New! Dark mode!
(Topic ID: 243565)
The score reels are contacting the backglass
By Silverstreak02
1 year ago
  • 11 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by dasvis
#1 1 year ago
How do I prevent the score reels from contacting the backglass on my 66 Cross Town. I have a BG Resto glass coming tomorrow and I don’t want to mess it up. This is what happened to the original glass.
#2 1 year ago
I keep editing-
Based upon the pic I dont see any damage corresponding to what I was expecting based on the title. Are you sure there is contact? I would have expected significant serious damage of a score reel was actually hitting the glass. Also- I dont even know how that would happen without something being seriously wrong.
#3 1 year ago
The small dots between the reels are from paint lose. When the reels are inserted in the plastic holders they can be pushed in far enough to contact the glass with tabs connected to the reel mechanism.
#4 1 year ago
Quoted from Silverstreak02:
To state an obvious solution... put something like felt on the tips that contact the glass
#5 1 year ago
Are the slots the reels slide into in good shape? Using the clips to secure them so they don't go in too far?
#6 1 year ago
So its the metal bracket assembly that holds the reel thats causing the damage not the actual reel?
#7 1 year ago
Quoted from rufessor:
Yes
#8 1 year ago
The bracket tips do touch the glass in those games I believe. Pretty sure my 65 Bank a Ball does
#9 1 year ago
My CT will do the same. If clips are used top and bottom on each reel you should be OK.
Putting felt on the tips would be a good precaution.
The new backglass will put the finishing touch on an awesome restoration.
#10 1 year ago
Just make sure that the reel metal tips cannot touch the glass by fitting the correct spring clips that hold the unit in the plastic slide retainers and make sure the glass is not loose and moving about.
I'm fairly sure the bgresto glasses have a hard coating on the back ( My Apollo has it) so should be stable enough but I wouldn't use felt or anything absorbent in case the glass gets mullered; many original GTB glasses that had factory fitted felt strips absorbed moisture and discoloured the glass and sometimes worse, make the artwork lift off.
#11 1 year ago
I use the fuzzy side of self adhesive velcro strips to space it back a bit. Much better than the paint removing factory Gottleib foam.
$ 7.00
APB Enterprises
$ 10.95
Apparel - Unisex
Pinball Wheezer
$ 39.95
$ 48.00
$ 25.50
CzTV Mods
$ 5,899.99
Music City Pinball
$ 7.50
$ 1,099.00
$ 48.00
Arcade Upkeep
$ 115.00
Cabinet Parts
Merf's Pins
$ 76.95
$ 3.50
Various Other Swag
$ 7,395.00
Great American Pinball
$ 48.00
$ 209.99
PinballBulbs
$ 26.50
$ 999.00
Metal-Mods
$ 69.99
$ 125.00
Sparky Pinball
$ 1,248.00
$ 29.99
Bent Mods
