(Topic ID: 46571)
The Shadow Club
By marsgnu
7 years ago
  • 7,220 posts
  • 579 Pinsiders participating
  • Latest reply 14 minutes ago by Mad_Dog_Coin_Op
  • Topic is favorited by 205 Pinsiders
There have been 1,975 images uploaded to this topic. (View topic image gallery).
There are 7220 posts in this topic. You are on page 109 of 145.
#5401 1 year ago
The light-up headlights on the repro playfield are awesome!
#5402 1 year ago
I can’t wait for the Shadow Battlefiled apron. Mine is completely broken and off the game. I also can’t wait to see how bad ass it looks in black chrome.
#5403 1 year ago
Quoted from Squeakman:
Me too! It’s the only piece I haven’t been able to replace yet lol
#5404 1 year ago
Looking forward to seeing your finished work
#5405 1 year ago
Quoted from Shadow_E:
I’m restoring my Shadow and am torn between buying a restored playfield or a new reproduction. Any strong feelings or recommendations on either option? Thanks!
E
If you could find a properly restored orginal, go with that. Better than CPR because not only is it good as new, no need to test fit the mechanisms when drilling the holes. Either way, it won't play the same as it did before you swap it.
Good luck finding a restored original.
#5406 1 year ago
Just finished shopping my game out and I can’t figure out where this piece goes. Anyone know? Thanks!
#5407 1 year ago
Behind the left ramp diverter.
#5408 1 year ago
Another question, does anyone’s magnet when it holds the pinball by the sanctum not pull the ball back to lock it. Mine use to work correctly but now after cleaning it the ball just rolls back towards the flippers after the magnet releases it.
#5409 1 year ago
Quoted from pacman11:
I seem to remember mine doing that. I think if the switch in the big wall droptarget is faulty, it causes the magnet to do weird things. Or maybe the opto is bad.
#5410 1 year ago
Check the switch at the bottom of the sanctum wall target. It probably just needs adjusting. Switch should trigger when wall target is down.
#5411 1 year ago
Almost definitely the wall switch. Sanctum was giving me fits until I replaced it and it solved the issue.
#5412 1 year ago
Tell me if you think I'm nuts but planning on modifying my shadow wire form accordingly. Despite extending my switch out further on the wire form and using the long 3 inch actuator on the switch, I still experience the ball jumping the switch. In fact, sometimes the ball is moving so fast it flies off the wire form.
I was thinking about using an old junky wire form to cut out some pieces and extend my wire form where you see the red lines. Was also thinking about relocating the switch from the red box area to the green on the other side of the playfield. Currently I have a zip tie in the yellow box area to help knock down fast balls that are riding high in the wire form and jumping the switch.
I would obviously have to replate my wire form bronze if I weld it up.
This picture isn't of my game btw.
#5413 1 year ago
Quoted from Djshakes:
This picture isn't of my game btw. [quoted image]
I've never heard of anyone needing to go to that extreme before....but for all of that effort, one has to wonder if fabricating a simple spring loaded finger/gate (that would function similarly to the switch in a sense) near where the current switch is to slow down the ball - and relocating the switch further down - would be less effort, but similar effect...
#5414 1 year ago
Alright I looked at the switch and I put the game in test mode and the switch works. Does this switch look right to you guys? That switch was regristing that the wall was down because of the lever that was on it but yet the wall was up not down. Seems like there should be a spring or something holding that lever until wall comes down on it..
During game play magnet catches ball and opts work it switch test mode and wall goes down but the ball releases and rolls back to flippers..
9F4CD7A3-624A-45BF-BA5E-0650EA325134 (resized).jpegC0F80F0B-7145-4323-B438-BEB1E03BC783 (resized).jpeg1C90401F-FC32-4933-A4ED-C6FF442CD7A4 (resized).jpeg
#5415 1 year ago
How did you test the switch? With your finger? If so, then that is not a good test. It needs to trigger when the plastic sanctum wall is down. Manually drop the wall target and see if that triggers the switch. I bet you need to twist the switch counter clockwise a bit and tighten. If it gets loose, the sanctum will push it back and then not trigger. You also want to make sure the swing arm does not trigger the switch - only the wall target.
