Quoted from Wickerman2:The windlance shot, where it holds the ball in the kickback to "fire" and I think you hit the ring button...what am I doing there? You can't aim at anything...do I need to hit a lit shot after firing it or something?
Depends - sometimes when starting a mode (not sure when) it will allow you to fire, using a power meter on the back monitor,, the windlance into the M A N drops to get points/or an add a ball.
For 1 mode, cant remember the mode name, you shoot the right ramp to load a black arrow, you then fire the windlance using the ring button (you can't control the power) - and it feeds the top right flipper to get a D W A R F shot to hit Smaug and complete the mode. If you miss that shot you have a quick chance to hit from shooting from the bottom flippers, but you don't have much time if you miss from the top right flipper.
The final step of killing Smaug is similar except you have to hit a certain D W A R F target without hitting the remaining drops that are up. And that is a hard shot for me to hit - so much so I haven't done it yet The way I have seen it done, is you would cradle one of the pinballs on the right flipper and then use the left flipper to shot the right ramp, to load the arrow, fire it, and shot the target from the right flipper. That shot is much easier than the top right flipper. If Keith wants to make it harder to kill Smaug he could turn off the bottom right flipper for 1 second after you fire the windlance to drain the held right ball(s).
