Well, it certainly sounds like you’ve covered all the bases. It’s peobably something stupid we are all looking right past.
Quoted from Jimmyhonda:So, I’m still having issues with my shooter plunger. It works well every other or every third plunge. When it works well, it shoots it up the wire form very well. When it doesn’t work, it doesn’t even make it all the way up the wireform. I checked the alignment and it’s good. I also checked for any loose screws. Everything seems okay. Any suggestions on what to do? Thanks everyone.
Get an iPhone and film the launch sequences in slo motion. Then watch back and you’ll see what happened.
Slo mo is invaluable for working out things like this.
I had a similar launch issue with my Metallica - the ball wasn’t sitting square on the launch forks and it would launch off centre and do really crazy stuff. Slo mo captured what was happening and I could fix it.
rd
Hello, the slo mo didn’t reveal anything. It seems to lack enough power to get the ball up the wireform every few shots. I’m stumped on this.
Quoted from Jimmyhonda:Hello, the slo mo didn’t reveal anything. It seems to lack enough power to get the ball up the wireform every few shots. I’m stumped on this.
Is the ball rattling along the lane or wireform after it is fired?
Any contact with the rails or something like that will slow the ball and make the sequence fail.
rd
Change coil sleeve
I know this has been posted before countless times but I can't for the life of me find it!
Anyone have a link to the recommended switch to eliminate ball hang up on the left ramp (when diverted to the right)? Thanks!
Quoted from isJ:I know this has been posted before countless times but I can't for the life of me find it!
One with a long straight arm. I bent mine up just a little bit after I was still getting the occasional fly off
I believe this is the one:
https://www.marcospecialties.com/pinball-parts/12-SMSB
Quoted from isJ:Anyone have a link to the recommended switch to eliminate ball hang up on the left ramp (when diverted to the right)? Thanks!
Talking of Slo Mo ...
Last week I filmed that switch to see why it wasn’t triggering.
I’d replaced it with a longer arm switch ... mucked around with it for a month ... and I’d still get the occasional “no trigger”
I put the footage on Facebook - check it out.
https://www.facebook.com/532998618/posts/10157373319658619?s=532998618&sfns=mo
Sorry if you don’t have facebook ...
(Spoiler alert ... for those that don’t ... the ball jumps the switch lever!)
rd
Quoted from Yesh23:I just joined the club! What do people do to brighten up the upper playfield?
I put a double flex led in the back right corner of the upper pf. One head pointed down towards back of game and the other pointed towards middle of upper pf. It does a pretty good job lighting up everything and super easy install.
Quoted from Scoot:Comet strip in the back does the trick.[quoted image]
Where did you get the brick decal for the back? That looks totally awesome
Quoted from Lamprey:I believe this is the one:
Ty!
Quoted from isJ:Ty!
You’re better to keep your original switch and make an extension piece.
My videos above prove that the longer switch isn’t always reliable.
Something like this is the way to go ... I’m making one in the weekend.
rd
12C26BFB-35EB-4D91-9873-207B80ADD8D9 (resized).jpegQuoted from Yesh23:Where did you get the brick decal for the back? That looks totally awesome
I think it was this I used.
World Model Miniatures Dollhouse Miniature Modern Brick Wall Material https://www.amazon.com/dp/B00Q1ZTDMO/ref=cm_sw_r_cp_tai_1-WaDb7AEXGVJ
Quoted from rotordave:You’re better to keep your original switch and make an extension piece.
rd[quoted image]
Sorry I'm not sure what the difference is between the longer switch and the one you posted, it looks like a longer switch that's slightly bent. What am I missing?
Quoted from isJ:Sorry I'm not sure what the difference is between the longer switch and the one you posted, it looks like a longer switch that's slightly bent. What am I missing?
It has a plastic bit that relocates the switch.
Quoted from gunstarhero:It has a plastic bit that relocates the switch.
Indeed.
That way, the ball is settled down before it hits the switch area.
I guess it depends how your game is set up. I know some have had success with the longer switch in the standard position. And I know others where it hasn’t. My game is super fast and the ball flies up that ramp, as you can see in the videos. It jumps the switch 1 out of 3 times on average.
rd
I wanna join this club. Some one sell me a shadow!
Also, is there a list of must have mods for this game?
Must have mods:
Aurich translite and speaker panel
ColorDMD
That's it, IMO. Then again, I just bought this one with a whole lot more mods than just these 2:
https://pinside.com/pinball/forum/topic/for-sale-shadow-the-66
Those are good ones... plus it really does need a decal for the back board. It looks so plain black with just the 3 flashers there.
Quoted from gunstarhero:Those are good ones... plus it really does need a decal for the back board. It looks so plain with just the 3 flashers there.
The above, plus switching out the orange flasher domes for purple ones (and purple LED flashers) makes a huge difference.
Quoted from stevevt:Must have mods:
ColorDMD
Congrats! I think you got a killer deal on that one given the new playfield, new parts, mods, colordmd, and custom painting. Love the custom painted sanctum wall target. Looks like real brick.
One thing I think the game needs that most do from that time is added lighting. Upper pf and back area are a little dark.
Hey guys, having issues with my ball lock release (for multiball at top-right of playfield). Posted details here is anybody has run into this before: https://pinside.com/pinball/forum/topic/shadow-multiball-release-help#post-5045987
Thank you! -- Craig
Quoted from dudah:The above, plus switching out the orange flasher domes for purple ones (and purple LED flashers) makes a huge difference.
The only game I found that I really love Purple Dome Flashers on!! Great Light Show!
Hey, I have an intermitent weak launcher. I've replaced the sleeve, cleaned all parts of the mech, aligned it to the centre of the ball, checked the voltage and resoldered the coil. Can't think of much else to do. I do have my game jacked up in the back, but it works 80% of the time with way more than enough power. Any thoughts?
