Quoted from shovelhed:To help others in the future, easiest way to install the art blades is
1. Get a second pair of hands (Partner)
2. Have Partner slide playfield almost completely out, holding the playfield straight.
3. Starting from the back to the front attach 4 to 5 clamps to the side rails along with the art. From the back carefully remove a clamp and backing of art. Line up with hinge bolt and smooth out any bubbles. Rinse and repeat until its installed, then do the opposite side in the same manner. Here’s a reference pic of the clamps. Hope this helps
Harley D.
That's a good tip regarding the playfield. I did the same thing. Thanks to the crazy long slide rails, the playfield can be slid way out until it is essentially resting on the front of the machine. Have a partner hold the playfield horizontal so the rear of the playfield is completely up and out of the way. No wires need to be disconnected.
