(Topic ID: 165815)
The Hobbit 1.3 is out!! - Link inside - *** 1.31 now out - Fixes reset.
By Drenden
7 years ago
  • 68 posts
  • 31 Pinsiders participating
  • Latest reply 7 years ago by eliottk
  • Topic is favorited by 7 Pinsiders
There are 68 posts in this topic. You are on page 1 of 2.
#1 7 years ago
From the JJP group.. AWESOME!!!
All,
Version 1.30 is now available.
Please note this is a DELTA ONLY update. It currently updates any base game code.
It can be downloaded from the following link:
http://www.jerseyjackpinball.com/game-specific-downloads/the-hobbit-downloads/
Below is a list of the changes from 1.21 through the release of 1.30.
== Legend ==
+ Addition * Change/bugfix - Note
== Version 1.30 ==
=== Game Code
* More Into the Fire choreography.
* Improved Windlance choreography.
* Added Windlance awards 2x mode scoring, 2x playfield scoring, add-a-ball.
+ Barrel Escape.
* Arkenstone modes now properly restart after an add-a-ball event.
* REALLY scaled back Beast jackpot callouts.
* Mode won/ending fanfares unified.
* Fix Into the Fire stage 4 and victory lap lamps.
* Fix won modes not registering properly towards Arkenstone modes.
* Into the Fire scoring nerfed.
* Correct some stale blinking lamps.
* Defeat of Azog made a bit easier and higher scoring.
* Update mode hexicons.
* Ring Button can now be used during intial entry.
+ Book Mode Multiball. Adjustments control how many "easy" locks player
gets (light when Smaug locks light), and how hard it is to win points
and extra balls during Treasure Hunt.
* Fix drop targets popping back up after being hit during skill shot.
* Poppers hold off during extra ball and replay animations now.
* Cleaned up some book mode background speech.
* Arkenstone lit lamp effect should be more obvious now.
* Fix middle beasts' backstab.
* Smaug Multiball scoring nerfed.
=== Core Code
* Start button only shows Credits 0 if in attract mode now (not in-game).
* With SLOW restart set, game can be restarted on ball 1 with max players.
* Match awards credits now if interrupted by start.
* HSTD entry now times out after 60 seconds of inactivity.
* Coin-in no longer cancels HSTD entry (could cause game to get stuck).
=== OS
+ Manual version 1.6.
#2 7 years ago
Awesome. Should have my game soon
#3 7 years ago
Thanks for posting
#4 7 years ago
Thanks Drenden. It's like Christmas...again.
#5 7 years ago
I think these last 4
and
Are the new ones between 1.30 beta and 1.30
Also, its 400mb bigger
had a look inside to see the differences and it looks like all the videos for Battle of the 5 armies is in there... So should be pretty close and in 1.40 firmware.
#6 7 years ago
Congrats Hobbit owners!! Love how JJP stands by their code.
#7 7 years ago
Jack stands by his word.
#8 7 years ago
i just Loaded and was playing 1.3. Had Smaug multiball and beast multi ball stacked. I was having a pretty good ball with a lot of call outs and the game reset. This did not happen with 1.21. I will try another game and will see if it re produces.
#9 7 years ago
Are the game resets with 1.3? not sure I want to update if there is a rest bug. Anyone else have rest issues with 1.3
#10 7 years ago
No resets prior to installing 1.3. 2nd game on it, I had a reset mid game. Sending error log to JJP.
#11 7 years ago
I have gotten 3 resets now. Did not happen before 1.3. Two of the three times were smaug and beast multi ball running concurrent.
#12 7 years ago
Lloydjust PMed me back. Apparently the Hobbit Forums are reporting resets with 1.3 and he is sure Kieth will fix it
#13 7 years ago
I put in the 1.3 beta a few days back and no resets for me.
#14 7 years ago
Same issue , have got 2 Reboot with the 1.3 , with the 1.3P never reboot
#16 7 years ago
I just installed the official version 1.3. I had also a reboot.
In version 1.3 test, everything was working normally.
#17 7 years ago
Had mine reboot mid game with 1.3 also.
#18 7 years ago
Which also has problems reboot, passing the 1.21 code to 1.3 code?
#19 7 years ago
I rolled back to 1.21 and opened a ticket. There is a bug in 1.3 causing a reboot. Opened a ticket with JJP
#20 7 years ago
at this point if I'm running 3.1 beta over the last week with no issues, should I NOT install the new 3.1?
#21 7 years ago
I'm running 1.30P beta with no resets and been playing it a lot !
