(Topic ID: 170989)
The Genesis Club
By Hazoff
7 years ago
  • 475 posts
  • 106 Pinsiders participating
  • Latest reply 8 days ago by Menthelm
  • Topic is favorited by 43 Pinsiders
There are 475 posts in this topic. You are on page 2 of 10.
#51 6 years ago
Quoted from martimagico:
I just finished my plasma disc mod. Went with one disc as the focal point rather than multiples. I think it looks great!
Dude, I dig it! I was thinking about a way to incorporate a plasma globe, but this is way cooler. Will be stealing this idea, thanks.
#52 6 years ago
Quoted from zimjoe:
https://pinside.com/pinball/forum/topic/fs-in-va-custom-gottlieb-genesis
I got the idea from prowlerman99
#53 6 years ago
Cool! I've been wanting to do this ever since I saw the plasma disked Black Hole. That looks BA. How did you attach the disk to the bumper skirt?
#54 6 years ago
Joined the club this weekend. I will say this is one of the easiest games to "shop". Now just to figure out what to do with the translight
#55 6 years ago
Quoted from Its_me_aj:
I'm going to get one of these printed this week. I had one before, but gave it away. I tweaked this version a little and am trying again. I'll post pics of how it turned out. stpcore printed my alt Raven translite and it came out great. There is a whole thread about it https://pinside.com/pinball/forum/topic/diy-custom-translites
#56 6 years ago
I saw that one!! Not sure if I wanted to do something alternate or look for a clean NOS horribly amazing original
#57 6 years ago
Anyone have a lead on a set of plastics? Really just need the slings and the ones above the bottom lane guides but...
#58 6 years ago
The last NOS ones at PBR sold before I bought my Genesis. I almost bought one just to have it ready. The best thing about the translite is that it is easy to change
#59 6 years ago
I have my Genesis near ready but I have never played a 100% working one so I have questions.
The variable target. When I hit all the way back the the 40,000 sometimes the coil doesn't release it. When is it supposed to release it.
When I have Life Generator lit, I hit the 40,000 and it doesn't activate it. Only if I hold the target on that rivet for 4 or 5 seconds, will it activate.
#60 6 years ago
Quoted from futurepinhead:
Is it scoring when its shot all the way? I had to clean contacts on mine recently because it wasn't recognizing shots anymore and hanging up at times. Cleaned contacts and it was good to go again. I've never had to adjust it however
#61 6 years ago
Yes, I cleaned them.
They are scoring all rhe way back to 40k, but she only activates if I hold it in place on her switch rivots.
And it doesn't always release the target. I assume it's supposed to release it after you get it back to 40k
#62 6 years ago
Oh, its not revealing when you make the vari-target. The switch on the rotating robot shield cover thing has to be adjusted ever so perfectly. I forget off hand if its supposed to stay open all the way around then close and then open the switch again when its covered again. Mine didn't work right when I got it and I had to F with it for what seemed like forever to get it just right.
#63 6 years ago
The switch on the rotating cover works perfectly, just the damn vari target is the one that has me scratching my head
#64 6 years ago
I'll try and post a video of what it's doing this week.
I just don't know what it's supposed to do, so I don't know how to fix it or if it even needs fixed. Totally lost with it.
#65 6 years ago
I had the same issue with my vary target were it would not reset after being hit way back to 40K. I had to add a few more twists on to the spring. That made a big difference.
It will try and unravel on you.
It also could be a weak spring by the coil itself. Had to cut a few springs first time around on the drop targets to get them to work right, before the replacements came in.
RJ
#66 6 years ago
As far as activates only when you press on it by hand.
Turn the game off, unplug the assembly. Remove it, comes out very easily you do not have to remove the target,and operate the target by hand. clip onto to the wires that lead to each contact using alligator clips, and set your multi meter to ohms/Tone. Move the target to other score point contacts then to the one with a issue. Release it each time and watch the return motion. Since you are clipped in you can move contacts, solder pins,wires arond till you find what is loose. Clean the pins and check the barbs on the pins. This is were a dental pick helps, going into the molex also. If it dose not show up in tone mode. If you still has a issue. Go to ohms only and see if you have to much resistant between swipe and contacts. Compare the ohms reading on the other contacts.
