I bought this machine working but dirty, and the bottom half of the display out. I figured... no big deal it's working
- I can fix the display,
- It's only a little battery juice on the board. Hahaha
- It's not that bad
- I might as well change the 6116 out and put a socket in for nvram while I'm at it
Well here I am,
I've tried everything in the caseydanger Black Knight 2000 won't boot post. Can't get the Leon to boot.
Everything in the - DumbAss " If a Leon does not work then you can shotgun ICs in the address bus, data bus and address decode but the first thing I usually do is verify ALL the connections in the address bus, data bus." Can't get the Leon to boot.
Everything in the- https://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#System_11A.2C_11B.2C_11C_games Can't get the Leon to boot.
Everything in the- https://techniek.flipperwinkel.nl/wms11/index2.htm Cant get the Leon to boot.
I even tried to give it to #chrishibler to fix.
" Thanks for the pics.
I’m going to pass on that one.
Too much corrosion and rework already.
Sorry.
Chris"
Oh, it's ugly. I hear you. But I have made it through the whole "Leon Tutorial" 20210815_185806[1] (resized).jpgAll voltages are good for all address and data lines. No shorts. All I see is a lower voltage at the PIA's #25 at 1.9v.
So... should I just give up on this board ?? I would really love to fix it and keep the original board. Can anyone out there walk me through fixing this thing?
Rob
20210703_083619_1629067754426 (resized).jpg20210703_083636_1629067754274 (resized).jpg
