(Topic ID: 46571)
The Shadow Club
By marsgnu
5 years ago
  • 5,256 posts
  • 487 Pinsiders participating
  • Latest reply 2 hours ago by SeaLawyer
  • Topic is favorited by 163 Pinsiders
There have been 1,388 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 5256 posts in this topic. You are on page 105 of 106.
#5201 13 days ago
Quoted from ccbiggsoo7:
looks like you'll have to take that off and pull out bolt from other side or drill it out, replace new bolt, good to go.
Yeah that's a good idea honestly.
If anyone ever has a kicker issue, make sure to check this point of failure in addition to the spring/optos/coil, it just might be why your sleeve is affecting the travel.
#5202 13 days ago
yellowghost tiesmasc manny65
Thanks for the tips and suggestions, my girlfriend and i were able to unscrew the posts from the board and then put one in put the band around and stretched it and got the other post screwed back in without taking anything else off the playfield. Pain.
I am in need of someone who knows how to fix the driver board. I have the dreaded reset problem(most of the time when someone double flips at same time, but I have also seen the machine on occasion just reset though rare). Can anyone recommend someone I can pay to fix? I would have to ship my board obviously. I do have experience soldering switches etc, but the video's I watched entail more than I would feel comfortable doing at this time.
Thanks as always
#5203 13 days ago
Anyone have either of these two plastics available for purchase?
#5204 13 days ago
Quoted from InfamousDolphin:
First, try reseating all ribbon cables. You don't have to pull them all the way off, just wiggle them loose and the push back on.
#5205 13 days ago
I was able to fix this issue on mine by replacing the Caps and BRs but it's not always that simple or recommended.
If you still want to play in the meantime, these are nice to have on hand and will keep things working.
http://www.kahr.us/daughterboard.html
You're going to get people in two camps on the solution - those that say they shouldn't be used as a permanent fix, and those that say it's ok as it relieves strain. In my experience the product works great and I was able to keep my game running until I had time to fix.
Thanks as always
#5206 13 days ago
I agree. Grind off the stud, drill a hole and install a screw and lock-nut. Doubt that your're going to find one of those. Put a classified ad out. You might get lucky though
#5207 12 days ago
Hey guys, after receiving a number of questions about my Shadow, I had my custom back board artwork professionally printed to a decal.
If anyone is interested, I made a few extras available on a first come first served basis. You can find the decal here: https://pinside.com/pinball/market/classifieds/ad/73433
IMG_9961 (resized).jpgIMG_9968 (resized).jpgIMG_9965 (resized).jpgIMG_9980 (resized).jpg
#5208 12 days ago
Quoted from jonesjb:
I bought one if these from ebay a little while back. It started to bubble a few weeks later. How is yours holding on?
#5209 12 days ago
Quoted from yellowghost:
I haven't had any issues. I had these printed direct (not from eBay).
#5210 11 days ago
My ramp plastics were yellowed and tired, laser cut some in UV blue.
It's obvious with the lights on, but I play in the dark. The effect is there, but much more subtle. Flows well with the blues/purples on the playfield, ever so slight glow from the edge.
Thoughts?
#5211 11 days ago
I think my ring lights are out, does someone sell those little lights anywhere?
#5212 11 days ago
Quoted from pacman11:
I think this is it:
https://www.pinballlife.com/7268-bulbs-sold-individually.html
#5213 11 days ago
I had a picture in here somewhere.. not sure where it is. But I cut open regular ol LED bulb and took the filament out and stuck it in the socket. Works great. Will find a picture
#5214 11 days ago
Quoted from dudah:
Thoughts?
Looks good. Wish I hadn’t just put new clears on my game, lol.
#5215 11 days ago
Put a LED inside.
#5216 11 days ago
Put a LED inside.[quoted image]
That's more or less what I did. To help diffuse the light a bit, I put a couple of layers of wax paper in there, YMMV.
#5217 11 days ago
I never liked the plastics on the ramps so I took them off when I took ownership of the game. It's never been a problem yet but I suppose they are there for a reason.
Quoted from dudah:
Thoughts?
#5218 11 days ago
Quoted from Lamprey:
Good idea
#5219 10 days ago
Wow, great idea.. Someone said pinball resource had them too.
#5221 10 days ago
Are those led?
No, those are the same as OEM.
#5222 9 days ago
My ramps were tarnished. Powdered coated in "prismatic transparent gold" hope they look good in the flesh
20181229_233056 (resized).jpgFB_IMG_1547143998448 (resized).jpgFB_IMG_1547144004939 (resized).jpg
#5223 9 days ago
My ramps were tarnished. Powdered coated in "prismatic transparent gold" hope they look good in the flesh[quoted image][quoted image][quoted image]
Out of curiosity, why did you go powder coat instead of brass plating?
