(Topic ID: 209985)
The First Rule is.... Fight Club 20th anniversary homebrew build
By Mbecker
2 years ago
  • 408 posts
  • 72 Pinsiders participating
  • Latest reply 23 days ago by Mbecker
  • Topic is favorited by 101 Pinsiders
    There have been 410 images uploaded to this topic. (View topic image gallery).
    There are 408 posts in this topic. You are on page 5 of 9.
    #201 2 years ago
    Shadow motor has never stripped on me yet but I think it’s possible for sure. I think it might have something to eventually stop the motor from running if Optos are out though. Could implement an overcurrent solution with a chip and transistor but would be cleaner with a microswitch or something easy like that if it were trustworthy.
    #202 2 years ago
    Quoted from Mbecker:
    This thing is donating some parts.. picked this up local for cheap for the purpose. Kinda cool looking playfield, I've never played it.
    want to get rid of that ramp to the right? if you aren't going to use it. very cool build too. Love to movie and can't wait to see the final product!!!
    #203 2 years ago
    The gear on the motor on the Shadow is plastic as well as the rack. Mine did what you are describing. The optio failed and the motor got to the end of the rack and what broke was the gear on the motor shaft. It snapped in half and fell off the shaft. All in all it is the best scenario that caused the least amount of damage. But yes, I can confirm this can happen.
    -Jim
    #204 2 years ago
    Quoted from jim5six:
    -Jim
    Yeah — then def need a fail safe solution.. my motor has the brass gear so it’s the rack that will strip for sure
    #205 2 years ago
    Quoted from Bax1:
    The clear plastic one? Do you have a broken one that needs replacing?
    #206 2 years ago
    yes. mine is broke in the s curve section. Send me a pm and let me know what you may want for it.
    #208 2 years ago
    Hahaha what the heck?!? That’s freaking awesome, just made my night. “If you could play pinball against any celebrity- who would you play?” “If this is your first night at Pinball club, you have to play!” Haha oh man, that’s pretty perfect and sadly inserting Pinball in everywhere made it feel pretty relatable — “ I had a Pinball collection that was nearly complete” lol
    #209 2 years ago
    4/13/18
    Back to the mini Playfield. Cut holes for slim targets - sometimes this requires reshaping other parts:
    Barely got that one tucked in there by the pop.
    Then I realized my somewhat straight shot for the subway was blocked by a damn target:
    Now I gotta figure this out — more proto fabbing..
    #210 2 years ago
    4/13
    Still working on that subway.. I can weld parts together with the propane torch I’ve found. Just need the right shaped first - done with a handheld heater gun.
    Working topside, got a problem here:
    Readjustment and then rails mostly fabbed and put in:
    Trying to decide on the support columns size.. wanted the larger but they will block some view I think, prob gonna have to be the smaller size:
    #211 2 years ago
    “Welded” together rest of ramps for the subway and it’s functional enough.. I think it needs a bit more than 6 degrees or it hangs up but I’ll fix that later on with final version.
    On to wiring
    #212 2 years ago
    if it works it works!
    #213 2 years ago
    Recycling some connectors ..
    Here’s mocked up support columns - got side tracked switched out drop bank so no wiring yet.
    And a rough view from the camera angle.. should be interesting, gonna be tough. I have an adjusting post on left outlane do it can be blocked if ness.
    #214 2 years ago
    4/13
    This spinner switch mounts on the other side
    http://www.marcospecialties.com/pinball-parts/535-8684-01
    You’d have to move it aliitle further back but should fit.
    #215 2 years ago
    Quoted from Pdxmonkey:
    Niiice! Thanks Monkey! I was considering another opto one here (have 1 more from FF) but fir 7 bucks, I’ll try that one out from Marco. I think I can match them then and do both sides.
    With that, cheers! Happy Saturday
    I will have videos soon, once more wiring is done. Although I may get distracted.. P3 arrives this upcoming week.
    #216 2 years ago
    Quoted from Bax1:
    bax1 — see pics below. I removed mine but it’s aldo cracked. However I just recently learned this is easily fixed with a blowtorch..
    If still interested in mine lmk soon. I can attempt repairing this one as well - would look better than my Adhock subway
    #217 2 years ago
    #218 2 years ago
    Picked up another 0804 today from Aaron.. gonna mount 2 on the lower pf - have 8 drivers so that’s perfect but I wanted 17 switches so gotta cut one some how or drop an extra down from another chain of 8.
