New! Dark mode!
(Topic ID: 46571)
The Shadow Club
By marsgnu
7 years ago
  • 7,809 posts
  • 611 Pinsiders participating
  • Latest reply 4 hours ago by Manny65
  • Topic is favorited by 210 Pinsiders
There have been 2,147 images uploaded to this topic. (View topic image gallery).
There are 7809 posts in this topic. You are on page 122 of 157.
#6051 1 year ago
Quoted from Happy81724:
Powder coat came back today. We are very happy with the look especially with the alt translite[quoted image][quoted image]
Love the way that the colour turned out. Looks much better than the colour that my wife picked out for mine
#6052 1 year ago
Quoted from Stuieb84:
Keep blaming the wife....lol
#6053 1 year ago
Should have vetoed it ...
rd
#6054 1 year ago
Looks beautiful.
#6055 1 year ago
Quoted from rotordave:
rd
Happy wife = happy life
#6056 1 year ago
Bad trim = sad pin
rd
#6057 1 year ago
Fart in the wind = wasted sin
#6058 1 year ago
This works so i havent bothered to fix it, but man does it set some OCD off in my head...
Thinking about adding a few washers below the left side to straighten it out.
#6059 1 year ago
Quoted from Chitownpinball:
Thinking about adding a few washers below the left side to straighten it out.[quoted image]
Mine is similar too.
#6060 1 year ago
So I suck at teching and cant figure out my flasher issue yet. But I can install a matrix mod I had laying around for another game! May look better with a purple post, but this will do for now...
Here is where Im at on the flasher issue. Text to my buddy for help:
“Just pulled all the flashers on shadow. I had tested it real quick before hand with the breaker on to see if maybe one of them was out and was causing the issue. Not the case. The machine makes a louder humming noise when the flashers would test and all the flashers were dim, not bright. So I pulled them all, and tested ohms for shorts. All came back clean.”
I also pulled J106 and J107 respectively and both still blew the breaker when on one by one.
Any ideas?
#6061 1 year ago
I saw this topper from the ACNC thread and thought it'd be a cool mod to flash during the multiball as it kind of copies the DMD. It's a Gemmy LED projector.
Anyone know how it could activate only during MB?
#6062 1 year ago
Any ideas on why the battlefield is not operating correctly? The kicker fires sometimes but won’t move right??
#6063 1 year ago
Quoted from Johncare07:
There are some optos underneath the battlefield that control left and right movement of the kicker. I had one go bad years ago. Sometimes a wire will pop off the opto as well that can cause that.
#6064 1 year ago
I did a test of the playfield and got this screen. The manual doesn’t have any guidance for the error. Any thoughts?
I will check the opto
#6065 1 year ago
Right! I had a few PMs a few weeks back about how I was going to fix my lower right ramp switch so it actually registers EVERY time the ball is shot up there. You may remember I shot a video showing the ball jumping the standard switch.
So let’s make one!
This has been done many times before ... it’s the best way to go IMO.
I made mine out of 3mm high impact acrylic. But you could use aluminium or metal.
I machined the acrylic down to approx 100mm long x 30mm wide.
I marked out where the vertical support was on the wire form, and filed out a small groove to fit around it.
I drilled the holes for the switch and mounted it to the acrylic. I just used the long lever switch that I had on the machine, but the standard switch would also work fine. I used the standard switch screws and mounting plate.
At the other end, I used 2x machine screws, washers and lock nuts. I had to drill out the mount a little as these were the smallest screws I had on hand. Smaller diameter machine screws/bolts would be better.
I bent the switch lever to suit, so it always registers, but a slow ball doesn’t get stalled on it.
Works like a champion. Registers every single time. SUPER VENGEANCE!
rd
Great work ROTO, do you happen to have the dimensions of it?
#6066 1 year ago
I will check the opto[quoted image]
As noted, check your opto board under the mini pf. Once you lift the mini pf, put the game in switch test mode and slide a piece of paper through the optos to see if they register.
