(Topic ID: 46571)
The Shadow Club
By marsgnu
6 years ago
  • 5,629 posts
  • 513 Pinsiders participating
  • Latest reply 14 hours ago by Squeakman
  • Topic is favorited by 169 Pinsiders
There have been 1,486 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 5629 posts in this topic. You are on page 110 of 113.
#5451 37 days ago
I am assuming no one has posted this yet. I spotted it on craigslist and I got a pretty good giggle out of it so I thought I would share. So much so, I may post it in the regular general forum as well. Apparently, when it comes to the sanctum, it pays to discover.
#5452 37 days ago
Someone posted that in the worst hacks thread. Honestly, that doesn't look too bad! I've seen worse paint matching jobs!
#5453 36 days ago
Can anyone post a picture of the upper flipper coil and it's wiring?
I had an the upper coil seize up a while back. I replaced it, but it hasn't seemed right ever since. Though I'd double check my wiring first and then work from there.
#5454 36 days ago
Quoted from Lamprey:
Hope this helps...
#5455 36 days ago
Quoted from PinballCoug:
Hope this helps...
Perfect. Much appreciated!
#5456 36 days ago
Quoted from Demoman1:
Chromed mine......
I like the purple lights replacing the green on the playfield.
I've put spot lights on the sling shots.will post once my 5A fuses arrive as I blew F110 this week.
#5457 36 days ago
Does anyone have a spare bracket and plunger assy for the wall target they could sell me? Mine is worn and the wall won’t reach high enough and so isn’t working. Everywhere seems out of stock:
https://www.marcospecialties.com/pinball-parts/A-18752
#5459 36 days ago
Quoted from MANTO1975:
Hi everyone,
I am currently having my Shadow fully stripped and refurbed to like new, would just like to know what you all would do with the legs, side rails and lock down bar, I cant decide on gloss black or fully chromed.
cheers
Trevor
Thanks for your opinions everyone, still cant make up my mind.
cheers
#5460 35 days ago
cheers
Rails and legs black, gun chrome (to match the movie, unless you just don’t care about that kind of thing) would be my vote.
Going all chrome would be cool too.
#5461 35 days ago
Fixed -Alright I was able to work on my Shadow last night for a couple of hours and got the magnet area fixed. Seemed to be the switch at the bottom of the drop target causing problems for me.. I adjusted the switch so it only registers when the drop target drops, mine was registering from the little metal bar instead and everything now seems to be working correctly now. Thanks everyone for your help!
#5462 35 days ago
Black chrome (nickel plating) looks beautiful...my vote.
#5463 35 days ago
Quoted from dluth:
Keep looking. It probly will be back in stock eventually
#5464 30 days ago
Hey,
I finally got around to attempting to adjust my diverters, but from the looks of it, there will be more work involved. Unfortunately, it doesn't look like it's a matter of loosening the hex screw and adjusting the arm assembly. Everything looks warn out and the left diverter is actually hitting the coil. Check out these videos and let me know what you think I need to do, and if parts are needed the best place to get them. Also, the one hitting the coil is the left diverter and the other one is the right diverter.
Thanks!!
#5465 30 days ago
Does anyone know the type and size of the screws holding the gun to the cabinet?
#5466 30 days ago
cheers
Here’s my all black one we just finished recently. Everything black. Almost.
rd
2A458BDE-29D3-4979-AAA5-D1727EA0F9B1 (resized).jpegCCAB4CB5-D2F6-4BA5-8EA2-9468F8060D23 (resized).jpeg
#5467 30 days ago
Quoted from RockBass14:
Hey,
Thanks!!
That looks like the set screw collar on the diverter arm is moving independently from the crank arm. The collar and arm should be one solid piece. It used to be hard to find, but Marco now has them in stock. It might just need this piece: https://www.marcospecialties.com/pinball-parts/A-18983
#5468 30 days ago
Thanks, I'll start with that. Hopefully, that's all that it needs! Is there something I should just swap out while I'm down there and do a overhaul of the diverter assemblies?
#5469 29 days ago
If you didn't take the spring off to make it easier to see, you're missing the tension spring.
You probaby want to replace the roll pin that connects the crank arm to the armature.
Maybe replace the coil sleeves while you have things apart.
Nice diagrams with part numbers in the manual, which is available on IPDB as PDF if you don't already have it.
#5470 29 days ago
Quoted from RCA1:
More good info; I don't have that manual but I'll be sure to get it. I didn't remove any springs so maybe it popped off, I'll have to look inside the cabinet for it. Are the parts you mentioned all available on Marco?
#5471 29 days ago
I dont think that plunger is available anymore but I could be wrong. You could have somebody spot weld it until you can find one
#5472 29 days ago
Should be. Those are pretty standard, inexpensive parts.
If the tension springs are missing, that's probably a lot of the looseness in your diverters, since they keep tension on the assembly. If that exact spring is not available, it seems like any generally similar size spring would work. The collar on the crank arm in the lower video does look broken though.
yg is probably right about the plunger armature not being available. It would be surprising if that needs to be replaced though. Just clean that up and make sure the plunger ends are smooth when you have it apart. The broken collar on the crank arm might be weldable, but it is now available as a replacement part.
