New! Dark mode!
(Topic ID: 225862)
The reanimation of Gen. Yagov - An F-14 Tomcat restoration
By cletus
2 years ago
  • 250 posts
  • 31 Pinsiders participating
  • Latest reply 5 months ago by Clnilsen
  • Topic is favorited by 33 Pinsiders
There have been 168 images uploaded to this topic. (View topic image gallery).
There are 250 posts in this topic. You are on page 4 of 5.
#151 1 year ago
87CCFE7A-4F85-4B51-A256-2758BBDD796B.jpeg2FFA954A-4434-4CB3-9139-EB7593721CD5.jpegAA468B7A-2C91-4EBD-AB00-9B77DCA0C5E8.jpeg2F69ECDD-B0BA-498C-90ED-9770A575B2A1.jpeg8552F4C9-4C35-4119-B195-67F876F9D7AB.jpeg
#152 1 year ago
Quoted from cletus:
The only issue I have now is the match sound number 15 doesn't play. I'm not sure where to start looking on that one.
Start by checking ohms from pin 1 to the rest of the pins on SRC1 and SRC3, should be @ 4.7 k ohms. Pin one is marked be a dot on the board.
#153 1 year ago
Thanks! grumpy. I’ll look at that and reply.
Here’s some more pictures with everything installed on the completed and powered playfield.
0722887A-0649-459A-BAB2-8BA4FF47BE5A.jpeg0A9CE5A9-CFD1-4FE8-80FA-3561F1DE8461.jpeg1DA2E5A3-B641-4BB4-9A12-62AAF8E89226.jpeg8589BFDE-8CD2-4598-AAA3-9C48D035B4A3.jpeg9956A691-B903-4A6C-873F-E39DB4BE2BD7.jpegC0D123FB-32CA-428A-AD1F-368329632450.jpegEC87BBF5-6C88-48BF-A8A2-3E91C2AAB66A.jpeg
#154 1 year ago
Wow looks amazing, are the mirrored back panels available?
#155 1 year ago
Quoted from cletus:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Man oh Man @cletus14 that game is gorgeous. You have done one hell of a job. I especially like the new target faces and matching post rubber on each side. Bravo
#156 1 year ago
Quoted from DKong:
I'm going to make a second set for the newer machines with the circuit board back panel connectors. There are two more holes for the board mounting screws that I didn't design for in the original batch. I'll contact you when I send out the order for laser cutting.
#157 1 year ago
Quoted from GRUMPY:
SRC1 - Pins 2, 3 and 8 show 2.01-2.58 k ohms. The rest show 4.67 k ohms.
SRC3 - shows 2.3 k ohms down the line.
I forgot to mention. There is never and has never been a startup tone on this machine
#158 1 year ago
Looks so amazing!
#159 1 year ago
I installed an LED OCD board and It really classes up the controlled lamp look.
Super easy to install and highly recommended if you’re going full LED.
http://ledocd.com/cart/index.php?main_page=product_info&cPath=1&products_id=23
9077457B-9750-463E-9B15-21BB0B11C1AF (resized).jpegFEA6C871-F286-433B-861F-3A361AEB04B1 (resized).jpeg
#160 1 year ago
Quoted from cletus:
Thank you much appreciated.
#161 1 year ago
#162 1 year ago
Oh man! Your killing me!
Great job! Love it!
#163 1 year ago
My wife says she doesn’t see a difference...
00877A1B-0C5D-438C-A8D9-622237FB978F.jpeg70406F65-D67B-4195-86BA-8C20840E5311.jpegC368653F-994B-4DA6-8AE2-1CC02C7C1C30.jpeg
#164 1 year ago
I don’t think they ever really understand!
#165 1 year ago
That is an impressive improvement!
#166 1 year ago
Quoted from cletus:
I don't know why she can't see you added some spot lights.
#167 1 year ago
That doesn’t go there!
#168 1 year ago
I had to rewire the flasher socket next to the Yagov kicker. Those LEDs flashlamps don’t like it when the wires are backwards.
#169 1 year ago
The SRC resistor network parts are on order and should be here this week.
Hopefully, replacing them gets me a step closer to fully working sounds.
#170 1 year ago
My SRC resistor network parts came in so I pulled the MPU and rechecked each of the SRCs. A few of the pins had high ohm readings so I pulled U41 and U42 and checked them again. All of the ohm readings on every SRC checked out. I continued to verify the sound circuitry to the prints with my meter and everything looks great. I put everything back together and the booted up with a U42 error and a memprot. error. It rebooted a few times then it booted without error. There was still a missing sound at #15.
I pulled the soundboard and checked that as well, but I remembered that I replaced the original board when I first bought the machine because the sound wasn't working. The original board looked hacked with some resistors on the back. I dug it out of a box and figured It couldn't hurt to try installing it now that I pretty much ruled out the MPU and...
It worked. All of the #$%#&%* sounds work!!!
Now I know it's on the background soundboard somewhere and I can stop pulling out the MPU. I completely rebuilt the soundboard that doesn't work, so it's most likely something I did. The original board produces a little more buzz, but it also works 100% so I'm not complaining. I'll order some more capacitors and at least get that much of the old board rebuilt.
