Quoted from timlah79:Rensh and TomDK Before our conversation in this thread about mod connectors, I purchased a "Power Tap for ATX Power Supply Games" from Pinball Life. It is in their category for TBL compatible 12V and 5V mods. However, I have no idea how I use this, do you? It doesn't have the same molex connector you speak of that comes from the TBL back box nor does it have the standard 2 pin, "matrix" connectors that most mods use, specifically the connectors that The Mod Couple mods use (I think it is 2.5mm Pitch 2-pin JST XH?). So what else do I need to create the right "Y Cable"? Can you please post links, photos to where I can purchase what I need and instructions?
See links and pictures:
The supposedly TBL compatible Y cable I purchased which has the wrong connectors for what I need, "Power Tap for ATX Power Supply Games": https://www.pinballlife.com/power-tap-for-atx-power-supply-games.html
Again, the two mods I need to hook up and their types of tiny, 2-pin matrix connectors:
5V Mod: https://themodcouplepinball.com/products/the-big-lebowski-gutterballs-abide-custom-color-changing-mod
12V Mod: https://themodcouplepinball.com/products/the-big-lebowski-the-creedence-is-found-illuminated-custom-mod
Example of what the connectors look like:
Very funny, you pay hell lot of money for "moddings" but the seller do not offer a compatible cable to connect.
With my TBL Topper from BigLebowski came a perfect y-adapter. And he is not a pro selling expensive mods to the communty.
What sould I tell you ?! Buy a crimptool and some plugs and crim what you need. Cut of the small plugs and make the mods compatible. Or solder them diectly to the wire. I would send the mods back and ask them to make them plug and play. Making hell lot of money out of nothing, selling 3D prints for helllot of money but do not support theit products ?!
Quoted from TomDK:Very funny, you pay hell lot of money for "moddings" but the seller do not offer a compatible cable to connect.
Thank you TomDK I agree with what you are saying but I cannot find the exact type of Y-cable needed with the right connectors. So my guess is no one makes one. I don't even know the names of the connectors I need, that's why I posted pictures and asked for links to buy what I need. The Y-cable I posted a photo of already splits out 5V and 12V (https://imgproxy.pinside.com/25_ZRLPRwu5hgZptMrJsLpCtSoMQYQTcpNgb8YPh9IM/rs:fit:2048:2048/q:70/aHR0cHM6Ly9vLnBpbnNpZGUuY29tL2MvNTEvOTkvYzUxOTk3YzZhOGFjOTgwNDFjZWQxNTI0ZGI0MWVlNWZhYjYyNDM3Ny5qcGc) outputs to 2 x 4-pin/4 wires/connectors that the TBL doesn't use. So how do I take that Y-cable and connect from the TBL power supply to the 5V needs of one of the small 2-pin connectors and the 12V to the other small 2-pin connector from the mods I have? (the second photo I posted https://imgproxy.pinside.com/4QEPMg1C-HHE_V7pLMlSXyerkB3qm8M5QnmepGAWWAQ/rs:fit:2048:2048/q:70/aHR0cHM6Ly9vLnBpbnNpZGUuY29tLzIvZGEvNTMvMmRhNTM4NDQ5MGMwNGMxN2QyNGI5OWMyMjdiMDU3MWZlZjY4YTliMS5qcGc) Do I simply only use the red and black wires?
I have ordered parts and I am in the process of making harnesses for sale.
It will have 3 - 12v; 3 - 5v; and 1 - 3V (for spinning bowl sign coming soon).
So that’s 7 power connectors for under the playfield. You will be able to buy hook in connectors to ModCouple mods as well.
I should have proto by next weekend and be ready to sell after that.
Quoted from cpr9999:I have ordered parts and I am in the process of making harnesses for sale.
Thats the way it should be ! Most new people to pinball are not able to solder and understand how a pinball works, so there is need for ready harnesses before this people try to solder on SMD pcb to get some power for modding.
Quoted from TomDK:Thats the way it should be ! Most new people to pinball are not able to solder and understand how a pinball works, so there is need for ready harnesses before this people try to solder on SMD pcb to get some power for modding.
Apparently some people don't understand how forums work either and just post their opinions and assumptions about people's intelligence instead of actually answering questions from the community.
Quoted from timlah79:Apparently some people don't understand how forums work either and just post their opinions and assumptions about people's intelligence instead of actually answering questions from the community.
It has nothing to do with intelligence. But a little with skills and the time I am willing to invest in the hobby.
