(Topic ID: 70775)
The Firepower Club
By wiredoug
10 years ago
  • 4,689 posts
  • 396 Pinsiders participating
  • Latest reply 6 days ago by ChrisHibler
  • Topic is favorited by 183 Pinsiders
There are 4,689 posts in this topic. You are on page 53 of 94.
#2601 5 years ago
Quoted from canoncitypb:
I'm working on my Stellar Wars (I know this is the Firepower page, but I thought since they have the same board set and are both Ritchie machines, perhaps someone could help)
On my left lower pop bumper switch there is a 100 ohm resistor and a capacitor. it seems like the capacitor is labeled 2200 uf 10v. Does that sound right to anyone? When I attach the capacitor, the coil locks on when a game is started. When i detach it, the coil works fine. Is it a bad capacitor? What is the purpose of this capacitor?
It should be a 22uf capacitor. I would replace it with a 25V or higher cap. When you replace it, pay attenention to the polarity (plus and minus) of the original cap and install the new one in the same orientation.
The reason the coil locks on when the cap is connected is that the cap probably failed shorted. Very common with electrolytic caps of this age. Lots of machines from this era have the capacitor cut out of this circuit for this reason.
The capacitor buffers the switch closure. It ensures the transistor activates long enough to fully activate the coil. Same capacitor is on all slings and pops from the early solid state era.
#2602 5 years ago
Anyone selling a new back glass? I am possibly in the marke for a remake perfect version.
#2603 5 years ago
Quoted from Aniraf:
How much you wanting to spend? You want absolutely perfect call Mayfair.
http://www.mayfairamusement.com/backglasses.html
You want really nice call PPS
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PPS-08-7227-FIREPOW-V2
#2604 5 years ago
Quoted from Schwaggs:
22uf capacitor.
Thanks for the quick response. I'll change my order to get the one you are suggesting.
#2605 5 years ago
Any idea what Mayfair charges?
#2606 5 years ago
I joined the club this weekend. This one is a little flaky but plays. The displays go in and out but look good. I also have an issue with the flippers scoring points, I think it is just some nearby switches. I need to update the connectors, touch up the playfield, and buy some back glass. I think that after a full shop job this will be a really nice game.
IMG_9382 (resized).JPGIMG_9382 (resized).JPGIMG_9383 (resized).JPGIMG_9383 (resized).JPGIMG_9387 (resized).JPGIMG_9387 (resized).JPGRWNB1008 (resized).JPGRWNB1008 (resized).JPGIMG_9386 (resized).JPGIMG_9386 (resized).JPGOQSP3667 (resized).JPGOQSP3667 (resized).JPG
#2607 5 years ago
Quoted from SR230CC:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Almost done with mine! I have a little display issue and all the blue in my glass is flaking but after a new Rottondog MPU, Reseating the high playfield plastic and a set of rubber your right, It will be a nice game.
#2608 5 years ago
Playfield looks better than most. Nice find.
Your targets suck and your flipper is a little droopy.
#2609 5 years ago
Quoted from Aniraf:
The black knight and Gorgar I got from him were about $300~$350. You would have to call. BUT they are the original Williams reruns and are absolutely perfect.
#2610 5 years ago
The Mayfair FP backglass are a little different than the original in that they do not have the yellow to orange gradient at the top and lower left.
I have the Firepower and Blackout Planetary backglasses and they are not perfect either. The colors don't look quite right. The saturation of the colors is not as solid as original (looks washed out).
#2611 5 years ago
Since the Mayfairs are probably more expensive which is better?
Or... is the cost difference worth the printing difference?
#2612 5 years ago
I am new to this game so I have a question. Is the knocker on the Left Side of the cabinet supposed to do anything when the ball is plunged? Sometimes it does sometimes it doesn’t.
#2613 5 years ago
No, thats the credit knocker. It only fires when you put in coins or win a free game. It does not function if you have the game set for free play.
If your fires when you plunge a ball you have a problem.
#2614 5 years ago
That’s what I thought. Thanks
#2615 5 years ago
Quoted from Travish:
Not sure. Never saw the Mayfair backglass in person.
#2616 5 years ago
I bought the Mayfair at Pintastic for I think $300 and had it for a couple of years and loved it. I then bought the Planetary version thinking it would be an upgrade but I hated it. The ink is too thin and some of the reds are pinkish so it's sitting in the box and the Mayfair is back in. I did like the blue and the green on the ships of the PPS version but to me the Mayfair is much better.
