Quoted from mrm_4:Sometimes a wire in the matrix coming unsoldered can cause what you described. Did you trace the wires and make sure everything under the playfield is still attached?
Yes, I checked all of the sockets, switches and diodes that were shown in that column. I didn't see any wires touching, bent over lugs or bad diodes. If this was the reason things weren't working, wouldn't the culprit come from the next to last item working in the column on the play field?