    #219 2 years ago
    if you want to use it for your subway, go for it. if you are going to have it laying around then I would try it out vs my other one. Wouldn't want to take something that you would use on this killer build!! Hopefully the jager got the creative juices flowing on Saturday.
    #220 2 years ago
    Quoted from Bax1:
    haha I think the jager gets them going to a point then I start to slow down I try to build in the mornings/afternoons on coffee usually.. I start to get sloppy in the evening I can use other parts.. subways all wrapped up anyway -- I hate to use parts that could be otherwise useful to people so if you want it I'll ship it out to you.
    #221 2 years ago
    More terminals in for mini pf and got the cheapest web cam amazon had for playing around with.
    Cam comes with this fancy Hawaiian case lol - prob the case added 1/2 the total cost of the cam ha!
    #222 2 years ago
    Wait, are you doing what I think you're doing? mini playfield, with only a camera and monitor to play it (no window).
    #223 2 years ago
    Quoted from toyotaboy:
    Yeah - is that a bad idea? It’s too big to cut a window — the idea is to install it at the back of the cab, completely seperate and sealed with the illusion of the ball feeding down to it. Going to get a roughly 5 to 6” mini lcd for lower 1/3 of Playfield and cut a window for it. The camera view will be roughly like a what a security cam in the basement of Lou’s would have seen... at least this is all the plan.
    It’s going to be some work to execute in mpf since there’s no dual monitor support that I understand.. the camera / lcd will be displaying at a different portion of a view window than the main display. A 3rd portion will have extra stuff for the lcd when not in the basement. Hitchhikers guide pulled this off - hoping I can too
    #224 2 years ago
    And then some distractions showed up...
    D0115601-E836-4ADC-BE09-69190EEBA425 (resized).jpegAEC03151-F408-471A-8F86-7E1654BE3AA1 (resized).jpegAB72CD64-A5DD-4CE0-A2D8-6BB1B1E57A2F (resized).jpegC653B465-669F-404F-89E4-51F703CEF558 (resized).jpeg7CA88341-60D8-4F32-AE18-21D89FAC82B5 (resized).jpeg
    #225 2 years ago
    I think is a cool idea.
    If I understand correctly, you would hold the playing ball in the main playfield and the ball in the mini playfield would be another one. If somehow fitting to the story, you could film before hand a ball falling down an intrincate duct or some sort of pachinko wall, and show that video before releasing the ball in the mini playfield.
    #226 2 years ago
    Not a bad idea, I've had it myself. The biggest issue you "may" have is delay. I'm assuming you're just running raw analog composite video? Anything is compression will have delay. I would simply have that LCD on all the time, and then maybe the video feed is turned on/off by switches from the ball traveling down, or draining.
    #227 2 years ago
    I figured just leave the feed on all the time, but have the lights in that area on a switch/relay
    #228 2 years ago
    Aaand more distractions .. starting to think I may get less dobebthis summer than I had hoped.
    #229 2 years ago
    For the camera — yes, raw feed is what I’m thinking. Because the mini field is bigger than my lcd I’m thinking wide screen web cam? Any thoughts on wide/fish eye view vs standard?
    Always on should work - I’ll just have two anchor points/window definitions in my overall mpf viewport and when the ball goes to the mini I’ll redirect what’s showing on the lcd screen. I *think* this will work.
    Love the idea of the ball going to the basement animation. Will throw that on the wAnt list - thinking a ball bouncing down stairs
    #230 2 years ago
    Wow what a top idea wish i had thought of it
    and the timing and transitions and multiball issues...
    at 2:25
    and the layout for the lp on the current Airplane project
    I knew this was on the cards when i could see that lower your Lpf was not
    going to fit under the main pf.
    To start you rolling it will need to be an analogue camera.
    Anything over a 5ms delay is unplayable.
    #231 2 years ago
    Quoted from kaboom:
    and the timing and transitions issues... 3 years ago
    that's awesome.. I followed your project years ago, didn't realize you had added that feature.
    #232 2 years ago
    Quoted from kaboom:
    at 2:25
    Thanks for the vid posts - I was def. gonna go back and check them out - hitchhikers and airplane are both impressive, would love to play someday.
    Any more helpful hints are more than welcome
    #233 2 years ago
    something like this?
    #234 2 years ago
    Quoted from fantarama:
    Exactly!! That’s awesome
    #235 2 years ago
    can I buy this machine yet or what????????!