#5416 1 year ago
Quoted from jawjaw:
Yeah I tested with my hand to make sure it was working. The swing arm is resting on the switch and is triggering the switch and yet the wall is in the up position is that correct???
so the swing arm shouldn't trigger the switch in resting mode? I can probably bend the switch a little and that way it doesn't register it..
I guess I am not understanding how this mech works fully.
#5417 1 year ago
Mine worked in test too, but just was flaky enough that it needed replacement. They don’t last forever.
#5418 1 year ago
Sometimes the bottom of the target cracks and when the arm moves it to the up position it jams it. That isn't the case with you.
Also check for divots in the sanctum that doesn't allow the ball to release and then get pulled back into the sanctum.
#5419 1 year ago
Either way. It a switch problem. The weight of that arm shouldnt be enough to trigger. I would remove that thing and clean it while you are at it. Its pretty filthy
#5420 1 year ago
Quoted from yellowghost:
yeah I am going to definitely do that ..
#5421 1 year ago
Another thing. You have to do tests will the playfield horizontal. Things move differently
when tilted up. So loosen the screw and rotate it slighlty until the switch isnt tiggered and take it from there.
#5422 1 year ago
The swing arm should NOT be triggering the switch. When the pf is down, gravity will bring the swing arm down. If that triggers the switch then the game will think the wall is down when it is up. ONLY the red wall target should activate the switch as it moves down. Go into the menu settings and drop the sanctum wall. Get under the pf and manually move the wall target up and down some without locking it up in switch test mode. Verify the switch is only activating from the wall target and not the swing arm.
The sanctum target mech works off of a couple of coils, an opto, and a switch. The opto tells the game when the ball has crossed the magnet. The small coil will release pin holding wall target so it will drop. The switch at the bottom of the wall target will tell the game when the wall is down (or up if switch not triggered). The other coil will be used to raise the target back up.
#5423 1 year ago
Quoted from jawjaw:
Okay yeah I noticed yesterday that in the normal position when the wall was up in switch test it was activated. Seems like I can just bend the switch a little to make it harder to register somehow. Anyone have a good picture of their switch?
#5424 1 year ago
Anyone looking for a life size knight to go with their Shadow? You can bid on it live on Maxsold near Toronto. I guess it's the largest Shadow mod out there Six and half feet tall!
#5425 1 year ago
Quoted from pinballjah:
That's cool and all, but what does it have to do with the The Shadow? Wouldn't it be a more appropriate mod for MM or BK?
#5426 1 year ago
Quoted from gweempose:
I guess your right, not really a mongol. Just add some Ugg boots
#5427 1 year ago
That's what I was trying to figure out too.
#5428 1 year ago
Well The Shadow does operate under cover of... KNIGHT! Ha!
#5429 1 year ago
Quoted from gunstarhero:
Can't figure out if I want to upvote or downvote this.
#5430 1 year ago
Quoted from Isjack:
FWIW, either way, I deserve it.
#5431 1 year ago
Please help!!
I have a Shadow that only the left flipper worked, so replaced the right opto flipper board, and then the lower right started working, but upper didnt..
Left and right flipper buttons only register one square each in the switch test grid...
I have 13v at the upper flipper board coming from both optos on right side , and when I press button, they drop to 0.. not sure if this is how you test them... any ideas ?
#5432 1 year ago
Not to be redundant but here's a shout out to Aurich and his translate. I've swapped out the LED to an LCD ColorDMD, I know... it's hires but I like it and the colors seem to mesh better with his beautiful artwork!
Thank you!
#5433 1 year ago
Quoted from tiltmonster:
Thank you! [quoted image]
I’ve done the same thing and couldn’t agree more! It looks bloody fantastic
#5434 1 year ago
Looks beautiful with the Color DMD. Nice back board decal too BTW
#5435 1 year ago
Quoted from mobilexx:
Please help!!
Have you tried swapping boards and see if the problem follows a board? Is your interrupter arm broken? You could try manually tripping optos to see if they work correctly.
