(Topic ID: 278791)
The Official JJP GnR Owners Thread
By Dallas_Pin
  • 28,410 posts
  • 1,067 Pinsiders participating
  • Latest reply 23 hours ago by PinMonk
  • Topic is favorited by 473 Pinsiders
Topic poll
“Which one are you buying”
  • CE 188 votes
    17%
  • LE 634 votes
    57%
  • SE 77 votes
    7%
  • None 218 votes
    20%
(1117 votes)
78 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 28,410 posts in this topic. You are on page 297 of 569.
#14801 2 years ago
Quoted from Jackrabbt:
The Good, The Bad, The Ugly
Good - May playfield, 163 games played.
First, Kudos to PinMonk. Your air ball mod is great. It blends perfectly, looks great and its easy to install. A real no-brainer.
Bad - Semi-kudos to JJP. It looks like they are trying different things to mitigate the playfield issues though they are not there yet. The first three pics are of the typical problem areas though I am not seeing any damage yet.
Ugly - When I removed the plastic to install the air ball mod, I found my first pooling issue
Why Jersey Jack did not put any protection under this post is a mystery. It does take direct hits.
Its kind of like finding that first scratch on your new car.
PETG washers on order.
Good job pinmonk. Is the yellow paint edge around the washer in your picture also starting to pool? Can it also be replaced with PETG?
#14802 2 years ago
What about this from Pinballlife?
69ACBDF6-1327-4CFD-A206-EECD526746B5 (resized).jpeg69ACBDF6-1327-4CFD-A206-EECD526746B5 (resized).jpeg
#14803 2 years ago
Thanks. Sucked with all the different flavors I convinced myself I needed to make and test after I took over from cybevenom before I got to the 3mm one that worked best, but it did turn out nice. Karl from iepinball was also patiently helpful trying some of them out in testing, too.
Also, good to note that pinball life is also carrying this GnR airball shield now, so if someone is already doing an order for something else from them, they can save on shipping if the airball shield by itself was the main shopping want from me. If you get the GnR Tibetan Breeze and the shield from pinmonk.com, domestic shipping is free anyway.
I would absolutely get the vinyl iron repair kit and using yelobird's method and smooth that out while you can before you cover it up (ideally mylar, then PETG). It will harden it a bit, too.
#14804 2 years ago
Sorry, that pooling sucks. I'm convinced all machines have it to varying degrees and if you don't take efforts it will catch up to you eventually. Good luck.
#14805 2 years ago
Quoted from Beez:
These I actually bought before getting my GnR with the expectation that I would have to replace the ones on the playfield. Unfortunately, the post in this hole has threads on top as well as on bottom. It's one of the supports for the long plastic.
#14806 2 years ago
Quoted from Vespula:
It does look like it is starting there too. Maybe I just need to schedule monthly playfield repair sessions with my GnR.
#14807 2 years ago
A couple Rule ideas (in case Keefer is bored and awake )
• if you beat an album mode, and start another one right after (without draining); all scores will be doubled during the second album mode. If you beat that and start a third (without draining), it’ll be worth triple scoring. If you beat that and start the 4th and final album mode (without draining) it’ll be worth quintuple scoring.
• Tour multiball: scoring increases based on # of balls in play.
#14808 2 years ago
Have had my game set up now for little over a week and it keeps getting better and better especially as I dial it in. I almost got it playing like I want now. Got scoop ajusted so it goes to left flipper . Also my left orbit exit was hitting top of sling sometimes and it was annoying me. So I took things apart last night on the left side and ajusted the guide rail and while I was under there I added some thin silicone washers under some posts that didn't have any but was happy to c everything looked good anyhow. ....also my left orbit exit goes to my left flipper almost every time now which is nice. Game is amazing .. super fast , flowy ,adrenaline rush and the light shows are far beyond anything else ever made. Can't wait to actually learn the rules somewhat...
#14809 2 years ago
Quoted from Beez:
Its good, just need to add 3 x t nuts for the 3 x oversized holes up top, great idea from cooked71.
Edit: this problem may be corrected on newer playfields ?
All posts, especially at high impact locations should be locked in tightly ie. Tight hole for post.
Never over torqued though.
Screenshot_20210827-212044_Chrome (resized).jpgScreenshot_20210827-212044_Chrome (resized).jpgScreenshot_20210911-154901_Chrome (resized).jpgScreenshot_20210911-154901_Chrome (resized).jpg
#14810 2 years ago
Scoop not registering as it should.
After adjusting the scoop switch to protrude higher through the hole to make contact with the ball, worked better for a while.
Now getting a 50% hit rate.
Kinda spoils the game experience to a degree.
