New! Dark mode!
(Topic ID: 220547)
The Hook up
By trilogybeer
2 years ago
  • 49 posts
  • 8 Pinsiders participating
  • Latest reply 2 years ago by bangerjay
  • Hook Data East, 1992
There have been 64 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
I picked up this Hook for my brother and his family .This will be their first game . Game was in players condition and was in need of a few small repairs , so without getting too crazy I thought I'd do a few things to make this game a little nicer and make it play real nice for them .
#2 2 years ago
You da man Doug
#3 2 years ago
Playfield was overall decent but needed to be taken apart cleaned and parts replaced .
WIN_20180421_20_59_51_Pro (resized).jpgWIN_20180421_21_35_11_Pro (resized).jpg
#4 2 years ago
Quoted from bangerjay:
You da man Doug
Thank you here is a few more sexy strip down pics.
WIN_20180421_21_24_04_Pro (resized).jpgWIN_20180421_21_42_20_Pro (resized).jpgWIN_20180428_13_14_49_Pro (resized).jpg
#5 2 years ago
This is how I remove ball guides . Plyers with a rubber coated grip , I use them to pry them out .
#6 2 years ago
Topside parts removed .
#7 2 years ago
And bottom side.
WIN_20180428_13_08_31_Pro (resized).jpgWIN_20180428_13_45_33_Pro (resized).jpg
#8 2 years ago
I clean/sand the bottom side with a red scotchbrite pad .
WIN_20180428_21_14_38_Pro (resized).jpgWIN_20180428_21_14_54_Pro (resized).jpg
#9 2 years ago
Topside I buff polish and wax
#10 2 years ago
I tumbled/cleaned all the metal parts . Here is a pic of a few after tumbling.
#11 2 years ago
Playfield going back together .
WIN_20180430_22_17_50_Pro (resized).jpgWIN_20180430_22_18_01_Pro (resized).jpgWIN_20180430_22_18_16_Pro (resized).jpg
#12 2 years ago
Lets look at the cabinet repairs tomorrow.
WIN_20180516_20_34_48_Pro (resized).jpgWIN_20180519_10_19_56_Pro (resized).jpgWIN_20180519_10_20_11_Pro (resized).jpg
#13 2 years ago
lots of fun there! am sure they will enjoy it when you are done
#14 2 years ago
Some more cabinet pics
WIN_20180519_10_20_33_Pro (resized).jpgWIN_20180519_10_20_51_Pro (resized).jpgWIN_20180519_11_13_12_Pro (resized).jpg
#15 2 years ago
Taking parts out
WIN_20180519_10_31_01_Pro (resized).jpgWIN_20180519_21_11_13_Pro (resized).jpg
#16 2 years ago
Ok so the piece that the head sits on was pretty bad so I removed that and made a new piece
WIN_20180519_21_10_06_Pro (resized).jpgWIN_20180519_21_11_29_Pro (resized).jpgWIN_20180521_18_16_16_Pro (resized).jpg
#17 2 years ago
The back of the cabinet was also pretty pad so I removed the paint and did some filler work
#18 2 years ago
Panted the top piece and the back
WIN_20180522_18_21_49_Pro (resized).jpgWIN_20180525_18_10_40_Pro (resized).jpg
#19 2 years ago
The inside of the cabinet was looking pretty bad with stains into the wood , so I painted the whole inside .
#20 2 years ago
I used the heavy duty style leg inserts to give the cabinet more strength and stapled ground braid in .
WIN_20180526_11_05_17_Pro (resized).jpgWIN_20180526_11_05_31_Pro (resized).jpgWIN_20180526_11_06_24_Pro (resized).jpg
#21 2 years ago
When I removed the side rails it leaves glue residue and parts of the two sided tape . This 3m product works really well for removing that stuff .
#22 2 years ago
The outside of the cabinet I cleaned and buffed .
#23 2 years ago
It for the most part looked good , but there was a poor repair done on the front left bottom corner . It looked as though a beaver had been chewing on rocks .
WIN_20180519_21_10_49_Pro (resized).jpgWIN_20180522_19_32_36_Pro (resized).jpg
#24 2 years ago
So I need to take care of that , but I need to keep my repair as small as I can because any artwork I remove will need to be touched up . So I sanded it as flat as I could get with what was there . Put more filler and finished it off . I then primed and painted as small of an area as I could . The rest will be done by hand painting the artwork back in .
#25 2 years ago
I also just sanded that bottom to clean it up and put a new speaker grill on .
#26 2 years ago
All of the metal trim and speaker panel were rusty and had the powder coat flaking off . So lets take a look at those pieces tomorrow .
#27 2 years ago
looking great. Already moving along farther than I get to on my own games.
#28 2 years ago
Thank you ! Yeah I have been working on this since MGC so it didn't happen as fast as it appears to be here .
