Quoted from lpgnr:No The decal itself is coming unstuck on the right side, all over the place, but primarily near the flipper button. I guess I am the only lucky person this is happening to.
I had this happen, granted it wasn't as dramatic as yours looks but here's what I did:
I'm calling this the Guitar Pick Fix
1. Lift the playfield fully
2. Unscrew the nut retainer screw for the flipper button
3. Using a pair of needlenose, unscrew the nut holding the flipper button and keep it from rotating in your hand
4. Using a hairdryer, apply moderate heat for a couple minutes at about 8 to 10 inches, not too hot, still able to touch the decal without burning your finger...we only want to soften things up to make them pliable.
5. Now using a Guitar Pick (I just happen to have my favorite 1.14mm dunlop lying nearby - and it is just the right abount of stiffness while allowing some flex to apply pressure) - using the FLAT part of the Pic (or any hard plastic with a little flex ) DO NOT USE THE EDGE, you don't want to scrape or tear things ...press and move the bubble towards the hole, working slowly and applying smooth steady pressure...don't rub back and forth or DIG IN with the pic, we're trying to move the wrinkle to the hole.
6. Apply more heat as needed and keep working it...allow it to cool and check your work...reapply heat and pressure if necessary
7. Re-insert flipper button and hold it firm while you reattach the nut. You don't want any rotation or twisting motion on the button, it doesn't have to be super tight, only snug
8. Rescrew in nut retainer screw, not too tight, don't strip the wood
9. After, apply a thin coat of Carnuba (Blitz) wax to the area, let dry and lightly wipe clear.
Hope this helps.
I don't have a before pic as I was too excited when my game arrived but, this was one of the first things I did...here is the after pic for what it's worth...Not 100% perfect but pretty close.
20210424_172903~2 (resized).jpg20210424_173215~2 (resized).jpg20210424_175901 (resized).jpg