Has anyone found a good fix for this?
#14811 2 years ago
Quoted from Sako-TRG:
If adjusting the switch arm doesn't fix it, try adjusting the angle of the body by loosening the screw holding it and rotating it a bit, then tighten securely.
If that doesn't help, you may have a bad switch with an intermittent connection internally. Someone else had the same issue and adjustments couldn't completely help. They replaced the switch and the issue went away - the switch was going bad.
#14813 2 years ago
^^^^ Thanks guys ^^^^^
#14814 2 years ago
Quoted from PinMonk:
What chip is on the bluetooth board with the headphone jack? If there's writing in it, we an figure out what bluetooth it supports. I doubt it supports bluetooth 5, so the airpods are slumming it with compatibility mode on early bluetooths.
CSR 4.0. Has anyone tried using a 5.0 bluetooth USB adapter?
#14815 2 years ago
Quoted from cooked71:
Here’s the Marco link:
https://www.marcospecialties.com/pinball-parts/4410-01118-00
Weird thing is the description said 7/16 barrel height, but there’s a 2nd pic in the listing that sais 9/32 barrel height.
The ones I received are definitely 7/16.
And apparently PSPA sell them here according to the description:
https://www.pinballspareparts.com.au/4410-01118-00.html
But for either supplier you better check with them what the actual height of the barrel is as apparently some are being sent with short barrels.
Hi Mark,
Also found these with six prong and again just shy of pf depth, base seems slightly wider than macro tee nuts and found the six prong holds better.
Been using six prong in my carpentry/joinery trade for years for better stability on table legs.
https://www.amazon.com.au/10-32-Deluxe-6-Prong-T-Nuts-Pcs/dp/B0002ZPEU4/ref=sr_1_1?dchild=1&keywords=%2310-32+Deluxe+6-Prong+T-Nuts+50+Pcs.&qid=1631366452&s=home-improvement&sr=1-1
Cheers
#14816 2 years ago
Just wanted to give a quick shoutout to Damonator for all his help in getting my apron monitor setup up and running! I had a few install issues and he helped to troubleshoot late on a Friday and several email exchanges before then. Many thanks, I’m digging the new addition!
B819283A-8CF6-4AC0-BF15-E17FA900E4A9 (resized).jpegB819283A-8CF6-4AC0-BF15-E17FA900E4A9 (resized).jpeg
#14817 2 years ago
Quoted from TakeOff:
Yes, I have done it. If I remember correctly, I have bent the center spinner assembly slightly to the left. You do no not have disasseble anything.
This also worked for me, did it a few months back.
#14818 2 years ago
Quoted from Mahoneyj:
If you order the JJP Art Blades they supposedly come with slide plastic protectors for lifting the playfield. Have not seen them in person yet but I hope to receive my JJP Art Blades in a few weeks.
They come with the CE. They work great. Just a sheet of durable but thin plastic in the shape of the side art with overhangs so they hang over the cabinet rails. Mine fit tight on one side but that could just be how my playfield sits.
#14819 2 years ago
Quoted from GnFnR:
It’s getting stuck in that Lower right bumper. What about what i said will that fuck it up picking it up and slamming it down ?
As PinMonk said, a small piece of something at the right edge of that bumper skirt will prevent the problem and is pretty much unseen. I posted a while back about a felt furniture leg dot cut in half at the edge of the skirt has worked great. Black so it’s nit noticeable. Doesn’t interfere with bumper or play and haven’t had a hang up since. Kudos to the OP who had the idea
Edit: it was @flooflighter
https://pinside.com/pinball/forum/topic/the-official-jjp-gnr-thread/page/178#post-6253643
#14820 2 years ago
Started to see some post pooling on my GNR CE. Barry never got back to me and need to take care of this before it gets worse. Is Cliffy the way to go and if so do you recommend the entire protector set from him?
#14821 2 years ago
So I was playing today and the game went crazy and I thought something happened to it.... luckily it was a mode called shall we play a game. Super cool start to a mode ...to bad I had no clue what was going on lol... till next time
#14822 2 years ago
Quoted from fastchef:
https://pinside.com/pinball/forum/topic/the-official-jjp-gnr-thread/page/226#post-6338289
Cliffies are great. Post above is helpful in regards to post pooling fixing, prevention and adding PETG washers.
If you need specific help, some pictures might help everyone offer more specific advice.
#14823 2 years ago
Yes, but if the pooling hasn't chipped yet, I would definitely smooth it back out using yelobird's vinyl repair iron method first, let it cool, and protect it then. The vinyl iron heating and cool off seems to harden it a bit more, enhancing the protective effect of the carbon fiber discs (or mylar, or petg discs).
