I really enjoy working on pinball machines. With the help from people here I have a nice working Flight 2000. I’m now fixing up a Trident. I’ve rebuilt two rectifier boards. I’ve repaired a solenoid driver board (both the regulator side and the solenoid driver side.) I have even fixed a badly corroded lamp driver board.
But when it comes to the MPU reset section I can never get one to work. I’ve replaced sockets, IC’s, transistors, switching diodes, zener diodes, diodes, etc. Still no flicker and no flash.
Why is the reset section so mysterious? It seems to me it should be pretty cut and dried. If your reset don’t work check the voltage here, then check continuity here, if that checks out then check the voltage here, etc, etc. I admit there are a lot of components in the reset section but it shouldn’t be that complicated to diagnose.
I’ve looked at PinWiki, Flipperwinkel, and others but someone needs to write an article showing step by step how to diagnose a reset section.
Bob