#30 2 years ago
Ok so the side rails I could have gotten from marco , lock bar seemed to be out of stock and I did not find a new speaker panel (hinges weren't too bad I could have left those alone ). So I decided the route I was going to take was going to be painting the pieces from the game I had . But since I was going to be doing this I did not want to make them just look stock , (too much work to just go un noticed I thought ) So I decided to paint them with a custom paint job .
#31 2 years ago
So The game is peter pan /pirate theme . The pirate ships in the game are made of wood and I thought a wood grain on these parts would look nice and fit the theme pretty well also . To do the wood grain I started by making a light brown to match the brown on the cabinet (that was the base color). Base color was put on after I removed the powder coat cleaned up the rust , then primed , sealed and base coat using automotive paint . after base color I started accent lines with a darker brown .
WIN_20180621_17_17_37_Pro (resized).jpgWIN_20180621_17_17_49_Pro (resized).jpg
#32 2 years ago
Here is a pick of the lockdown bar after the base was done and accents started .
#33 2 years ago
I guess I did not take enough pictures of the process , but here is the finished pieces on the game .
WIN_20180624_20_01_43_Pro (resized).jpgWIN_20180624_20_02_50_Pro (resized).jpg
#34 2 years ago
Awesome work I have 80 hours of work on our Hook.
#35 2 years ago
So after the base and accents the next step in the wood grain is to use black paint and a hard bristle brush to do the grain . Then go through and accent areas using black and the darker brown with an airbrush . Here is the speaker panel , I still need to get speaker grills for it .
#36 2 years ago
Have you thought about doing the legs in the wood look? Maybe even the coin door?
#37 2 years ago
Quoted from hawkeyexx:
Nice ! Not really sure how many hours I have into this one ,but I think it came out good and I believe my brother and his family are going to enjoy this game . He has 4 sons youngest being 7 and oldest 13 . I am going to let them start with the original code and after a while I have them put in Chad's update , that way the game will seem fresh again after sometime of ownership .
#38 2 years ago
Quoted from trilogybeer:
Excellent idea about updating the new code at a later date.
#39 2 years ago
Quoted from PoBoyPinball:
Thought about it yes ,but I am not going to do it ….yet. Was trying to not get too crazy with this game , and I do think it would look nice.... But the coin door was decent and the legs were . The parts I did paint I did because they were pretty badly worn out/rusty and not readily available new or good shape to just replace . Maybe someday if they decide they really like the game and would like the coin door and legs done at some point I will do those pieces for them . Time frame was also a factor as I had limited time to finish this game , My brother is driving from Connecticut next week to pick this up .
#40 2 years ago
Looks great!High Five!
You are a great brother!
#41 2 years ago
looking great. I love the wood effect on everything. Fits the theme well. Hook is a great shooting and looking game. It's the rules that should have had some modes going on to make it more involved. Havn't played the new code thou.
#42 2 years ago
Here is the front of the cabinet that had the messed up part . Not perfect but far better than it was .
#43 2 years ago
Bottom side of playfield , cleaned and parts tumbled . New coil sleeves on all coils , flipper rebuild and most of the pop bumper parts are are new .
WIN_20180709_20_53_36_Pro (resized).jpgWIN_20180709_20_53_42_Pro (resized).jpg
#44 2 years ago
The old speaker grills were pretty rusty also , I did put in new ones that are slightly different as far as the size of the holes in the grill . I went with black because I thought it looked better with the wood grain I had done . No artwork on the grill either . Easy enough to change out so something else could be put in with no problem but I'm liking the look of these . Put some little skulls down in the corners also because skulls are cool and they totally match the art and theme of the game .
WIN_20180709_21_11_59_Pro (resized).jpgWIN_20180709_21_12_31_Pro (resized).jpg
#45 2 years ago
Cool before and after pics . Thank you to Bangerjay for the help with the rivet press and Blue steel action on the ramp flaps .
WIN_20180421_15_11_46_Pro (resized).jpgWIN_20180709_20_55_51_Pro (resized).jpghttp___mashable.com_wp-content_uploads_2015_03_le-tigre-final (resized).jpg
#46 2 years ago
More blue steel .Again thanks to Bangerjay .
WIN_20180709_20_56_00_Pro (resized).jpgradar.zoolander.paramountpictures-1024x768 (resized).jpg
#47 2 years ago
Some pics of the cabinet inside with playfield installed .
WIN_20180709_20_51_20_Pro (resized).jpgWIN_20180709_20_51_34_Pro (resized).jpg
#48 2 years ago
A few minor tweaks and switch adjustments and the game is fully operational and playing great . Ready for my brother and his family to take home .
Cheers
Doug
WIN_20180709_21_13_46_Pro (resized).jpgWIN_20180709_21_14_20_Pro (resized).jpg
3 weeks later
#49 2 years ago
Blue steel!
$ 12.50
Gweem's Mods
$ 275.00
$ 299.00
$ 23.00
PinSound
$ 54.99
$ 54.99
$ 54.99
$ 42.00
$ 22.00