I'll hold tight and wait on a 1.31 ? Fix.
#22 7 years ago
Quoted from VolunteerPin:
Me too... no issues nor resetting happening. I wonder, is the beta slightly different?
#23 7 years ago
1.30 was pulled down from JJP's website. Says a fix is incoming.
#24 7 years ago
Quoted from Drenden:
I try to downgrading back to 1.21 and i have a error message on the screnn ...........
#25 7 years ago
Who wants to be the crash test dummy for the next version????
#26 7 years ago
i was running 1.3 beta w/ no issues at all. Is there a difference in 1.3 beta vs 1.3?
#27 7 years ago
Quoted from Skyemont:
Yes, 1.3 crashes and causes the game to reboot in the middle of play.
#28 7 years ago
No resetting for me with v1.30. Several stacked Smaug and Beast multiballs on several games.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#29 7 years ago
Quoted from FalconPunch:
Were you able to play any of the videos or are you going by file names? JJP is encrypting files in delta updates now. Not on my PC at the moment to check.
#30 7 years ago
Nope, can't play. Just see name and size
#31 7 years ago
1.31 is out... Apparently fixes the reset.
"**** THIS REPLACES 1.30 and fixes the reset issue.
All,
Version 1.31 is now available.
== Legend ==
== Version 1.31 ==
=== Game Code
+ Barrel Escape.
=== Core Code
=== OS
+ Manual version 1.6."
12
#32 7 years ago
Kudos to Keith to for getting this bug fixed over the weekend
#33 7 years ago
Just tried it. No crashes for me. Great update. Thanks to Keith and the others for working their magic.
#34 7 years ago
Working well for me too - great job
#35 7 years ago
No crashes. Well done JJP getting this fixed over a weekend.
#36 7 years ago
Can anyone who has the 1.30 beta version confirm if there is any valid reason to update to the final version?
#37 7 years ago
you have got 400Mo more in sound and image, it's ok , no bug no reboot on the 1.31 , fine version i just make a good score
#38 7 years ago
Quoted from RobT:
If you have 1.30 beta there is no reason to go to 1.31. I didn't.
#39 7 years ago
I would just to he safe go to 1.31. I had several games on 1.30 before it crashed. I was over a million to the first time. It only takes minutes to update. Good job jjp on a quick fix. Love jjp.
#40 7 years ago
Quoted from RobT:
A 1/4th of a GB bigger, so I'd do it. Keith fixed the 1.30 reset issue in 1.31, so I'd do it.
In my game here and no issues.
#41 7 years ago
2nd game on the new 1.31 code update. Felt like an hour+ of straight multi-balls. Exhausting.
#42 7 years ago
WTF?!
#43 7 years ago
wow, that score...wow.
And it is worth updating, if nothing else, when you get the ball lock it makes a really cool noise that it didn't with 1.30 beta...
#44 7 years ago
Which ball lock? Smaug or Mode ball lock?
#45 7 years ago
Like Lloyd said it's another 1/4 + gig. Lots more additions within.
1.30P just under 1.1G
1.31 just over 1.4G
So yes update it.
#46 7 years ago
Quoted from ExtremePinball:
Wow! You must have been more tired than Michael Phelps after a hard swim!
I have yet to break 800k and most of my games are in the 200k range. Jeesh.
#47 7 years ago
With the 1.31 code, I have a bug with sound.
In some parts, the sound is greatly reduced.
3 weeks later
#48 7 years ago
Damn this machine is making me feel stupid.
I've got the 1.31 .zip dl'd
I have a 4g stick
How do I update this darn game. Only founds instructions for full install in manual.
#49 7 years ago
Quoted from Jeekayjay:
I have a 4g stick
Are you unzipping the file and then saving it to the thumb drive?
#50 7 years ago
I unzipped it to the drive now there's a folder called hobbit_update on my thumb drive.
$ 64.00
Pixels Arcade Games
8,750 (OBO)
Belington, WV
$ 39.00
Travahontas Mods
Pinball Invasion
$ 29.95
Pinball Life
10,000 (Firm)
Leesburg, VA
$ 123.00
PinWorlds
$ 125.00
Dijohn
8,995
Ogden, UT
$ 95.00
Pinball Mod Co.
$ 79.00
Pixels Arcade Games
$ 100.00
Led Pinball
$ 120.00
10,200 (OBO)
Orlando, FL
$ 49.99
$ 50.00
Duke Pinball
$ 259.99
$ 18.00
Volcano Pinball
$ 90.00
RavSpec
$ 130.00
Dijohn
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/the-hobbit-13-is-out/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