If it's already chipping, then the iron won't really help, so it's critical to smooth it while it's just pooled before it chips.
#14824 2 years ago
Quoted from bigd1979:
Yeh it’s scary first time it happens. Like game is rebooting. It’s one of the album modes (chines democracy) after you compete 3 minutes of a song from that album- then start SWPAG at scoop.
#14825 2 years ago
Quoted from Eskaybee:
//<![CDATA[
window.__mirage2 = {petok:"8902d12fa80887ae624eca652580f4a4ae955aeb-1631391831-1800"};
1. I will never be good enough to do this.
2. Your mutliball is only 2 balls on my SE. Is it more on the ce/le only bc of the ball locks?
Super exclusive ad from the Pinside Marketplace!
#14826 2 years ago
Hahahah. I love seeing these posts! I did the same thing and posted about it.
Someone mentioned they need to code in to take a picture when it starts!
#14827 2 years ago
Quoted from Ecw0930:
Or a succession of pictures 5 seconds apart (or 3 seconds, or whatever covers the intro to the mode so you get the range of reaction). Would be funny.
Make an attract mode screen with the DYWTPAG highest score that shows the photo succession at the start of the mode for the lowest scored one (which would probably be the first-timer with the funniest picture succession). So you get the best score and the likely best photo succession. Or maybe save 5 or 10 photo successions and rotate them on that screen. For locations, especially, that succession would be comedy gold. Watching players discover a new game's modes is hilarious.
@pinball_keefer, please?
Here's a gif of a couple players discovering for the first time that Dialed In was taking pictures of them in the selfie mode on our location security cam...
#14828 2 years ago
Or a succession of pictures 5 seconds apart. Would be funny.
Yes! Then show them after the game... And if you get champ it shows those on the scroll!
Great idea!
#14829 2 years ago
I used a hair dryer and a credit card. Not sure if buying the iron it really worth it or necessary.
#14830 2 years ago
More foolproof since the heat and the flat surface are all-in-one. But sure, you can do it with a hairdryer and a credit card, too.
#14831 2 years ago
Just be careful with the iron - it gets hotter and hotter the longer it's plugged in, and if you hit the playfield with TOO much heat the clear will lift/crack.
#14832 2 years ago
Quoted from zaphX:
Good advice. When I did jjPotC's sling posts I was touching the area lightly as I ironed it to make sure it wasn't getting too hot. Barely got past warm.
#14833 2 years ago
Well I got the JJP topper yesterday. Here's my opinion:
Pros:
1) It's very thick acrylic. About 1/4 inch.
2) It's over-built. No double sided or felt tape holding it on the backbox. Held on by a big metal bracket.
3) All the holes are already pre-drilled in the top of the backbox. No drilling required.
4) It's simple.
5) It's only $ 199.00.
6) It's made as an option by JJP for the SE/LE. No need to take it off if selling it.
7) It looks good.
Cons:
1) No color changing options available. Only cool white.
2) It's simple. If you want more wait for Lior's 2 topper options.
Is it worth it? A big yes!
GNR Topper 1 (resized).jpgGNR Topper 1 (resized).jpgGNR Topper 2 (resized).jpgGNR Topper 2 (resized).jpg
#14834 2 years ago
That’s a nice topper!
#14835 2 years ago
Quoted from romulusx:
Essentially the same type of topper was free on jjPotC LE. Included with every one. If they're gonna charge for it, they need to do a better job. Even a diorama with a few pieces of acrylic would have been better and would give a 3D effect.
#14836 2 years ago
My Hobbit didn't include a topper for $8500 back in 2016. Your fans weren't an option on PoC. But I do like your product.
#14837 2 years ago
I can't believe it, I am still waiting on mine to deliver. I ordered in Oct of last year...
#14838 2 years ago
Quoted from JLebowski:
Hang in there. There's a great many waiting with you... They appear to be working on the second half of October at least if you ordered JJP direct.
#14839 2 years ago
Yep mine was a Oct 26 direct order.. got it week or so ago... well worth the wait. Also all the fixes were allready done and the playfield is holding up well so far...
#14840 2 years ago
Quoted from moat-pin:
I'm sure I had a very concerned look on my face lol and wld be great if it took some pictures at the mode start.... very impressed so far with all the neat modes in this pin and I still have many to c..
#14841 2 years ago
I know I’ve seen it here but I can’t find it now. What do I do to stop the ball from getting stuck at the top of the drumstick. I just looked at index post I don’t see it.
#14842 2 years ago
Quoted from GnFnR:
You need to make sure you've clicked "show all" and also are sorting by keypost summary so all the tech stuff in this thread is grouped together.
