Hello all - i have a couple quick questions about what i believe to be strange behavior with my FP. I have sorted out most of the issues i knew about. Though i did not do the work myself, there are stickers on the boards with an Oct 2018 date. Power supply was recapped, 40 pin interconnect replaced and coin cell battey installed. MPU is clean and no evidence there was any alkaline on it anywhere.
So issue 1 is related to the top rollovers. When i activate the “R” rollover it lights up both the “I” and the “R” and scored double (2000 instead of 1000). These are both in the same column so i’m thinking its an issue with the switch matrix. Though no other switches in theat column behave strangely. When i go into switch test, these switches show up correctly and only 1 switch number is shown. So is this just a dip switch setting that spots the I for you? I can’t see any such setting in the manual for this. I owned a forepower in the past and it did not behave like this.
Second issue is the left star rollover. Its not activating. Yet it was showing as closed in switch test. I clipped the diode (?) And it stoped showing closed. I’m not sure exactly which component it is but it looks like a diode. See pic. I can’t see anywhere in the schematics which shows this part.
Last question and thanks for all who have made it this far . Does my knocker assembly look complete? It looks tk me like there should be something on the bottom of the plunger but maybe this is a system 6 knocker. Someone clipped the wire which made me notice it..
C8B87B15-F5C6-43FE-8232-C049D3EA90B8 (resized).jpeg29AE12EC-263F-4963-8F9F-5129B9A9B48B (resized).jpeg