    #236 2 years ago
    Are those worker bees?
    Worker bees can leave
    Even drones can fly away
    The queen is their slave
    #237 2 years ago
    That IS awesome! How long did that take you? The scale is a little off (the ball doesn't get small enough for the perceived distance of the stairs), but still KICK ASS!!
    #238 2 years ago
    Quoted from mrm_4:
    Yep - just send me your $$
    #239 2 years ago
    Quoted from SeaLawyer:
    I'm not sure, about 3-5 hrs I guess. The 3d modeling was about 1-2 hrs, but then the ball bouncing didn't came out of the box as expected and spend a lot tweaking the damn thing.
    The scale... didn't think of it as it's as 3D as 3D comes, and not something I draw, but now that you mention it! Here's another take from a different angle and changed the field of view of the camera, maybe a bit better now?
    Quoted from kaboom:
    at 2:25
    you really make some rich use of screens in your pinballs! very nice
    cool!
    #240 2 years ago
    fantarama — what program(s) did you use to model and animate ?
    #241 2 years ago
    I used 3dsmax to model it, but in that case it's all very basic forms really, like boxes and planes.
    The animation was done with Unity. I just used the built-in physics engine. At first was hopping to just drop the ball down the stairs, but wasn't getting the desired results so I tampered a bit with it applying forces when it touches the floor. Everything (bouncing, speed) is very, and easy adjustable.
    The lighting is done in Unity as well.
    #242 2 years ago
    Yeh, much better! Terrific work!!
    #243 2 years ago
    Oh man - this is awesome but also makes me realize just how much work I have ahead of myself with animations / dots and coding.
    Ugh... progress has been slow last week, hoping to get some time in this Friday/sat to finish wiring my lower pf and switch over to the fast trough Optos. Then it may be time to upgrade to mpf o.5 which was released yesterday.
    #244 2 years ago
    Nice, I was waiting for the new version to come out before I started on it so I didnt have to move everything over per the recommendation of jabdoa
    #245 2 years ago
    waiting for yout next update!!
    #246 2 years ago
    4/27/18
    Happy Friday!
    Feels like backward progress when you have to remove parts to go forward.. none-the-less had to be done—
    Here’s my trough removed with the wpc trough boards.
    They came off and installed fast boards, eliminating the opto driver board I had between them, and the issues I had going on (wasn’t quite keeping track of balls correctly).
    Way better system with just the fast boards.
    Then I had to tangle with this beast —
    Removed the 0804 board from the loop and installed a 1616 instead. The 0804 is pairing with another on my lower Playfield to drive everything there and make it easily removable (both boards at end of hardware loop, so I can disconnect the whole thing easily). Had to change around some config stuff to accommodate the change.. but it’s done and everything works again.
    Still working on lower wiring now -
    Tomorrow hopefully get things wired to boards.
    #247 2 years ago
    More lower wiring. Coils all wired.
    Made an embillical cord to connect back to the mother ship
    I need a 17th switch input, so I’ll need to run an extra wire down for that from a different bank. Will prob run 3 since I already need 1. Also will be running a line from the nano and 5v for driving leds. And a couple opto lines from a board up top. It should still be easy to disconnect out of the loop when I’m just working on the upper.
    #248 2 years ago
    Looking good.
    Animations and screen stuff scare the crap out of me too. Just focus on the task at hand. For me that’s all code and post physical things to worry about.
    #249 2 years ago
    "Where'd you go, psycho boy?"
    -Tyler Durden
    BUMP
    #250 2 years ago
    Summer weather had hit and talk of and planing of outdoor house projects .. as such not much progress last few weeks. Maybe be good to take a step back for a bit as well - was going a little intense since January. Will be making progress this summer but a bit slower for sure.
    Also picked these up yesterday - getting back into playing so that’s taking some of my pin time
    $ 149.00
    $ 99.99
    $ 60.00
    Docquest Pinball Mods
    Pinball Z
    $ 27.50
    $ 9.99
    Bent Mods
    Pin Mods
    $ 9.95
    pinballmod
    Pinball Z
    $ 45.99
    Lee's Parts
    $ 29.50
    Playfield - Plastics
    $ 65.00
    Pinball Mod Co.
    $ 14.95
    Cabinet Parts
    Habos Arcade
    $ 9,500.00
    Great American Pinball
    $ 28.50
    $ 48.00
    $ 229.99
    Pinball Photos
    $ 76.95
    $ 66.95
    $ 84.95