It seems that my comments helped at leat that one of the mod sellers will make the needet harness/Y-adapter. On the older pins it is no problem to "grab" a needet power from any source in the machine, solder 2 cables and it works fine. On all the new machines you can not do so. Nodeboards from Spike and Spike2 f.eks. dont like differences in voltage. Same on TBL. You can not solder 2 wires to a smd rgb led to get some power for mods. Therefor the mod producer have to offer plug and play on this machines. It is also not DP warranty to cover failed installations of mods.
The connector for the apron f.eks. delivers all needet powers. If you are able to figure out what is on which pin, you can use it but I would never ever giving in the forums a tip how to use this plug. Specially not to people with no experience in crimping a cable.
To anser your question, this is how a Y-cable can look like. This cable came with the TBL topper from @biglebowski.
IMG_1074 (resized).JPEGIMG_1075 (resized).JPEGIMG_1076 (resized).JPEGIMG_1077 (resized).JPEGIMG_1078 (resized).JPEGIMG_1080 (resized).JPEGQuoted from TomDK:It has nothing to do with intelligence. But a little with skills and the time I am willing to invest in the hobby.
To anser your question, this is how a Y-cable can look like. This cable came with the TBL topper from BigLebowski.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Thank you very much, TomDK . This is the information I was hoping for. I am experienced in soldering and somewhat good with a multimeter but when it comes to electronics power or crimping my own cables, I am still learning. This type of information helps that learning process. Yes your earlier comments helped influence an experienced modder to start on creating a harness, which I will wait for while I learn to be more self sufficient in this area, so thank you!
BigLebowski That topper looks awesome, can it be purchased in the U.S.? I've only seen the Gutter balls one but prefer yours. Apologies if there's already an earlier post with a link to it. If you have a link to where to buy it, that would be great!
For all those looking for a power splitter.
Pinball life is carrying this in their product line:
You can contact BigLebowski for this great (and cheap ... versus Stern-Topper) topper.
He also ships to the US and has a manual in english ... and of course ... a Y-connector
Today an other TBL owner visited me and we spoke about mods for the TBL, he told me that all his mods from the USA came plug and play with connectors.
My game has only a handful of plays on it. Right flipper was working fine, now it raises and drops right back down, even if you hold the button. Went to look at the EOS switch and it is nonexistent. What's up with that? Any ideas how to correct this?
Quoted from Rensh:For all those looking for a power splitter.
Yes that's the one I bought and asked about earlier in this thread because I'm completely puzzled as how to leverage it.
Quoted from timlah79:Yes that's the one I bought and asked about earlier in this thread because I'm completely puzzled as how to leverage it.
you can't - wrong connector types
Quoted from fossmin:My game has only a handful of plays on it. Right flipper was working fine, now it raises and drops right back down, even if you hold the button. Went to look at the EOS switch and it is nonexistent. What's up with that? Any ideas how to correct this?
Box the machine back up and send it to me
There should be little circuit board there instead of typical EOS for the flipper which makes and breaks.
Are you asking where you can get one of those?
https://www.pinballlife.com/fliptronics-type-2-opto-board-replacement.html
Quoted from cpr9999:Box the machine back up and send it to me
However, this might be a coil issue .... OR....
RENS - can commit - I think there was a miss wiring that caused weak flippers.
(maybe search this thread of the fix it thread for tbl).
There is no EOS switch on TBL.
Sounds like a hold issue. Can you swap the connectors on the main pcb so left flipper is activated with right button and vice versa? If the problem remains at right flipper we know it’s something with the coil assy. Pls check wiring for something loose.
Which serialnumber do you have?
Please check my pictures, the y-adapter from the link to PinballLife has 4 pins only and it is "round". My adapter looks different !
Quoted from Rensh:There is no EOS switch on TBL.
Thanks Rensh I will try this. I think my serial number is 488.
I might be crazy, but after doing the code update on my machine the behavior of multi-ball has changed. With two characters ready, I still only get a 2 ball multi-ball, but in the past it was 3 ball multi-ball ( ball in play +1 ball for each character). Am I crazy?
Cant remember the old days ... fact is with 2 charactzers only 2 ball multiball. I can , maybe, maybe, also remeber that it was 1 ball per character.
Easy to test .. load in the menu an older software and play ...
Quoted from okgrak:I might be crazy, but after doing the code update on my machine the behavior of multi-ball has changed. With two characters ready, I still only get a 2 ball multi-ball, but in the past it was 3 ball multi-ball ( ball in play +1 ball for each character). Am I crazy?
Yup. You are crazy
As answered already per mail this morning it’s 1 ball per character with only exception being that 1 character multiball has 2 balls.
Rensh
When I flipped the coil connectors on the board, the problem switched to the left flipper. Is my coil bad?