#2617 5 years ago
Quoted from BriPin:
I also found with the Planetary repro the ink was thin causing obvious spotting. I placed the white condom/caps on the #47 globes, the end result looked pretty much spot on to how it should to me, only slightly dimmer overall due to the caps. The colours seemed to be correct on my glass. Very happy with it, I prefer this version.
#2618 5 years ago
double post
#2619 5 years ago
Great info about the back glass everyone…thank you!
#2620 5 years ago
Quoted from Aniraf:
Here is how the Planetary backglass looks with #47 incandescants (without condoms on the globes). Looks close to the original IMO, if you don't like the spotting like you can see in this pic install the condoms on the globes to address this.
One other thing I noticed with the Mayfair glass is the jets are a very pale blue when backlit - the Planetary blue looks correct as per original.
#2621 5 years ago
Quoted from Aniraf:
Nice. I wish I was brave enough to try the hard top. Can’t wait to see it.
I added my Hardtop experience to the Firepower Hardtop thread here:
https://pinside.com/pinball/forum/topic/firepower-hardtop-restoration#post-4741432
Ready to tackle the playfield swap now.
#2622 5 years ago
Just finished my restore. Here is the glass from Bally Bingo in the Netherlands. I'm very happy with it.
Pics are a bit blown out colour wise due to phone camera sorry. Its not that rainbow puke in real life!
20181215_140323 (resized).jpg20181215_140323 (resized).jpg20181215_140609 (resized).jpg20181215_140609 (resized).jpg20181215_140922 (resized).jpg20181215_140922 (resized).jpg20181215_140932 (resized).jpg20181215_140932 (resized).jpg20181215_141005 (resized).jpg20181215_141005 (resized).jpg
#2623 5 years ago
Quoted from KJS:
Pics are a bit blown out colour wise due to phone camera sorry. Its not that rainbow puke in real life![quoted image][quoted image][quoted image][quoted image][quoted image]
I really like the red skirts on those pop bumpers. That looks great!
#2624 5 years ago
Not really a “restoration” but I got my firepower playing tonight. Still have a few parts on the way so it’s not 100% but I have never played one besides on a computer so I had to. Great game!
A35C3143-F3BD-421F-B8C0-CCACA36FC53A (resized).jpegA35C3143-F3BD-421F-B8C0-CCACA36FC53A (resized).jpeg3DB02BA1-C1C5-48A1-A84D-2A3CDE11337F (resized).jpeg3DB02BA1-C1C5-48A1-A84D-2A3CDE11337F (resized).jpeg
#2625 5 years ago
Quoted from KJS:
Excellent work! Just curious why you used the round bullseye decals on the 6 standups in the middle and the explosion decals on the 3 standups on the right. Not meaning to be critical, just like to know how different people think...
#2626 5 years ago
Just personal preference. I like it how they are separate areas/target groups. I bought a full set of bullseyes but decided against it.
Also going to put a decal on the rear back one which is currently black.
#2627 5 years ago
Stripped and cleaned the playfield, touched up the paint, redid all the header pins on the boards and added nvram and a solenoid fuse block. Led's on the playfield and I will do the backbox later.
Just waiting for the new rubber to come in the mail and it is ready to play. Next I will get new backglass and possibly a playfield protector, but with $50 shipping....
Playfield is in worse shape than I thought, maybe CPR will be able to do them again eventually.
IMG_9432 (resized).JPGIMG_9432 (resized).JPGIMG_9433 (resized).JPGIMG_9433 (resized).JPGIMG_9408 (resized).JPGIMG_9408 (resized).JPGIMG_9434 (resized).JPGIMG_9434 (resized).JPG
#2628 5 years ago
Can someone tell me what size wireform ball guide goes on the left ball capture lane?
I did a pf swap a while back and just now noticing the guide is missing. Went back through my parts and cannot locate it so don't know if it was not on the original pf. Looking at online pics it looks like some playfields have the guide and others do not.
Thanks,
Robert
#2629 5 years ago
I've seen a bunch of original games including mine that never had wire form there. I think Williams realized it wasn't needed and stopped putting them on.
#2630 5 years ago
Quoted from StratDoc:
Thanks,
Robert
Whereabouts is this? Anyone have a photo of what it looks like?
#2631 5 years ago
With regard to the PPS backglass, I have been very satisfied with mine. I think the color, with some accent LEDs, really looks nice. Just my opinion:
https://pinside.com/pinball/forum/topic/the-firepower-club/page/43#post-4420363
#2632 5 years ago
Never implemented during production: cost cutting.
#2633 5 years ago
My CPR repro playfield had the holes in the pf for a wireform in the left hand capture lane. Took me ages to figure the ball guide was never there in the first place!