Please post pics of the ramps when they are done. Would like to see how they look!
#5224 9 days ago
Eh? Did not know where I could that done local and I reckon the cost would have been astro-nomical. Get them back tommrow
#5225 8 days ago
I hope that they still fit and the powder coat doesn’t add any thickness to the wire forms when they go into the ramp holes. Has anyone else gotten them powder coated.
#5226 8 days ago
Lots of poeple have powder coated wire forms, I’m sure he won’t have any issues. Worst case he might need to widen the hole a smidge.
#5227 8 days ago
Quoted from gunstarhero:
They fit afterall except for one hole. One thing to learn from my mistake however to make sure you put a screw into any threaded holes. One of the microswitches is threaded into the ramp itself. Cant screw it in now.
One more thing...after the swap,my right diverter binds when I install it on the previous position. If I line up the ball marks on the ramp and diverter, the set screws are digging in very close to the end of the shaft and that e-clip is not touching anything. Anybody else need to set it up this way?
#5228 8 days ago
Has anyone swapped in a CPR playfield for Shadow?
How is it holding up at the Sanctum area?
#5229 8 days ago
Quoted from bballfan:
I will let you know in a few years.
#5230 7 days ago
Help needed.
I forgot that each set of rings has one three pin connector and one two pin connector. I put both two pin connectors on the left and both three pin connectors on the right. Anybody reckon which rings on either side get the three hole connectors?
#5231 7 days ago
Help needed.
The easiest way is to just go into the settings and turn on each light, then you'll know.
#5232 7 days ago
it does, just had a tftc ramp powdercoated, had to peel off powdercoat where it fits into another ramp, just about 1/4" i'll just touch it up with black paint.
#5233 7 days ago
I am happy with them
#5234 4 days ago
I’m getting my Shadow refurbished. Any suggestions on trim color. Im thinking either black nickel or chrome? I would also do the wireforms etc. all the same.
Has anyone ever done or know of an alternate cabinet decal?
Thanks, Brett
#5235 4 days ago
Quoted from brett:
I am still very interested in seeing someones game that chromed the wireforms. I am not a fan of brass and know it does look good with the color scheme of the game.
#5236 3 days ago
Quoted from Squeakman:
I bet a shiny new dime that chrome would look good but can't recall seeing one. Having things chromed ain't cheap..at least where I live
#5237 3 days ago
Quoted from brett:
Thanks, Brett
Are you referring to the lockdown bar, legs, and siderails?
#5238 3 days ago
Yes, along with the wireforms.
#5239 3 days ago
I didn’t know if black nickel would would good everywhere, including the gun.
#5240 3 days ago
I have chrome in four other pins. It looks great.
I thought the Shadow might look great in either chrome or black nickel. Black nickel could looks really good with this theme, along with being totally different.
#5241 3 days ago
Joining the club again next weekend. Excited to be back in. Ts was the longest pin I've owned in past years. I remember all the tricks to fix the design flaws. Look forward to getting it running perfect.
#5242 3 days ago
Quoted from Djshakes:
Which tricks and design flaws are you referring to?
#5243 3 days ago
Quoted from brett:
I think black nickel would indeed look good on the cabinet components (and maybe some internal black side mirrors from Pinball Decals). This would create nice unity.
Just my opinion, but the pin benefits from the gold/brass look of the wireforms. I definitely wouldn't blacken them, it may change the look from a vintage art deco to a more modern 80s comic book look... Just personal preference though.
#5244 3 days ago
I believe I posted in this thread way back. Good luck finding it.
1. Standup mongel targets are known for airballs. Rip off the foam target backing and replace with a piece of flipper rubber. Super glue it on in place of foam. Air balls gone.
2. A weak shot to left ramp diverted right can result in ball getting stuck between wire form and ramp. A strong shot can cause ball to jump over thecswitch and it won't register the shot. Someone created a longer switch blade so the shot registers everytime. However, this doesn't remedy stuck ball. You need to get the switch further down the wire form on the downward sloping side. I cut a small piece of lexan and place it where the switch goes. I then place the switch on the end of the lexan strip further down the wire form. This remedies both problems.
#5245 3 days ago
#5246 3 days ago
Really good point. Thank you for your input.
#5247 2 days ago
Finally in the club!!
#5248 2 days ago
Topper is temporary. Remarkably clean Sanctum...
#5249 2 days ago
Quoted from SeaLawyer:
Welcome!
I have that Sanctum Wall decal too, just never installed it; if you ever have time and it's not too much trouble, would you mind taking a photo of it without the glass on?
#5250 2 days ago
Topper is temporary. Remarkably clean Sanctum... [quoted image]
Looks good
$ 29.50
Playfield - Plastics
Bright Lights Pinball
$ 229.99
$ 59.00
