Hi,
I updated Babylon Park @ Kfar Saba's Hobbit Black Arrow to the latest code, and it caused many issues, mainly the ball trough coils are weak, and the following issue that I will post a video about it in the next post. any fix?
Thanks,
Nadav
Hi,
Thanks,
Nadav
Odd, My black arrow is also reporting a drop target malfunction but all of the targets are operating properly.
I downgraded to 2.0, the version that was before all of this was done was 1.9. Can I downgrade it to this version anyway? Where can I locate it?
Quoted from gamefun29:Hi,
Thanks,
Nadav
You can change the Trough VUK Strength setting in Coil Settings. (Full Menu->Settings->Coil Settings)
Your video shows that there is a problem with the DW(A)RF drop target. Check the spring. Test manually to see if it moves freely. You may have to adjust the actuator arm on the little coil that knocks the target down.
--Ted
Quoted from check_switch_26:You can change the Trough VUK Strength setting in Coil Settings. (Full Menu->Settings->Coil Settings)
I found out today that the ball trough on my Black Arrow also cannot kick out ball with default settings...my as delivered coil setting from JJP are shown below:
DSC00514 (resized).JPGWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/the-hobbit-black-arrow-issues-after-updating and we tried optimising it for printing. Some page elements may have been deliberately hidden.