#6067 1 year ago
lift up the mini playfield. There is a black bracket where the side to side coil has a spur gear. That bracket has a very thin spot in one of the corners, that likes to break often. Make sure your metal bracket that has the teeth track on it, doesn't have a broken corner where the spur gear moves inside of .
#6068 1 year ago
Installed the cityscape backboard decal from brewninja, came out great...added some ice blue backboard lighting to highlight it more. No need to remove the backboard, just remove the flasher covers and the two screws holding the battlefield exit ramp and you have a clean slate to work with. I used a little dawn a water to help with positioning.
#6069 1 year ago
Quoted from Yesh23:
In the post.
rd
#6070 1 year ago
Quoted from Lermods:
Installed the cityscape backboard decal from brewninja, came out great...added some ice blue backboard lighting to highlight it more. No need to remove the backboard, just remove the flasher covers and the two screws holding the battlefield exit ramp and you have a clean slate to work with. I used a little dawn a water to help with positioning.[quoted image][quoted image]
Think ill stick with my first thought that warm white would look best. You washed all the color out of that art man. Bummer.
Wait, nevermind. You bought the bootleg decal. Thats why its not right.
#6071 1 year ago
Bootleg? I bought it from a seller with a pinside shop. Is there another version?
#6072 1 year ago
Just finished the shop job on my new to me The Shadow. The pin had a few problems but good bones. Came out great in my opinion. Not to bad for rescuing it out of an arcade.
#6073 1 year ago
Quoted from Mad_Dog_Coin_Op:
Just finished the shop job on my new to me The Shadow. The pin had a few problems but good bones. Came out great in my opinion. Not to bad for rescuing it out of an arcade. [quoted image][quoted image]
Looks great!
#6074 1 year ago
jonesjb makes the official one as far as im concerned.
#6075 1 year ago
Lift up Mini Playfield and make sure your kicker slides back and forth really smooth. Make sure you clean off the two metal guides. Operators used to lube those, but that’s a bad idea. They can get gummed up that way. Make sure the two metal guides are tight and solid as well. I had a similar issue and one of my guides was compromised. The rubber piece on the end was ripped. I had to buy a new one from Marcos.
#6076 1 year ago
Quoted from Jimmyhonda:
Mine would get sluggish over time. I would then clean the shaft and it would be ok for a week or so. Mine was full of grease as well. They say once those brass bushings get grease on them,they are screwed. I bought new ones and it worked fine ever since. If your shafts are pitted , they should be changed also. But one of the shafts marco sells is too thick for the bushings he sells. Dont remember which one though.
#6077 1 year ago
These two components work together to move the diverter. They had a brass "upgrade" spur gear but the problem was, the brass would eat up the nylon rack gear quickly. So, the ideal combination is to use the nylon material on both parts. It's not really necessary to lube those parts since grease only attracts dirt and dust, causing early failure on the material.
The spur gear uses a set screw and a roll pin to hold it in place. If the pin is missing, the set screw could come loose and cause the gear to rotate on the shaft. Be sure the pin is in place on the gear.
The rack is held in place by three screws; don't over-tighten the screws as the shallow threads can easily be stripped out. If the rack is not secure, it'll bind.
#6078 1 year ago
Link?
#6079 1 year ago
Quoted from allsportdvd:
Thanks to twister I have my Shadow Battlefield plastic mod! The black chrome looks nice and even though it’s a tighter fit than the original it’s much more attractive[quoted image][quoted image][quoted image]
love that sanctum dot
#6080 1 year ago
Quoted from ramegoom:
How is nobody 3D printing these?
#6081 1 year ago
Quoted from dudah:
They're available new.
Molded out of reinforced nylon. But if you 3D the part, it'll wear out quickly. You can't find filled material like this for printing.
#6083 1 year ago
Didn't know that, link please?
