(Topic ID: 55507)
The Dirty Harry Club
By Mato
6 years ago
  • 1,247 posts
  • 178 Pinsiders participating
  • Latest reply 13 days ago by Kas24
  • Topic is favorited by 53 Pinsiders
There have been 382 images uploaded to this topic. (View topic image gallery).
custom-6-clint-eastwood-head-dirty_1_6c78ac64f4569e1e2c82212ecb05c19d (resized).jpg
There are 1247 posts in this topic. You are on page 24 of 25.
#1151 4 months ago
Quoted from Scoot:
I am sure he is referring to the standup switch target next to the left ramp. I have never seen one without any damage. I have heard of people trying to add a metal backing and such, but don't think there is a solution for it other than a replacement. The gun shoots the ball with so much force on the target and ramp, that there is always some damage with the machines in the wild. Even the promo video for DH shows damage on that target.
Yes that is the target.
I'll try to figure out something and when I do i will post.
#1152 4 months ago
Quoted from o-din:
They are super easy to make. PBResource sells the material, and a good sharp pair of scissors can cut it. I use a small punch to start the holes and a drill to finish them on a block of wood.
Do that before you cut them and use a good heavy glove to hold it still while drilling the holes as it is sharp material.
Word to the wise: don't use scissors to cut blue "flap" steel. The sheet will curl slightly as you cut and you'll never straighten it. Instead, use a heavy duty paper cutter and you'll make nothing but sharp, straight cuts with no curling. Then use a Dremel tool to round the corners to match the original; I held the corner gently against the edge of a cut-off wheel to shape it and it worked like a charm. Here's a link to the flaps on my Jackbot ramp, these are the first flaps I ever made after very little practice:
https://pinside.com/pinball/forum/topic/jackbot-club-everyone-welcome/page/10#post-4851820
Also, a sheet metal punch is great for the holes. I got this one from Amazon and it's dirt cheap, plus no need to worry about cutting yourself during drilling:
amazon.com link »
#1153 4 months ago
Quoted from jibmums:
These don't. However your hole punch would be much better and safer than trying a drill.
#1154 3 months ago
Quoted from Ballsofsteel:
there are 2 flaps in the shooter lane, the first one that loads the gun gets beat up. Is yours blown out in the center? i replaced mine because of this issue, it helped but i also get the problem at times with the ball not making it to the upper lanes and pops. You can also bend or adjust the ball guides.
I am interested as well. Maybe a slow motion video would show the problem? i feel like this is a universal DH issue.
After many attempts I believe I found a decent and easy adjustment to the shooter lane, to help balls not making it up to the top. If you remove the apron, the coil for the shooter can be moved back a few mils. I tried that alone at first but it was un predictable I think bc the coil would move. I made a shim that I slid down in front of the coil, between it and the bracket.
I used a piece of plastic that came with some harbor freight tool.. its black plastic about 3x the thickness of a credit card. If you cut a slot into it, you can slide it down over the coil sleeve and it snugs it up pretty well. It seems, at this point, its softens the plunge just enough to prevent air balls...
#1155 3 months ago
^^^^^ got any pics
#1156 3 months ago
Commercial during big ten champ game allowed a few
It worked for 20 shoots so far. Which has been my best streak since having the machine
5D65C480-3203-4497-8B0C-DF8602DE04EF (resized).jpeg89385C35-03B2-485B-AC52-D6F6407B180A (resized).jpeg5CE75071-B1EC-438E-B077-B61ECC52B881 (resized).jpeg
#1157 3 months ago
^^^^ got it thanks, definitely going to give that a try. Good game so far.
Quoted from topkat:
#1158 3 months ago
Let me know
If helps. Feel
Like over tried allot of stuff
#1159 3 months ago
Have been wanting to add some stuff to my DH and found this golden gate that I think would look pretty cool, will have to do some trimming and playing around with location but I think it’ll look nice when done
4AE48141-9F41-4B86-B3F8-92BB9315FBB7 (resized).jpeg4E66CF8D-8090-431B-8CB4-AF51619A0270 (resized).jpeg
#1160 3 months ago
Quoted from Jolt:
That’s looking really nice. I think you could add three bulbs to the back panel for the upper lanes to know where the position of the light are. Either mounting point looks to cover them up, but it looks good. Think I like the back position better. To much covered the other away and not a whole lot going on in the back left corner.
#1161 3 months ago
Quoted from bssbllr:
You were exactly right, too much covering playfield. Decided to put in upper left out of the way completely. test fitting now. Need to trim just a hair more to clear glass easily.
#1162 3 months ago
Maybe use it as a topper?
#1163 3 months ago
I think that second spot
Looks better. Cool
Additional
#1164 3 months ago
Just became a member today,Can't play it yet but it's close.Glad to see they did the color dmd for this one.What are the must have mods for this one?That golden gate bridge looked pretty cool!
#1165 3 months ago
Quoted from Brian541:
I haven't seen very many mods for this pin. I think the best mods for this is the color dmd, gi ocd, and maybe a few spotlights to light the playfield.
#1166 3 months ago
ColorDMD and that's it.
#1167 3 months ago
The back cab graphic is pretty nice. Not sure if I like the side art or not.
#1168 3 months ago
I did a bit of dry brushing on the safe house and installed some blue and red flashing leds into the windows - these come on when the safe house shot is light.
I've got some leds that flicker like candles so think I'll put some in the warehouse windows.
Also leds for the roll over lanes in the backboard.
#1169 3 months ago
Ebay has the police car, helicopter and tv with video and audio.
#1170 3 months ago
I bought original style DMD for my Dirty Harry as I like to keep it original. I like it a lot.