These three should be of interest:
TECH: PLAYFIELD. Drumstick mylar fix Posted by Damonator
TECH: PLAYFIELD. Drumstick mylar interferes with right orbit gate Posted by fooflighter
TECH: PLAYFIELD. Drumstick to gate transition ball trap fix. Posted by PeterG
#14843 2 years ago
I officially suck at scoring. My average game is probably 1.7 million. Average start song value maybe 60. I still haven’t figured out what I need to do to hit the make some noise shot “under” the upper right flipper. That just feels like a lost cause.
Fun as hell but I suck. Highest score is I think 37 million next highest score is 18m and this is like 285 plays in….
Still don’t know what good say a lights patch does in a song mode or even a builder multiball….
Mostly venting but curious what you think of the make some noise shot and also your typical scores. Feels like I’m killing it in a song and maybe my jackpot is up to 3.5m. Big woop….
#14844 2 years ago
Quoted from sanantoniopinhea:
Pros:
4) It's simple.
7) It looks good.
Cons:
Plus… custom box!
DAACAA4D-B227-4A23-A401-72A9D1C289A4 (resized).jpegDAACAA4D-B227-4A23-A401-72A9D1C289A4 (resized).jpeg
#14845 2 years ago
Quoted from holminone:
Just under 10 million is my best so far ,played so hard almost needed a nap . I believe make some noise to activates from upper playfield, I could be wrong. have fun!
#14846 2 years ago
I’m right there with you man. I feel like I’m getting better but the scores aren’t reflecting it… yet. My GC score is like 22 mil. The other day I got a song value up to my personal best of like 95, even played the song pretty well, and came away with 8 million. The thing is stingy!
I have only been able to start make some noise on accident except once when I had a bouncing ball above the right flipper and was able to backhand it home. Felt great but it’s a pretty out-of-control way to make it happen. Hopefully some angle genius will chime in and tell us how to get it going on the regular…
#14847 2 years ago
Quoted from Cayenne:
there is an effective and simple solution.
The 3D Print from agima2000 works perfectly at this point.
A rubber is then also no longer needed, which only has an additional edge where the ball stops.
https://www.thingiverse.com/thing:4835017[quoted image]
the more simple solution is to add more sensitivity on bumper switch!
#14848 2 years ago
Quoted from Thot:
i tried, too often the ball runs slowly btw bumper and metal railing and stops. The simple and cheap agima solution works fine.
#14849 2 years ago
Ok sound experts: bought the Pinwoofer upgrade kit for my CE. It comes with an “upgraded” 8” sub. But I’m not sure it’s an upgrade - my installed stock one is a Pyramid 300w WX85X:
DAD30C56-A976-4151-9B7B-AD2CAFD3ADAB (resized).jpegDAD30C56-A976-4151-9B7B-AD2CAFD3ADAB (resized).jpeg
And the upgrade Pinwoofer one is the Goldwood GW8024:
C6550F0B-BA1A-4216-A3A5-6BEFBE2F0017 (resized).jpegC6550F0B-BA1A-4216-A3A5-6BEFBE2F0017 (resized).jpeg
From my brief internet search, it looks like the stock Pyramid one may be better - pretty much same specs but a beefier magnet.
I can understand replacing the stock Wonka no name ones in the videos (may also be on the GNR le), but I’m not sure it’s worth it on this.
Anyone know more about these speakers?
#14850 2 years ago
The Pyramid is a cheap speaker, nothing to write home about, and you can't compare spec sheets because exaggeration is the order of the day in that price range from China.
Just a quick look at the amazon reviews for both has only 38% 5 star/23% 3 star on the Pyramid and 64% five star/12% 3 star on the Goldwood.
Plus the goldwood is what came with the kit, so they know the sound they want to give you. I'd go with what they gave you.
Playfield - Plastics
Pin Monk
8,249 (OBO)
Temple, TX
The MOD Couple
$ 130.00
Dijohn
$ 210.00
$ 14.95
€ 42.00
PPmods
$ 11,000.00
8,000 (OBO)
Crestview, FL
$ 28.00
The MOD Couple
$ 124.50
The MOD Couple
$ 427.00
PinWoofer
$ 50.00
Duke Pinball
$ 19.95
Pin Monk
$ 649.95
Pin Stadium Pinball Mods
$ 109.00
The MOD Couple
11,999 (OBO)
Dracut, MA
$ 11,000.00
Classic Game Rooms
$ 29.00
The MOD Couple
$ 10,200.00
The Pinball Place
$ 130.00
Pin Monk
$ 8.00
Side Gig Studios
This page was printed from https://pinside.com/pinball/forum/topic/the-official-jjp-gnr-thread/page/297 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
