll take 5 minutes, you got nothing to lose.
rd
#6176 8 days ago
I don't think this speaker has the same impedance as the original speaker. This can cause the power amp to blow on the sound board from excessive current draw.
#6177 8 days ago
Thanks for the link, it helped a lot. I now realize the switch should only activate by contacting the wall when down. The lift arm shouldn't activate the switch. I had it doing just that.
With the lift arm activating the switch, the CPU would think the wall is down when it's up, since the arm drops down by its own weight and comes in slight contact with the switch lever.
Works perfectly now.
#6178 8 days ago
Quoted from ramegoom:
I had a similar issue years ago and had to rack my brain to remember where I found it.
#6179 8 days ago
I thinking to give the switch at the bottom of the wall mech a good look.
#6180 8 days ago
Quoted from GRUMPY:
I don't think this speaker has the same impedance as the original speaker. This can cause the power amp to blow on the sound board from excessive current draw.Ok, maybe that is the issue.
But I think this is a Flipper Fidelity speaker that was made for the original soundboard (not the Pinsound version). I can take a photo if that is helpful. Thanks as usual.
#6181 8 days ago
Yes if you can get a pic of the speaker label.
#6182 6 days ago
Topper is done.
058405DD-DCF2-4314-947B-2BD8423AFCA2 (resized).jpegA6A8DE18-1FBF-49DC-B406-7B919C7554A0 (resized).jpegE56BD4AE-4D1D-4016-A10F-A2EFDBEEA72F (resized).jpegFDFECB95-9ADD-4A9E-9EEF-025B3D47D1D9 (resized).jpeg
#6183 6 days ago
Was adding the headlights tough to do? I also picked up a Shadow car recently. Trying to make a stand for it. Thanks.
#6184 6 days ago
I'm wondering if anybody has this same issue, after the balls are locked in the sanctum area and are released if I don't hit the ball with my upper flipper 90% of the time they will go straight down the middle, are there any adjustments for this? I have my game set fairly steep so it plays fast but just wondering what others are doing
#6185 6 days ago
Anyone have a recommendation for colorful score/freeplay cards? The black and white factory originals just don't cut it.
#6186 6 days ago
Quoted from Wmsfan:
Been looking at mine too...might have to make some myself.
#6187 6 days ago
Quoted from Wmsfan:
http://www.pinballcards.com/
#6188 6 days ago
Quoted from Wmsfan:
There are some floating around, but I like Aurichs design the best. He has a thread on pinside and posted the artwork to it.
#6189 5 days ago
Quoted from Yesh23:
back isn't leveled correctly. Lift up the back left leg about 3-5 threads.
#6190 5 days ago
I used a Dremel to cut out the car headlights. Easy.
#6191 2 days ago
Quoted from Twister:
Hi,
Thanks for you feedback Terry. I'm happy you like it.
I have received many messages. Terry got one of the 4 prototypes. The first order is not yet completed, I'm still waiting for 24 parts of the chrome plating. Unfortunately, the chrome takes a little longer. It is not made commercially, a friend does that after work in his spare time. I wait daily for the parts.
Since I have received so many requests now, I will try to make a 2nd order, and looking for a different provider for the chrome plating. Or another surface, maybe a black slc coating.
Sascha
put me on the list too. looks fantastic!
#6192 2 days ago
Quoted from ccbiggsoo7:
2nd best mod I’ve seen for the Shadow behind the Aurich package of course, well worth it
#6193 2 days ago
Quoted from allsportdvd:
What is the mod? I can’t find the OP
#6194 2 days ago
twister is the mod owner, I don’t think there is a dedicated post for it
#6195 2 days ago
Before I get a lot of private messages, here is the current status.
I get the most parts from first run back from chrome plating.
I am actually shipping these parts. First People who are on my list for first run have get a message.
3 parts I have here without chrome plating. With these parts I will go to a local plating company. If this company do good work for a good price, I ship this 3 more parts, and then I start a second new list.
Unfortunately there was an accident with some parts. They have fallen from the hook into the sink in the electroplating, and lay there unnoticed for a few days. So I have not enough parts.
Sascha
#6196 2 days ago
Sascha
What is the mod you’re making?
#6197 2 days ago
@Twister posted about a replacement battlefield plastic (the one that surrounds the battlefield) done in metal and then black chromed. He's done a small run of them - you can find pictures in his posts in this thread
#6198 2 days ago
Ah, ok, depending on price I would be interested as well
#6199 1 day ago
I would imagine they will be at least $200.
#6200 1 day ago
Quoted from woody76:
No, 130€ with shipping to US
But I can't promise if I can hold the price with another plating company.
Pin Mods
$ 159.99
$ 229.99
