(Topic ID: 156276)
The Getaway: making the back loop shot up the ramp
By KornFreak28
5 years ago
  • 59 posts
  • 17 Pinsiders participating
  • Latest reply 1 year ago by RobC
There are 59 posts in this topic. You are on page 2 of 2.
#51 1 year ago
Coils are correct, probably factory as you said. Hard to say if they've ever been rebuilt. Probably worth considering doing, though.
One other question: what do your cabinet flipper button switches look like? Are they opto boards or leaf switches? My Getaway has leaf switches and i had to replace them due to intermittently weak or dead flippers. It's important to note that if they're cabinet flipper leaf switches, they use *gold* contacts (designed to handle lower voltages efficiently)...unlike most other games that have flippers that use high-voltage tungsten contacts on the cabinet flipper switches (designed for 50+ volts).
#52 1 year ago
Good info, I'll check mine later and let you know. Thanks again.
3 weeks later
#53 1 year ago
Quoted from RobC:
I rebuilt the flipper with a kit from pinballlife, and it made no difference. I'll look into cleaning or replacing the leaf switches next, I guess.
#54 1 year ago
I would check the eos switch gap. If too tight, it will cut power to coil early in the stroke.
#55 1 year ago
Quoted from jawjaw:
Good to know. This is my first flipper rebuild, what's the best way to measure the correct gap?
#56 1 year ago
The Getaway that I had I did install the hotter 17636 coils on the lower flippers. There are no plastic ramps on this game and I never had anything break with the stronger flippers. I could make the super charger ramp most of the time from the left flipper too.
#57 1 year ago
So, just to update - I played with the flipper angle, waxed the playfield, and I can now make the freeway ramp at least half the time with the lower right flipper so the game is definitely playable again. I think it was more the flipper angle than anything that was off, but the flipper rebuild helped I am sure since all the parts appeared to be original. Thanks for the tips!
#58 1 year ago
What firmware are you using? With L2 both Right flippers (U&L) activate at the same time where as in L5 they do not. I tried L5 on mine and didn't see a difference, but I also had a dirty sleeve causing my problems. Curious if both flippers simultaneously triggering could weaken the shot.
#59 1 year ago
I am running L2. The game is very playable now so I'm not unhappy. Great to share ideas here, thanks!