#2634 5 years ago
Hi all,
I've been running my game without the upper left gate so that I have the "skill shot" we talked about a few pages ago in this thread. This past weekend I noticed a flaw in running the game this way. If you lock a ball and are launching a second ball, the spinner is lit so you get good points when it spins fast. Well, I launched the ball with my left thumb putting pressure on the plunger while my right hand pulled back and released - this delivers great speed to the ball and to the spinner. It also delivers the ball quickly to the drain.
Well, because the spinner points aren't awarded until the spinner stops, the game sees the ball in the drain with zero points scored and serves another ball. Then the spinner stops and the points are awarded. I did it 3 times in a row and cranked up points without an increment in ball count, so it is repeatable. I'd be interested to hear if others with the gate removed have the same experience. I guess I'm going to put the gate back in because I don't want the game to have a "cheat" available. Too bad because I like the added interest created by removing the gate.
-Rob
-visit http://www.kahr.us to get my daughterboard that helps fix WPC pinball resets or my Williams system 3-7 sound board potentiometer solutions
#2635 5 years ago
I too have been playing with the gate removed and I like how it makes the game more difficult. I’ve never experienced the situation you describe but I try not to plunge the ball so hard because it will drain through the flippers. Later on when I get home I’ll give it a try and see what happens.
#2636 5 years ago
Doesn’t work on my game. Plunge and drain at your own risk.
#2637 5 years ago
I had it all up and running for Christmas and then I turned it on this morning and my displays wont work correctly.
Any Ideas?
#2638 5 years ago
Any Ideas?
Usually when you get the 0_0_0 displays it's one of the PIAs. Probably IC10 but maybe IC5
If those chips are socketed, press one of them back down and reboot. If that fixes it, replace that IC socket (it's bad).
ONLY PRESS ONE CHIP AT A TIME, or you won't know which one was the problem
#2639 5 years ago
Thanks I’ll try it right now.
#2640 5 years ago
Are you going to let us know what happened? or do we need to hire a private detective.
(Just kidding, another dumb joke)
#2641 5 years ago
It didn’t work. I’ll try to reflow the solder.
#2642 5 years ago
My Firepower has been doing a bunch of different strange things when I power it on. Examples include: lighting up but not starting, only starting in adjustment mode, starting with only partial sound, starting but with a weird scoring system, starting but going back to all default settings. I can get it to play normally by turning it on and off enough times or playing through the first game, but it seems like it’s getting worse.
Someone suggested changing the batteries, does that sound right? There are no regular disposable batteries in the back box, but there’s a lithium battery on one of the boards in there- is that what I should change? Thanks for any help.
#2643 5 years ago
You can measure the battery with a meter and make sure it still holds a proper charge.
Bad RAM or bad RAM socket can also make the machine go crazy, sometimes starting out fine, but getting worse as the machine warms up
#2644 5 years ago
One of my pop bumpers stopped firing and I cannot for the life of me understand how to get into the switch test or solenoid test. The instructions say turn to page 7 where it tells you how to reset the high score :/. Any tips?
#2645 5 years ago
Quoted from Aniraf:
No it's on the bottom of page 3 under "diagnostic procedures"
#2646 5 years ago
Looks like IC10 and 5 are bad. Does anyone know if the replacements from Marco will work?
#2647 5 years ago
Any Ideas?
Does the game play and just the displays are flakey? Are they locked at the digits in your picture or are the numbers in the digits changing?
The display PIA is IC18 on the CPU board. Is that chip socketed? Are the PIAs on the driver board (IC5, IC10, IC11) socketed? If so, you can try swapping the PIAs between sockets to see if the problem changes.
#2648 5 years ago
I just reseated those and it works now. Looks like I’ll have resocket the board. Thanks
#2649 5 years ago
Congrats on the fix! While you have the soldering iron out, replace the 40 pin interboard connector if you have not already. Also, you can use a fiberglass sanding pen to clean up the legs of the chips. Sometimes cleaning that side of the connection will prevent or delay you from having to replace the socket.
#2650 5 years ago
Will do. I already did the 40 pin and all header pins on both boards.
$ 44.99
Pinball Shark
$ 11.95
$ 36.95
$ 170.00
Displays
Digipinball Shop
2,900 (OBO)
Hawesville, KY
$ 27.95
$ 22.50
600 (OBO)
Casper, WY
2,200 (Firm)
Shrewsbury, MA
arcade-cabinets.com
$ 42.95
$ 1.00
Pinball Alley
Trade
Machine - For Trade
Washington Court House, OH
Tools
Pincoder Store
This page was printed from https://pinside.com/pinball/forum/topic/the-firepower-club/page/53 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
