Almost forgot to mention another thing that happened today; I spent most of it making final measurements and refinements to my custom neon design in an effort to send a comprehensive email to my neon guy. The email went something like this:
I've attached a PDF file of the final, full-sized, black and white version of my neon sign. (I saved a TIF file, too, but it was almost 100megs, so it wouldn't attach. If you need that or some other format, just let me know.) The attached file is 8'x4', which corresponds to the backer board and exact position of the neon on that board.
I'll try to outline the specifications here.
First, you might see some faint vertical lines. Those are simply demarcating a measurement every foot. Also, when you open the file, you'll see a dark rectangle in the upper-right corner:
That is where the backer board should be notched/cut out in order to fit around the duct work. Here is an image of the wall to give you a better understanding of the space:
...and where the sign with backer will be placed on that back wall:
...those other dark silhouettes are outlines of a couple of games that will be sitting in front of the wall. Kinda like this:
I also wanted to show you the placement of the studs behind the drywall:
...so that you can place the transformers accordingly. (If you need more precise measurements for the placement of these existing metal studs, just let me know.) Please also note that there is a gas line in the upper right portion immediately behind the studs:
...which will prevent the placement of transformers or nailing in that area.
In the meantime, here's a composite mock-up of where the neon sign with backer will sit in relationship to the existing metal studs:
That brings us to the color of the neon, which should correspond to this image:
I would like the red to be the ruby red coated tubes and the yellow to be the better yellow that will not show light through in the tight bends. I know we had some discussion about the color of the elephant toes. I saw a sign with sort of an off-white/beige color neon that I'm hoping you can replicate:
The animated elements are the flippers and the bite out of the elephant foot. These are all linked on an alternating transformer. I would like those elements to alternate every 2 seconds, as shown above.
The backer board should be painted the same color as the wall of my basement. I can bring the paint to your shop and even paint the backer for you whenever you're ready.
I think that's it. If you have any other questions, I'm happy to chat. I guess my only questions are; what's the final estimate for this and when can it be ready to install?
So that ball is also rolling. We'll see what he has to say!
