(Topic ID: 248353)
The Firepower II Lounge...members and fans
By ss-pinball
1 year ago
  • 358 posts
  • 38 Pinsiders participating
  • Latest reply 1 day ago by greatwichjohn
  • Topic is favorited by 21 Pinsiders
Topic poll
“Firepower II replacements: plastics, back glasses, hard tops and playfields are not available. It would be helpful to have an idea how many owners would commit to purchasing the following. It would likely be a "limited edition" approach. see post #157”
  • Plastics 15 votes
    36%
  • Back Glass 8 votes
    19%
  • Hard Top 9 votes
    21%
  • Playfield 10 votes
    24%
(Multiple choice - 42 votes by 25 Pinsiders)
There have been 90 images uploaded to this topic. (View topic image gallery).
There are 358 posts in this topic. You are on page 3 of 8.
#101 10 months ago
Can you remove yours and give it a soak in evaporust? maybe steel wool and coca-cola to remove the rust and clean it up?
#102 10 months ago
Yea, I’ll try that. Do you have the Original connectors terminals?
#103 10 months ago
Yes, I plan to tape it off like I did the sides and spray the colors to try and match the rest.
Quoted from ss-pinball:
I really like the look of the Firepower II below the coin door.
Are you planning to put the graphic Williams "W" over the speaker below the backglass?
#104 10 months ago
Quoted from Gorgar666:
I’m waiting on delivery to it as well, are all the words used? I know “3” can’t be used....I guess...
Mostly is says Firepower , Fire and Power. It does seem to say the other words when the game is over but I cant figure out what triggers it. If I get more time I may take a look at the roms to try and make a custom one to better utilize the speech. I know there are guides out there to help with the old William's coding. If I end up not touching that part I still think it was worth the upgrade.
#105 10 months ago
Quoted from matirwin:
swillie details how to do it either early on this board or on the original Firepower fan page...time frame would have been a little before I started this board if it is on the other one
#106 10 months ago
What pitch is best for this game the normal 7°?
#107 9 months ago
I'll admit it, I bought the game because it was cheap, and even if it sucked I could make a couple hundred bucks. I had a Firepower for a bit, and enjoyed it. General consensus was this one is worse, so my expectations were low. This is probably my least favorite era of game. I think it's primarily because they never play well in the wild. I just finished shopping it out, and I'm really enjoying it. I'm up to 2.1 million. I guess the GC is set a lot lower on modern games, 2.5M is a little bit of a challenge. I'm not having any luck hitting the multiball start up the center. It seems more likely from a ricochet of the bumpers. The target tests fine with a ball. I swear I'm hitting it, maybe only gracing the edge.
#108 9 months ago
Quoted from Shredso:
I'm about 50/50 on the multiball target between hitting it and benefiting from a ricochet from the bumpers...and again, putting the ball up there TO ricochet was really my first strategy.
I love this era. It is my favorite. If you think about what comes in the nineties lots of those pins just have horrible art and wire-form ramps and are all similar. Yeah, they are fun, Rampy. Fast. There's a lot more fan-pattern layouts there though.
I think you get a lot of pinball for your money in williams 6-11 games and the corresponding Ballys (I even like the art on many Gottliebs from that era...don't like the feel of them though).
Anyway, I think that FP2 is unfairly dumped on. It's solid, especially when it is dialed in.
#109 9 months ago
I'm not sure. I monkeyed with mine 1/4 turn of the nuts at a time...checking the level from everywhich way until it felt better.
#110 9 months ago
I put LEDs in the backbox it is nasty bright... But I don’t wanna put incandescenceS....
#111 9 months ago
I have LEDs in mine...Comet natural warm white non-ghosting and it still looks like a pinball machine
#112 9 months ago
My FPII backglass had a mix of warm & cool frosted white 1-SMD, Pinball Life "Ablaze" brand. Didn't seem too bright to me and I'm pretty sensitive to that stuff. There's a lot of masking area, helps keep the overall brightness down. I've heard people recommend using those cheap old flat-top style frosted LEDs. They kinda suck on playfields, but great for turning down backglass brightness.
#113 9 months ago
Quoted from yancy:
That’s exactly what I did. Found some old LEDs that I was unhappy with elsewhere. Really dim, all is good now!
#114 9 months ago
F-it made my own Protectors...too little to late on the Slings.... Where can I get some reproductions!!!
#115 9 months ago
What pitch level in degrees works best for this Game? Almost got it ready to go.
#116 9 months ago
mine is pretty dialed in at 7.5 degrees
#117 9 months ago
Wow, how’s the game play?
#118 9 months ago
I like it. It's fast. Not nearly the number of airballs that it had at first. It made it a bit more challenging. The shots were "slam dunkish" before...now there is more skill involved.
