Working on a Getaway Hi speed 2. This game has/had multiple issues so a little background first. The problem started with Check fuse F114 & F115 message. Fuses were fine but no 12 volts at Q2 so I replaced that and game came back up. I played about 5 or 6 games on it over period of 2 days then when I test played it one last time before declaring it fixed it reset during first ball and gave me slam tilt switch closed message. I have disconnected all 3 tilt switches in order to eliminate them as the problem. Now I have message "ground short row 1 stuck closed" Looking at the switch matrix for that row I see Slam tilt, Left sling, Top yellow, Top green, Top jet, Top loop, opto 1 I am still digging but also looking for advice on this one. One last thing to note this game has been heavily routed and someone has installed a separate independent power supply in the back of the cabinet with an electrical cord tied into the 5 volts.