#5436 1 year ago
Quoted from jonesjb:
lol, thank you!
#5437 1 year ago
Hello guys. Been lurking here for years. My name is Richy. Got my Shadow 15 years ago for my wife for anniversary present. She didn't want a diamond ring just a pinball, imagine that !!!!! Anyway was working good for years then we stopped playing 5 yrs. ago. Decided to resurrect it last month. Had issue with the Sanctum Wall not working. Replaced the entire unit from Marco's and it worked great. Problem is played 2 games, everything worked great but now DMD is blank. All I get is horizontal test line from top to bottom, then power shut down, then test mode again with flippers, lights, solenoids, and horizontal lines in display. Wife says I should have left it alone, at least it worked ! Any ideas ?
#5438 1 year ago
Quoted from CaptainRMF:
Easiest thing to try is resetting the ribbon cables, sometimes that fixes these issues.
#5439 1 year ago
Yup tried that already. Pulled all ribbons and plugs, then plugged them back in and still got same results. Horizontal lines still scrolling down display. will start again in the morning. Thanks.
#5440 1 year ago
Well don't know if this matters but on power up I get a high pitched squeal since I've owned it. After that powers up normal and plays normal. Also I noticed LED 3 on power board is flashing. Manual says it should be normally off. Gonna test the voltage at the DMD pin this morning.
#5441 1 year ago
What does it do in display test mode?
A lot of the older games chirp when you flip the switch on.
#5442 1 year ago
For any lurkers wishing to become a member I just listed a nice Shadow in the market
Archived after 5 days
Sold for $ 3,600
Contributed to Pinside
Shadow, The Archived
Partially shopped/refurbished “Selling a nice 1994 Midway The Shadow pinball machine. Solid cab with a couple of nicks, bright display working perfectly, game plays fast and error free. Removed everything from t...”
2019-03-03
Li, NY
3,600 (Firm)
#5443 1 year ago
Well don't know what I did or which one it was but went back and pulled EVERY ribbon and EVERY plug, blew them out with canned dust remover, plugged them all back in tight, hit the switch and every thing is working perfectly including the DMD. Thank god !!! So decided to play a game with the Wife to make sure it all worked right. Well it worked, she kicked my Butt 1,488,187,110 to my measly 46,343,850. She also made it to Final Battle for the first time but missed out with 4 shots left. I did make Shadow Loop Champ with 3 loops however. Now back to cleaning and polishing the PF. Thanks for the help guys.
#5444 1 year ago
My guess would be a cold solder joint on one of the connectors.
#5445 1 year ago
Quoted from okgrak:
Could be, but those ribbon cables are notorious for causing issues. If the display craps out again, I'd buy a new ribbon cable. Heck, I'd buy one now, just to eliminate a potential issue.
#5446 1 year ago
Hi everyone,
I am currently having my Shadow fully stripped and refurbed to like new, would just like to know what you all would do with the legs, side rails and lock down bar, I cant decide on gloss black or fully chromed.
cheers
Trevor
#5447 1 year ago
Quoted from MANTO1975:
Hi everyone,
cheers
Trevor
Nice to see another Aussie Shadow owner.
Chrome for me, it'll always look great, whereas black may possibly lose it's charm. That said, of all 90's pins, Shadow could definitely pull it off, bringing a more modern look, especially with a ColorDMD.
#5448 1 year ago
Hi everyone,
cheers
Trevor
I’d go with black. It will make the brass in the pin stand out more. Whereas chrome metal may clash with the golden hue and create a banding out of the inner cab walls (brass>black>chrome). Too busy.
#5449 1 year ago
Hi everyone,
cheers
Trevor
Chromed mine......
IMG_0064 (resized).jpgIMG_0065 (resized).jpgIMG_0760~photo (resized).JPGIMG_0791~photo (resized).JPG
#5450 1 year ago
As another Aussie Shadow owner I’d also go with chrome over black, particularly seeing the gun looks so nice chromed up
$ 37.50
$ 11.00
PCB Emporium
5,000 (Firm)
Mt Vernon, IL
KAHR.US Circuits
$ 279.95
Pin Stadium Pinball LEDs