There are a couple of sounds (the fly-by sound when you launch and orbit and the match explosions) that didn't work before. It's like a new new game now!!!
#171 1 year ago
It only took me one retry to get a game that lasted over 2 minutes.
#172 1 year ago
"Daddy are you playing?"
#173 1 year ago
Quoted from Waderade812:
Yeah, that little turd interrupts every game I play.
The first thing he wants to do every morning is go play pinball. Just like his daddy!
#174 1 year ago
Here’s a little fun. I switched out the balls for a set of Glo-balls. These are a couple of grams lighter and make for some pretty crazy ball action. It was impossible for me to get three balls locked. I could barely keep track of the ball.
Edit: Here’s the link - http://shop.modmypin.com/
#175 1 year ago
Amazing work! Add me to your list of back mirror peeps! I’d love one for my
Early model as well
#176 1 year ago
Quoted from cletus:
You better set it for a five ball game so you have a chance. Looks like a blast
#177 1 year ago
Dam Cletus pin looks dialed in. Also gave me more stuff to look into ><. Wonder how the glow balls would do if you did some uv in some select spots. maybe like a uv back light for flippers so every time they come down they get recharged
#178 1 year ago
I had lighted flipper buttons in red, but I thought I’d customize it a little more. Now my #F-14 Tomcat has port and starboard lights.
I thought about putting a Stern sticker on the coin door, but that’d just be wrong.
07BC8978-864C-44EA-A448-E490F2CE3BED (resized).jpeg099C402F-7D6B-47CB-8AF9-D4F2B7524984 (resized).jpeg64E097B9-D934-4411-9CD2-C65254197289 (resized).jpeg
#179 1 year ago
Thats one sexy mod that I would have never thought of. Now if you away for too long and you coming home you can see from a distance if someone turned your machine around.
#180 1 year ago
Quoted from GnarLee:
Right?!?!
It's still weird to me that the front of the machine is the back of the plane, but I'm piloting this bird so I wanted them to my perspective. I'm trying to get ahead of any discussion about what is port and what is starboard on a pinball machine before it starts.
#181 1 year ago
@cletus14 look at that reflection in the siderails...Sweeeeeeeeeet!
#182 1 year ago
Quoted from cletus:
Red, Right, Return... should hold true for aviation and ocean navigation. If the red is on the right, he's coming at ya.
I always get confused when I see that damn trip advisor owl!
#183 1 year ago
I’ve been trying to tune everything as perfectly as possible. My right center eject occasionally shoots directly at the post instead of directly into the orbit, and I’m finding it difficult to tune this shot in just right.
Too much adjustment to the right, and the ball rattles slowly around the orbit. Too much to the left, and the ball nails the post. I’m thinking that I’ll just need to move the post a little.
I’m hauling this out to PATZ 2019 this week so I want to make sure everyone walks away from it equally defeated.
#184 1 year ago
That machine is absolutely gorgeous. Nice work!!!
#185 1 year ago
Damn you.
You think you want a game, then you come into a thread like this and you GOTTA HAVE IT NOW.
What a beautiful restore, well done. I hope I can get one half that nice.
#186 1 year ago
Quoted from Chitownpinball:
Damn you.
The fun is in making it that nice.
#187 1 year ago
Sittin’ pretty at PATZ 2019.
If you’re close, come out get humiliated.
#188 1 year ago
Stick a 2x4 under the rear legs. Just for intimidation. When you get back home "upgrade" the rear legs to 31"
#189 1 year ago
Quoted from cletus:
Very cool of you to share it with others after all that fantastic work you put into it!
#190 1 year ago
Stunning! That's some real dedication
#191 1 year ago
My beacons apparently didn’t like the ride in the van. I’ll have to debug that one tomorrow morning.
Also, I have the sound turned down as much as possible and I can still hear that subwoofer over all of the other games. Oops.
#192 1 year ago
Pretty cool to have Keith Elwin stop over to play a game on the Tomcat.
#193 1 year ago
For a second there, I thought that was a for sale sign.
#194 1 year ago
Quoted from heni1977:
NEVER!!!
That’s actually a very clear (circled many times) NOT FOR SALE sign.
It’s been holding up very well to all of the play it’s getting. Today’s full-house Saturday play will be a different story.
#195 1 year ago
I won best in show at PATZ! Awesome!
#196 1 year ago
Congratulations, You earned it
#197 1 year ago
Now you are definitely one of the cool guys with that plaque.
Playball!!!
#198 1 year ago
Awesome ! Congratulations!
#199 1 year ago
Thanks guys!
Over three days and 25 hours of public play it held up very well. 376 games in total.
On the very last game before I packed it up the lower right flipper stopped flipping. A little nudge would help it get there. I cleaned the EOS contact and she’s good as new.
The aftermarket translucent flipper bats did not fare so well. That lower right flipper bat is only held together by the rubber.
Every single flipper bat has stress cracks in that same place.
#200 1 year ago
Plastic is too brittle, but looks are more important. Buy some new ones.
$ 15.75
Cabinet Parts
Tilted Pinball
2,300
Williamsport, PA
1,800 (Firm)
Melbourne, FL
$ 50.00
$ 54.99
$ 54.99
$ 39.99
$ 85.95
$ 9.00