#1171 3 months ago
Quoted from SYS6:
Also leds for the roll over lanes in the backboard.[quoted image]
I painted my buildings too.
3 weeks later
#1172 73 days ago
Anybody have a spare set of ramps?
Desperately need the right one that feeds the gun.
#1173 73 days ago
Left ramp feeds the gun.
#1174 73 days ago
Ok. Well, the shorter, more curved ramp with the two optos.
#1175 73 days ago
Quoted from RTS:
Let me check my garage when I get home from the office.
I have the left ramp that’s opposite the upper flipper in my parts room. Not sure the condition. I’ll take pics when I get home.
#1176 73 days ago
I'm on the hunt 4 another DH ... Kinda local ( 3 hrs driving 1 way )
#1177 73 days ago
Quoted from Coindork:
That’s amazing they are hard to find. That would be great for him.
Quoted from RTS:
Make sure to take the playfield back off makes thing much easier with taking ramps on and off. There are like 8 screws holding it on.
#1178 73 days ago
Quoted from RTS:
Ok. Well, the shorter, more curved ramp with the two optos.[quoted image]
Yikes! That sucks!
#1179 66 days ago
Quoted from kidchrisso:
Just installed the LED OCD GI board set. It took care of all the issues I had after putting LEDs. It is a pretty slick system...
Can you elaborate on this? Want to upgrade to LEDs.
#1180 66 days ago
Quoted from Captainclown:
OCD LED is an add on board that will make the LEDs behave like bulbs in respects to dimming. LEDs are not good at dimming so the sort of flicker when they try.
If you put LEDs in your Dirty Harry they will work just fine, but they wont be able to dim as well.
It's a trade off that you will decide if it's worth it, because OCDLED costs $$$
#1181 66 days ago
What site would you find this board add-on?
I've had my DH since 1998 and it was only on location for a brief time and had 600+ plays on it. I've "neglected" it for years, just playing it as it's in my eating area in the kitchen. Never down in a basement.
Playing one night in November, the left flipper just disintegrated. So I replaced it and installed new rubbers and cleaned it with Novus products.
I just joined this site and see all of the Mods that people have done. I just ordered the backboard decal from www.littleshopofgames.com today.
Game is pretty mint and everything works well.
#1182 66 days ago
http://ledocd.com/
Sorry to all, I always say it the wrong way around.
#1183 66 days ago
Quoted from TheLaw:
http://ledocd.com/
So you have this installed and no issues?
Site says "No Test results" on DH machines.
#1184 66 days ago
I have one in my machine and it works flawlessly. Worth the money for me.
#1185 66 days ago
Quoted from Scoot:
No but he has.
I had one NOT installed on my machine and it was fine.
Just diff'rent opinions. Like, if you where to be doing this on a route machine, it would 100% be not worth it. No location player is going to care that much or not play it becasue of it.
#1186 65 days ago
Quoted from TheLaw:
No but he has.
Agreed.
#1187 65 days ago
Has anyone purchased this Dynamite Mod?
ttps://modfatherpinball.com/products/copy-of-sopranos-playfield-dynamite?_pos=2&_sid=24e3370eb&_ss=r
If so, where'd you install it?
#1188 60 days ago
Finding a Dirty Harry nowadays without some kind of "mod" added is indeed a rare find.
#1189 60 days ago
nowhere. i've had mine for 12 years and all it needed was the backboard decal. just my opinion. feel free to place action figures, light strips, bullet holes in the display plastic, or whatever people do to feel better about the game i guess.
#1190 59 days ago
Quoted from TheLaw:
if someone does this, they need to make sure that all of the incandescents are replaced before starting the machine with the board installed. I forgot to switch the backbox bulbs on my Airborne over to LED and kept blowing a microfuse on the board, thankfully Herg helped me figure out the issue and it was my stupidity that caused it. Apparently the incandescents pull too much current for the fuses on the OCD board.
It's a nice mod and makes a difference!
#1191 43 days ago
Looking for help, thoughts, and ideas. I have the "Opto Trough Bad" message on my DH, which is a long term project I started years ago, it is an assembled machine from parts. On power up this message appears. The optos on the playfield test and work, The game boots okay, but will not start a game. In the switch edge test mode nothing in the trough registers. I have swapped the 16 opto board out mounted on the underside of the playfield, with one I had which I believe to be "good", still same issue playfield optos work, the trough does not. Any advice?
#1192 43 days ago
Quoted from TheLaw:
You don't think this would make a great topper?
#1193 43 days ago
PAR fuse on the 12v? Loose wire on plug to trough opto?
#1194 43 days ago
Quoted from o-din:
You don't think this would make a great topper?[quoted image]
It actually would, if by "Topper" you meant "Bong."
#1195 43 days ago
Quoted from PAR:
Check for continuity between the green numbers on u20 and u23. Notice the numbers on u23 are a little scrambled so double check. The 3 on mine did not have continuity and I had same Error message till I ran a jumper wire. All was fixed. Also check the black numbers on u20 to the plug pins on j207 I believe.
#1196 34 days ago
looking for this plastic if anyone can help?
#1197 34 days ago
Is there any way to keep the ball from falling out of the gun? Only happens sometimes.
#1198 34 days ago
jhanley somewhere in this thread this is mentioned. I believe you need to move the habit trail slightly back (or something like that).
#1199 34 days ago
Quoted from ChrisPINk25:
thankyou
#1200 33 days ago
Need to adjust the wire ramp leading to the gun all the way back towards the right side of the pin.
Quoted from jhanley:
3,700 (OBO)
Los Angeles, CA
$ 259.95
Pin Stadium Pinball LEDs
Gweem's Mods
Arcade Upkeep
KAHR.US Circuits
