Quoted from pinballjah:
I noticed that the woofer of my Shadow wasn't working so I decided to check the connections to the soundboard to make sure they were all connected properly. I decided to check some of the other connectors to make sure they were all in fully, and that's when things went wrong.
First, I turned on the game and the monitor wasn't working (just a scrambled green screen) and the game wouldn't turn on (to start a new game). I checked the connectors to the DMD and one had come loose. I turned the game on again and the DMD and sound are working but now all I am getting are these numerous errors. Also, I think one of the balls has disappeared (if that makes sense). I checked the balls and there were only four and I was getting a message that a ball is missing. So I put a 5th ball in but when I start the game, no ball is coming out into the shooter lane. There has never been an error about a ball missing so there must be a ball stuck in the game somewhere.
Here are the various error messages. Any idea what might be causing this? Could it be a blown fuse(s)? It seems odd all of these errors would start at the same time when the game was working perfectly (with the exception of the woofer). Thanks for the help!
TEST REPORT
CHECK SWITCH 48 SHOOTER
CHECK SWITCH 51 WALL TARGET DOWN
CHECK SWITCH 55 BATTLE TARGET DOWN
ER. WALL TGT. BAD CHK. SWITCH/COIL
ER. BAT. DROP BAD CHK. SWITCH/COIL
Also, the diverters and the flipper buttons are not working. Not sure if they are not activated until a ball is in the shooter lane? Thanks.