Carefully Use a piece of plastic(monitor tweak tool) or wood stick to press on,move stuff around.
RJ
#67 6 years ago
So I was playing genesis Saturday morning and everything was perfectly fine. Went back later that night to play again and when I turned it off it would only boot with the flashers running. It would start a game but then it would randomly reset midball. Turned it off and checked connectors and everything. Turned it back on and then the under ramp kickouts wouldnt work and the robot cover wouldn't turn. Turned it off again and back on and now every light and coil locks on. No clue what's going on
#68 6 years ago
Have you done the ground mods to your game? Check your 5 and 12 volts.
Dose the display come on? Do you have a cap checker. I had 2 bad caps on the boot board.
RJ
#69 6 years ago
Quoted from rj:
RJ
On the vari-target, should it go past the last rivet at all or stop right on top of the last one?
#70 6 years ago
If I rember correctly stops on top. Each score has a position. There is some play on the swipe adjust. Finger nail polish the screw head after your done.
So click position 1 click position 2 and so on.pull the assembly and look at it on a bench.
I did re adjust mine so that all position had thevvsame contact points between the swipe and the circuit board. They started out leaning to one side..Close as I could get it.
It's not a pass by the pads, it has to be on the pads for score to register.
#71 6 years ago
Quoted from rj:
Mine originally had it land on top of the rivets and when it was like that, it just continuously scored that rivet's score. So I made with the contacts going just past the rivets then the scores worked perfectly but then I got the not always releasing and only getting it to activate motor when I held it in position for 3 or 4 seconds. I will do some more testing with it this week and shoot a video if I still have issues with it. I appreciate all the help!
#72 6 years ago
Unfortunatkey my daughter has the game in her basement now.
So I can't look at the vari target. I am sure someone will chime in. I thought there was something about the vari target in the game manual. I just remember mine was dirty off swipe points and the spring needed a few more wrap around the shaft.so it would return from the 40k position
RJ
#73 6 years ago
Quoted from rj:
RJ
displays work. I thought about ordering a new power supply and the daughter board fix. not sure if that will take care of all the problems though. ill check 12 and 5 v tonight. I do not have a cap tester
#74 6 years ago
I like the solid state 5 volt supplies they offer.
The 2nd Genesis I had , I was playing around with my ESR meter and most of the elec. caps were out of spec. Game is from the early 80's. one of the two I believe 10mfd caps on the daughter board, showed open. No boot no display.
If you are getting the GL and the display is showing up. Then I believe it is booting.
Have you done the grounding mods to the game. It is worth the time. Makes them run some much better.
RJ
#75 6 years ago
I think the previous owner did the grounding mods. I just looked again and now the displays are not working. Everything just locks on as soon as you turn it on. Haven't checked voltage yet.
#76 6 years ago
check out the TNT video on systems 80 b ground mounds on the molex connectors
#77 6 years ago
well I went through and double checked all the ground mods and everything was clean and good. checked voltages and they were good too. So I lifted the PF to check things under there and found out there were more fuses under the PF that I didn't know about (my first Gottlieb ss game.) the fuse for the outhole under the ramps was blown. so I replaced it and check by the ramp areas. I found that when I out the led flashers in, I mist have twisted the socket so one of the tabs was grounding out. turned it where it ended to be and the game booted up and played just like should. Stupid user error on that one.
#78 6 years ago
Good to find the error and be up playing. Has the translite grown on you yet?
#79 6 years ago
https://pinside.com/pinball/forum/topic/help-adjusting-gottlieb-varitarget-genesis#post-2973526
This just fixed my vari target. Where I was confused, the coil is supposed to release the target after each score. This fixed it. Thanks for all the input.
#80 6 years ago
So your spring was to tight and I had to add a couple of turns to mine. I could never get it to retrurn to the starting position
Did you end up readjusting the leaf switches so the hits end up on a pad?
RJ
#81 6 years ago
Leaf switches were fine actually. My biggest issue, was I didn't know how it was supposed to act since I had never seen one in action. Mine wasn't so much the spring, but the magnet wasn't releasing it, so I had to adjust the bracket closer to the magnet. But I couldn't figure out why it was scoring non stop, and that's because it was supposed to release. So I had it in between the rivets, but that wasn't allowing it to start the reveal.
