Quoted from Vespula:Thanks foo. Just to make sure I'm understanding you right I did go into the EQ settings to try and troubleshoot this and thought I just set to none as the default So all the frequencies were flat at zero. . It didn't make any difference. Is there another reset that you're talking about? Or are you saying that what I did was good but only half of it and that I have to actually set the EQ like yours with the mid-range dip to compensate for this issue? Thanks
I set the custom to 0 manually (flat) then adjusted the midrange to a scooped pattern (as I currently have set) I did have to take the Bass and Treble high and low ends way back as they seemed to blow out and muddy the sound effects (very weird) from what I had set previously. So I guess the latest beta boosted the top and low ends a bit