Quoted from OLDPINGUY:The only game I found that I really love Purple Dome Flashers on!! Great Light Show!
Art, I did this months ago based on your recommendation. Awesome change
Have CPR gold playfield and mini playfield and plastic set coming up for sale in the next few weeks.
This playfield has the inserts to light up the headlights ... will post a formal ad to the market place soon
To answer my own question, I finally fixed the weak launcher by removing the rubber stopper at the back of the pin. I built a thinner pad and my launcher is crazy powerful. Funny how I fix a problem months old immediately after I finally post. That's how she goes!
I've had a number of requests so I will be doing another print run of my Shadow Cityscape Decal. These run $30 including shipping to US (international shipping is extra). These are color matched with a halftone dot design from scratch similar to the plastics. Please PM me to let me know if you would like to be added (or removed) to the order list. I should receive these from the printer around the end of June.
On the list I have:
Yesh23
Spacemanratso09
Smurrill1
RobDutch
MANTO1975
attack7777
vulcan903
MikeS
Here's some feedback on the mod: https://pinside.com/pinball/community/pinsiders/jonesjb/feedback
Quoted from jonesjb:I've had a number of requests so I will be doing another print run of my Shadow Cityscape Decal.
This is a great mod, looks original, fits perfectly, love it on my shadow - thanks jonesjb!
Hey all! So happy to find this topic
Question re: a fuse that keeps blowing every time I push the "Start" button. For whatever reason, this same fuse blows before the ball gets kicked out into the shooter lane (see attached photo).
Has anyone ever experienced this issue? If so, any insights into what the problem might be?
Thanks in advance!
IMG_0158 (resized).JPGQuoted from jonesjb:I've had a number of requests so I will be doing another print run of my Shadow Cityscape Decal. These run $30 including shipping to US (international shipping is extra). These are color matched with a halftone dot design from scratch similar to the plastics. Please PM me to let me know if you would like to be added (or removed) to the order list. I should receive these from the printer around the end of June.
On the list I have:
yesh23
stuieb84
spacemanratso09
smurrill1
robdutch
manto1975
attack7
vulcan903
mikes
[quoted image][quoted image]
Hi there - your backdrop is excellent, but I got a spare copy from another user on pinside, so no need for my name to be on this list for the next print run.
stu
Quoted from Sean_R:Hey all! So happy to find this topic
Thanks in advance![quoted image]
You have a short somewhere in that circuit. That's fuse F112. Try looking up what's on that circuit. I'm not sure but guessing it has something to do with the coils. Once coils get energized on game start something shorts. Start with looking for any of the coil lugs touching metal brackets or other bare wires. Maybe wire or diode came loose.
Hey all I am having an issue with the drop bank on the mini-play-field and was looking for some guidance.
Issue:
When I power on the game it appears to boot fine and run through the coil test. I start a game and get the ball into the mini-playfield and it works fine the first time and even the second time. Then, when the ball attempts to go up to the playfield again, ( still within the same game) the coils pulse as if they are resetting the drop bank. It pulses about 5 times then it will give me an error message. When the ball eventually get onto the mini playfield, the drop targets fall and stay down.
I did find a few posts on this topics and here is what I have tried so far:
1. In switch edge test the optos appear to register fine.
2. I replaced the ribbon cables with ones from another game, but still have the issue. Although it did seem like it took the issue a little longer to manifest.
3. I turned off the mini playfield in the menu and played a game then turned it back on.
4. I reseated the connection to the opto board.
At this point my next step was to swap out the CPU from another game.
Any other suggestions would be appreciated.
thank you,
Quoted from Arcadevudoo:Hey all I am having an issue with the drop bank on the mini-play-field and was looking for some guidance.
Issue:
thank you,
Does the reset bank move freely if you raise it with your hand? Do you feel resistance? You may have a swollen coil or a bad coil sleeve making it hard to reset (and getting harder as the coil heats up and the swelling around the interior gets more pronounced).
Hi,
I'm facing an issue with the mini-target that gives access to the mini-playfield.
If i push it by hand, it stays up ; but in test or during game, it never manages to raise up enough to be stuck in high position.
Can someone share some pictures on the shaft + coil + switch to try to set it right ??
thanks
Quoted from PinMonk:Does the reset bank move freely if you raise it with your hand? Do you feel resistance? You may have a swollen coil or a bad coil sleeve making it hard to reset (and getting harder as the coil heats up and the swelling around the interior gets more pronounced).
Good question, when I test the coil, it appears to be ok. When I move the target assembly,to reset with my hand, it appears fine. I honestly do not feel a hint of resistance.
ColorDMD
hell of a deal, I had just bought one with a clear coated playfield or I would have purchased this one. Easily a $5500 machine.
Quoted from jawjaw:You have a short somewhere in that circuit. That's fuse F112. Try looking up what's on that circuit. I'm not sure but guessing it has something to do with the coils. Once coils get energized on game start something shorts. Start with looking for any of the coil lugs touching metal brackets or other bare wires. Maybe wire or diode came loose.
Will do. I'll look tonight. Thanks so much for taking the time to reply! Much appreciated.
The left one is available but the right one isn't. Kind of crazy.
https://www.pinballspareparts.com.au/catalogsearch/result/?q=gun+grip+shadow
https://www.pinballdecals.com/PartsByGamePages/Shadow_Page.html
For the rest of the crew here: Any guesses as to what a used right side grip would sell for?
Quoted from Johncare07:Does anyone have a lead on where to get the gun grip replacements? Is there a way you can use a real gun grip as a substitute?[quoted image]
I have a few custom wood grips left.....theres a link, next to my avatar.
This page was printed from https://pinside.com/pinball/forum/topic/the-shadow-club/page/117 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
