In a bit over my head. Got a project Firepower. It's my first non-working pin.
I have done stuff in this guide:
https://pinside.com/pinball/forum/topic/vids-guide-to-bulletproofing-williams-system-6
e.g. replacing all electrolytic caps, some stressed diodes/resistors/etc. replaced 40 pin connector, some bad sockets.
Put it all back together, no luck. No reset/ no blanking.
Found wiggling a ram chip caused blanking LED i added to light up. (blanking signal 3.5V, hopefully that's fine). So I replaced that socket
current state:
On power on, 2 red LEDs turn on then off, once. Then, blanking signal comes on.
No sounds, and the only insert light lit is "1" down by the flippers. (is that trying to tell me something?)
displays are on and are 0s . bottom left has nothing.
I put balls in in case it wanted them. No response to coin or credit switches.
The sounds do work when i push the test button on the sound board (no voice, but i'll deal with that later).
I've been reading
https://www.pinwiki.com/wiki/index.php/Williams_System_3_-_7
But I don't know what to do for "blanking signal is high but nothing happens".
Any pointers on things to check? Or is there a better thread to look for help in. Thanks in advance.