I think it is a little more steep than what it should be but I think the previous owner did the flipper upgrade, so I can get away with it.
(Either that or my gauge isn't terribly accurate and it's at about 7 degrees).
Nice blue vent below the speaker. I like it.
#119 9 months ago
Anyone have a layout/parts list showing the rubbers needed for the playfield? I don't see it in the Operator's Handbook. PM me if you can help. Thanks!
#120 9 months ago
#121 9 months ago
What attaches to this bracket? Do I have wire harness support(s) missing? Don’t like these wires resting on the transformers.
#122 9 months ago
Metal grating cover is missing. Prevents accidentally touching the power supply.
Look over to the left And rear, Vacant screw holes...used to mount the metal mesh grading.
#123 9 months ago
Would you or anyone be able to send a picture of what the grating looks like...even a picture through the open coin door perhaps? I'll look to fabricate one like the original. Thanks.
#124 9 months ago
15908598618178702005189763989630 (resized).jpg15908598818061790714731382604366 (resized).jpg
#125 9 months ago
1590859940845786574976125183926 (resized).jpg15908600281715145835728028979734 (resized).jpg
#126 9 months ago
Painted black. Not original color.
#127 9 months ago
Thank you for the pics!! Just what I needed!
#128 9 months ago
How do I put videos here?!!...
#129 9 months ago
I uploaded mine to youtube then put the link here. Not sure if you can embed directly.
#130 9 months ago
#131 9 months ago
Removed the playfield to install a missing guard over the transformers. Reinstalled and plugged everything back in (can't see how I could have plugged anything into the wrong connector). Now when I turn the game on, the right flipper immediately locks on. What's going on? The flipper switch (at the button) is open, but even if it was closed I wouldn't think the flipper would activate unless the game had booted and a game started. Any ideas what's going on?
#132 9 months ago
Quoted from JethroP:
Any chance you swapped the white and black playfield plugs around? I believe they were used in this system, but I could be wrong.
#133 9 months ago
Quoted from Tomass:
Well, as a matter of fact, that's exactly what I did. So I corrected that and now the game doesn't boot. What did I fry? All the fuses check good.
#134 9 months ago
There was a thread a while back where someone did this. I will see if I can find it. I think he fried some ICs on his boards but not exactly sure which ones.
#136 9 months ago
Actually this is the one I was looking for.
https://pinside.com/pinball/forum/topic/pulled-a-rookie-move-mixed-black-amp-white-molex-on-williams-system-4#post-4525782
#137 8 months ago
Ok some, unass your slings plastics spares...Lol.
#138 8 months ago
I just put up some Firepower II items on the marketplace (harness, ramp, mechs, etc)
https://pinside.com/pinball/market/classifieds/ad/97554
#139 8 months ago
Ok, how to get extra ball ?
#140 8 months ago
Complete F-I-R-E-P-O-W-E-R three times, then shoot the ramp.
#141 8 months ago
Thanks. Is there a Way to Make that easier. Lol
#142 8 months ago
It's easier on later balls since letters carry over. For example, if you start ball 2 missing one letter, you just need to complete that one letter and spell it twice more to get credit for three completions on a single ball. Also a good thing to focus on in multiball.
#143 8 months ago
Quoted from yancy:
Ahh... good info. Thanks. I was racking my brain on this. Couldn’t find any info...
#144 8 months ago
Metal-mods making me decals to make my own FP2 Caps. Seeing that they are unavailable....this is placed on a blue cap.
8BC8BA8D-F32E-473F-A654-619EBBC5BDB2 (resized).jpegD4399E6F-459E-4A60-885E-6FA8C189F02F (resized).png
#145 8 months ago
[quoted image][quoted image]
FP2 isn't the only pin that uses those caps. I think Laser Cue and maybe even another title or two use them.
Some folks use Firepower caps or just mod out like you have.
#146 7 months ago
Check out what Metal-Mods got Firepower 2!! Oil Slick shine!
#147 7 months ago
I’ve looked everywhere for this type cap....
#148 7 months ago
We just need a hardtop!
#149 7 months ago
Quoted from topkat:
I added FP2 to the Official Hardtops thread some time ago.
I agree it would be pretty nice to have a sexy new playfield...or even waterslide decals...or replacement plastics...or bumper caps
#150 7 months ago
Grand lizard had 2750 Made
Fp deuce 3400
Seems like it’s possible to have a Htop made for it if looking at production numbers as a basis. Not to mention majority of fp2 playfields looks like ass.
(And nothing agains the lizard)
$ 22.50
$ 17.00
Tools
Pincoder Store
$ 33.00
Metal-Mods
1,500 (Firm)
Escondido, CA
$ 50.00
$ 12.00
Siegecraft Electronics
$ 89.95
$ 28.00