#6084 1 year ago
Marco has the complete kit:
https://www.marcospecialties.com/pinball-parts/A-20267-RP
#6085 1 year ago
And it's ONLY $90.
#6086 1 year ago
Quoted from Reznnate:
And it's ONLY $90.
We are putting multiple generations of Marcos family through college at this point
#6087 1 year ago
Quoted from lordloss:
yep, but they do carry a very large line of stuff. almost always guaranteed to have what you need and only have to order from 1 place. They are good people and he gets tons of parts custom manufactured that can't be purchased anywhere else.
#6088 1 year ago
And it's ONLY $90.
Add about $70 USD on top of that to post it to New Zealand ... and feel my pain.
rd
#6089 1 year ago
rd
Just for LOLs I went and put it in a cart to see how much shipping it was for that one item.
I wasn’t too far wrong.
rd
#6090 1 year ago
rd[quoted image]
Yep being in Australia I never order from Marco either. If I absolutely must, I have it shipped to a friend in the USA who then sends it to me First Class International which Marco won’t offer. Funny thing is I pay 2 lots of shipping and it’s still less than half that $69USD
#6091 1 year ago
Me too. My last order the quoted $75 USD shipping, it worked out at $30 NZ bucks ($20 USD) including Marco shipping to the NZ post depot in Portland and then NZ post shipping it to me.
Big difference.
If I’m going to the States my suitcase always comes back full of pinball stuff.
rd
#6092 1 year ago
PM me if you have a set of sling plastic protectors you want to sell, thanks
#6093 1 year ago
So I need to replace my left diverter bracket as a bit at the end has snapped off. Following the manual’s instructions to remove the mechanism, I removed both set screws and the shaft that connects to the phurba is supposed to slide out...but it absolutely won’t budge. I’ve pulled it, pushed it and it doesn’t even look like coming out. Any advice?
#6094 1 year ago
I get a lot of airballs off the left ramp targets, is there a fix for this?
#6095 1 year ago
I noticed that the woofer of my Shadow wasn't working so I decided to check the connections to the soundboard to make sure they were all connected properly. I decided to check some of the other connectors to make sure they were all in fully, and that's when things went wrong.
First, I turned on the game and the monitor wasn't working (just a scrambled green screen) and the game wouldn't turn on (to start a new game). I checked the connectors to the DMD and one had come loose. I turned the game on again and the DMD and sound are working but now all I am getting are these numerous errors. Also, I think one of the balls has disappeared (if that makes sense). I checked the balls and there were only four and I was getting a message that a ball is missing. So I put a 5th ball in but when I start the game, no ball is coming out into the shooter lane. There has never been an error about a ball missing so there must be a ball stuck in the game somewhere.
Here are the various error messages. Any idea what might be causing this? Could it be a blown fuse(s)? It seems odd all of these errors would start at the same time when the game was working perfectly (with the exception of the woofer). Thanks for the help!
TEST REPORT
CHECK SWITCH 48 SHOOTER
CHECK SWITCH 51 WALL TARGET DOWN
CHECK SWITCH 55 BATTLE TARGET DOWN
ER. WALL TGT. BAD CHK. SWITCH/COIL
ER. BAT. DROP BAD CHK. SWITCH/COIL
#6096 1 year ago
Quoted from dluth:
Maybe somebody spotwelded it on
#6097 1 year ago
Back metal support of switch is probably bent back. You can bend it back and use extra padding but probably not a long term solution. Get the reinforced switches and that should fix it for good.
https://www.marcospecialties.com/pinball-parts/A-18530-6R
#6098 1 year ago
Quoted from yellowghost:
Oh, then I’m screwed then? What would be the solution?
#6099 1 year ago
Quoted from dluth:
Can you remove the other one?
#6100 1 year ago
I will try that later today
$ 159.99
Arcade Upkeep
$ 19.99
PinballElectronics.com
PCB Emporium
