Alright, I have about one year electrician apprentice experience (not much I know) but as far as I can tell, everything in the backbox looks quite decent, if anything a bit dusty. Fuses don't seem blown and batterys also look good (still give me 1.31V when 1.5V is wanted.)
If anybody has a better eye, also, the connector on the left is for the Knocker, which was just disconnected cause it was too loud for our taste^^
Down here I haven't found any disconnected wires, it looks more dusty or with oil or some other black stuff which gets on my fingers..but a relatively detailed look from me didn't help.
Except for these:
Would you guys think to use new wires here? They look quite done..but a connectivity test showed it should work (tested while they were still connected, not sure if it would also beep cause it can around a different way? Didn't think so though).
This is what the Switch Edge test shows, the closed ones on the right are all Opto Switches which afaik have to be closed, the one in the middle even says "always closed" so I guess that is alright.
One switch seems to be for the ramps (also one on the right) not sure if that is also a Opto, or if it's really a false switch?
This is how it looked when I had the Row Short.
But this time I got it through pressing a "switch" on the playfield, just to show, meaning, the row Short issue didn't appear this time.
Also, it seems the memory issue has been resolved?! Switched some stuff around again, turned off and on, several times. And it seems to have saved it.
Not sure how long, or why..but well?
The only Error it gives me on the start now is, "Shifter Error", which is still quite interesting, since the Shifter is also in the Row that was said shorted, otherwise, in the Switch test, the Shifter works perfectly fine?
So I'm back at the start I guess, the Ball Missing Error is still the main problem.
Maybe somebody got some ideas from the picutres or anything :S
Thank you!
