Pinwoofer Review:
I ended up ordering pinwoofer around 2 months ago, then installed it. But that was around the same weekend that the audio equalizer was added to the beta code.
Install went well, the new pinwoofer product was a noticeably better install than the older versions I had ordered ~2 years ago. Not that the prior versions were bad, just the improvements to the product were noticeable and appreciated!
The only quirk I ran into was when I unplugged the game audio board's power (I can't remember the specific name) the game would not boot. I think that was a recommended step as that board was no longer needing to be powered, as the audio power was now coming from the pinwoofer unit. All I know is when I unplugged that board, the game would not fully boot (it got stuck in some sort of boot loop). When I plugged the audio board it back in, things were okay. It could have been some other power part was jostled and it got jostled back when I "fixed" this. Could have just been coincidental. I did not try unplugging the stock audio board again to replicate the issue (at the time, I was just happy to get things working!). Now, I have the curiousity . Mentioning this on the off chance somebody else runs into this.
My initial take was great, this is working, time to tune it! I opted not to remove the stock speaker grill as I thought, the rattling would not be noticeable with the sound level I was intending to use it at. But in tuning, some lower frequencies were super obnoxious (something was rattling, and not in a good way).
So, I decided to remove the cabinet speaker grill- no appreciable change unfortunately. I then tried to see what else could be rattling. Cable bundles in the cabinet? Backglass? Coin door? I added some foam I had in the backglass and coin door to stop them from vibrating, and things improved a small amount.
BUT the main culprit ended up being the plastic channel that holds the top of the playfield glass. I ended up using some drop target foam I had on the top of the playfield glass (you can't see it when the glass is installed) and after adding enough pieces (4-5 or so across the top back of the playfield glass) I finally tamed the Rattle Beast.
So now I can just enjoy badass sound. I still need to probably do a bit of tweaking, but it sounds "right" to me now that low frequencies are not making things sound like the game is about to explode.
So is the pinwoofer awesome? Sure! I feel I spend a lot more time tracking down what was causing vibrations than I expected (I did not have to do that with my prior pinwoofer installs). Could be luck of the draw on the playfield glass back channel I have, different sound mixes (less bass maybe) on my prior JJP games, just my personal preferences when setting up the pinwoofer.
Posting this mainly in case you take the plunge, do the install, and then feel you have to dial it back due to some crazy audio related vibrations... if you work at it you can probably figure it out (before doing that make sure you don't have the bass set to absurd levels... but if things seem reasonable and you are getting a crazy rattle, hopefully this information helps).