#5473 28 days ago
Hey,
Thanks!!
Another thing. That arm comes very close to that coil but should not touch. Thats why its wrapped in that thick paper. A new arm and coil stops should sort that out.
#5474 27 days ago
Battlefield mod get a little bit polished before black chrome plating.
#5475 27 days ago
Quoted from Twister:
Looks great!
#5476 27 days ago
Absolutely stunning, what the hell was I thinking not ordering one of these...? Sheesh
#5477 27 days ago
I like it judt the way it is.
#5478 27 days ago
Quoted from tiltmonster:
Don’t worry, you can’t order it yet
That pic is the prototype
#5479 27 days ago
looks great, cant wait for when it is completed.
#5480 27 days ago
Quoted from allsportdvd:
I am not sure. I have made 30 pieces, 40 people have interest. I am not sure if I make a second run. It is more complicated with the black chrome plating than expected.
#5481 26 days ago
Anyone sell the Shadow car used as a topper sometimes? Where did this originate? Thanks.
#5482 26 days ago
Quoted from pinballjah:
It’s from the toy line. Look up Shadow Thunder Cab on eBay and they go for $20 - $40.
If someone knows a cool way to make this into a topper let me know.
#5483 26 days ago
As of last Wednesday I'm new to this owners group
Does anybody know what version DA76 is ?
Usually they are L versions
#5484 25 days ago
Looking for the gun launcher to replace the button I have instead. Want add posted too. Thanks!
E
#5485 25 days ago
Just joined the club, managed to rip the side art the first day I installed it .
Cityscape backboard piece was super easy to install tho and the seller was awesome enough to include a backup. If anybody would like a cityscape backboard decal, I will send you my extra one free if you just pay shipping.
#5486 25 days ago
Quoted from ruzeo:
I would keep it. I bought one somewhere and it started to bubble and wrinkle.
#5487 25 days ago
Quoted from yellowghost:
That wasn’t my decal though
#5488 25 days ago
I mean, I am pretty good at destroying decals and side art but I trust it, looks and feels quality. TRANSPRTR4U was first to message me so I am going to send it to him for his shadow. Thanks again jonesjb
#5489 25 days ago
Quoted from ruzeo:
You’re very welcome.
I still have a few other decals left if anyone else is interested in buying:
https://pinside.com/pinball/market/classifieds/ad/73433
#5490 25 days ago
Quoted from jonesjb:
Love mine! Perfect in every way!
#5491 24 days ago
twister The black chrome coating is nice but if it’s giving you difficulties, I would buy one without it. I could get it powder coated or chromed locally.
#5492 22 days ago
Quoted from Nds777:
ME TOO!
#5493 22 days ago
Me three..if my plastic peice becomes damaged
#5494 22 days ago
At the moment, I have a couple parts at the guy who make the coating.
He make samples with black chrome, and he make samples with black glossy powder coating.
When it is done, I have the final price. So I can offer with price for black chrome, black powder and without coating. So everybody from the list can choose.
Sascha
#5495 22 days ago
You are on my interest list on place 4 from this forum. So don´t worry, you are definitely in
#5496 22 days ago
#5497 22 days ago
On my second shadow. I noticed I get a ton of balls jumping off the wireforms on this game. My first I never had the issue. I installed new ramps made by Mantis I believe. On the left ramp it will jump the wireform going right. On the left ramp diverting left it will slam the ring bracket on the ramp and sort of stop, drop in place and then roll down the wireform. The right ramp diverting left will sometimes jump the wireform as well. Anyone have similar experience with the newer ramps? Tempted to weld up the old ones and give them a try. I'm thinking even a slight degree in variance from the originals might be causing this. I noticed when installing the ramp flaps they are super rigid, not sure if that matters? I'm thinking the angle on the ramps are too steep or something.
#5498 22 days ago
Quoted from rotordave:
rd[quoted image][quoted image]
That looks great mate
#5499 21 days ago
Quoted from Djshakes:
I've installed a new left ramp from Mantis, and I did end up having to adjust the wireform, but it was all the way to the right where the end of the wireform ties in. I probably posted about it in this thread somewhere.
Another thing I recommend is installing this
https://www.pinballlife.com/sub-microswitch-with-4-straight-wire-actuator.html
It will help keep the ball aligned a bit more. The original switch there ends up having issues registering, and can sometimes even trap the ball when it barely makes it up the ramp an into the wireform.
#5500 17 days ago
Pick up my second and forever shadow tomorrow so pumped
Only pin I’ve ever missed after it was gone
$ 40.00
$ 129.00
LED OCD
Trade
Machine - For Trade
Trivoli, IL
$ 50.00
$ 29.50
Playfield - Plastics
Bright Lights Pinball
KAHR.US Circuits
4,200
Burnsville, MN
$ 229.99
PinSound
$ 59.00
PCB Emporium
€ 95.00
FlipperLED
$ 159.99
Pin Mods
4,800
Burlington, WI
Gweem's Mods