Needless to say, I was very excited.
#82 6 years ago
Hi! I love that there is a Genesis club and I agree it's a great game. Mine hasn't worked for sometime now, but it's currently being fixed and I'm hoping to have it up and running within the next two weeks. This thread is great for getting caught up and I can't wait to help contribute. Also, thanks to this thread, I'll be sure to tell my guy to do the grounding mod asap.
1 month later
#83 6 years ago
While investigating a possible weak coil problem, I discovered my machine has A-20095 coils installed (super flipper). The manual calls for A-17875 coil. I have no idea what a super flipper coil is, nor do I know if this a preferred coil replacement. Is a supper flipper stronger than the correct flipper coil?
Any feedback on which coil should be used is appreciated.
#84 6 years ago
I would call pinball resource Monday see what they have to say
RJ
#85 6 years ago
The factory coils work fine if eos switches and flippers are set right, if what you have are too strong you will end up breaking ramps or plastics.
#86 6 years ago
Quoted from crlush:
Mine plays 100% with the factory coils. When I bought it the flippers barely worked; it was just EOS switches out of adjustments. With them properly adjusted, I didn't even need the rebuild kit I ordered for it.
#87 6 years ago
Ok, dug into it a little closer, looking at the schematics. Apparently the game does use the A-20095 coils for the flippers, per the schematic.
On my game, using the left flipper to shoot up the right ramp was no problem. But using the right flipper to shoot up the left ramp, just didn't have enough power to make the shot. The left ramp does have more of a curve to it than the right ramp, and therefore would require a bit more power.
I replaced the right flipper coil, and now I'm able to shoot the left ramp. I measured the resistance of the new and old coils, and the old coil had slightly more resistance than the new coil.
#88 6 years ago
Count me in! Mine has been a project over the years - first, the translite was replaced, then I re-made the paper backing to the reveal below, then replaced the displays, then the Swemmer board went in, with the ground mods, followed by the new clear ramps, and LEDs are next - its actually a neat game (need to figure out how to post vids).
#89 6 years ago
Welcome! I love this game and I can't wait until it's fixed, which should be this coming up Monday....lol, I hope..
#90 6 years ago
Well, my game is finally working after all these years, but unfortunately there is no sound so I'm not too sure what to do at this point.. background music does come out briefly when we loosened up the connections on the mpu board connectors so there's some hope.
#91 6 years ago
I've seen some with clear pop bodies/caps - does anyone know where I could source those?
#92 6 years ago
Quoted from remf:
I currently have two Genesis. One of them is fully working and the other is getting there. I had a sound issue as well. It turned out to be connectors. I ended up just repinning all of them. But it appears the ones for the double edge connectors are drying up.
#93 6 years ago
Quoted from Robotoes:
They are williams pop bumper parts on top, just buy the whole top, it will screw/line up with the gottlieb bottom.
#94 6 years ago
Quoted from crlush:
Oh cool, thanks. Opens up a lot of possibilities. Putting my clear ramps on this week!
#95 6 years ago
I've got my Genesis machine almost completely re-assembled, but I'm not sure if I have the right shooter rod plate. This wasn't with the other parts of the game and it just doesn't seem like the right fit.
Anyone out there who could verify that this is the right or wrong shooter rod plate?
Thanks,
Jody
#96 6 years ago
That is not the one in my game. I can take a photo tonight if no one else beats me.
#97 6 years ago
Thank you, that would be great if you post a photo!
Jody
#98 6 years ago
Anyone have a spare knocker assembly? I found out that mine is missing
#99 6 years ago
Quoted from jmountjoy111:
Thanks! I'll see if that's the issue when I get home tonight. I also have a buddy who's willing to let me plug in my MPU board to see if that's the issue or not as well.
#100 6 years ago
hey everyone, where are you getting your clear ramps? My dad has a Genesis and would love to install those!
$ 12.00
Tools
Nezzy's Pinball Prints
2,500 (Firm)
Towson, MD
$ 83.00
PinballReplacementParts
This page was printed from https://pinside.com/pinball/forum/topic/the-genesis-club/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