Quoted from fossmin:Rensh
So
Left button left coil working
Right button right coil not working
Left button right coil not working
Right button left coil working
Assuming the wires are correct connected to the coil my conclusion is coil is defective.
Quoted from Rensh:So
Yes, your scenario is correct. The right flipper worked about 10 games then started doing this. Should I work this through Cointaker?
Quoted from fossmin:Yes, your scenario is correct. The right flipper worked about 10 games then started doing this. Should I work this through Cointaker?
CT being ‘local’ and knowing this is a standard BW coil I think that’s the easiest and fastest way.
Note: in case you get a standard BW coil this likely has a diode. Don’t forget to remove the diode !!
Hey folks - my pin is on order w/CT - looking forward to it.
I had a random thought / question - during gameplay - or other - is there a quote from the movie that goes "Who the F are the K-Nudesons???" Its one of the most random lines in the movies but its one of my favorites.
Thanks,
Its not a random line in the movie. The Knutson's paid Da Fino (the private eye) to find their daughter Fawn (who goes by Bunny Lebowski which is Mr Lebowskis wife). Fawn ran away from Minnesota and made porno movies, racked up big debt and somewhere along the way married Mr Lebowski.
The dude knows her as Bunny not Fawn Knutson so that's why he inquired in typical Dude eloquence. Anyway .. carry on!
Quoted from brandonx76:Hey folks - my pin is on order w/CT - looking forward to it.
Thanks,
Bunny is not the issue man....And you forgot the influence of Carl Hungus - just wondering if the quote comes up?
I'm losing my mind over the issue after issue with my NIB TBL I received less than a month ago. Can anyone who follows this owner's thread please look at this post and the related ones in the maintenance thread? I seem to be having issues that no one has ever reported before and really need some expert help. Thank you. https://pinside.com/pinball/forum/topic/a-lotta-ins-a-lotta-outs-tbl-maintenance-thread/page/12#post-6283770
This means that the switch named MENU/ÖUS RIGHT was for 30 games not in action which brings up this message.
Same will happen to the tilt blomp ....
Ignore it or use this switch 1 time ...
Its a bug that also this kind of switches are listes/checked from the system.
So dont worrie ... doenst mean anything !
Quoted from TomDK:This means that the switch named MENU/ÖUS RIGHT was for 30 games not in action which brings up this message.
The spinner switch will occasionally show up as well.
Quoted from PinheadEDM:Starry lit apron beauty, thanks Barry!
Wondering when you ordered this? I did about 3 weeks ago…still awaiting arrival dude.
Quoted from Bmanpin:Wondering when you ordered this? I did about 3 weeks ago…still awaiting arrival dude.
It’ll get there
Quoted from timlah79:TomDK Like I said, my concern is that I've proven that "the mod couple" harness and their mod which requires 12V (but doesn't work from the TBL mod connector) has no wiring issue when it comes to continuity. Both of their harness connector and "matrix" 12V mod connectors have continuity where expected, yet it doesn't power the 12V mod, only the 5v one. This is why I am concerned that the TBL stock connector is not outputting 12V and that my apron may not work.
I also cannot find a Y cable anywhere online that connects from the backbox with the right molex connector to two, 2-pin "matrix" connectors that these any almost every mod out there requires. So that's why I asked Rensh to a) update his FAQs with both a link to where a proper connector that uses a recommended TBL power source can be purchased and b) add specific instructions to how to safely test the TBL mod's connector for 12V using a multimeter. I hope this clarifies.Thanks Rensh , as I mentioned above, if there's a safe way to test with my multimeter, I would prefer to know for sure that 12V is coming from this connector before I receive the apron.
Just as a follow up on the apron, I got mine today and it works like a charm! So no 12V issue after all. That scratches one more concern off the list! Thanks you guys for all your input on this.
Hey dudes, I might be late to the party but does anybody have any ideas in regards to this? Am I buying a USB keyboard to get this to go away?
Haven’t played the game in about a month and haven’t touched anything it seems like it has a mind of its own and this is what I get when I play tonight. New shit has come to light: Rensh
73DBEABA-42B5-4905-B412-5943544E4DAA (resized).jpegQuoted from Bmanpin:Hey dudes, I might be late to the party but does anybody have any ideas in regards to this? Am I buying a USB keyboard to get this to go away?
Haven’t played the game in about a month and haven’t touched anything it seems like it has a mind of its own and this is what I get when I play tonight. New shit has come to light: Rensh [quoted image]
How to deal with this is posted in this thread.
Quoted from cpr9999:How to deal with this is posted in this thread.
I haven't run into this but could only find steps from ubuntu experts themselves: https://itsfoss.com/how-to-fix-system-program-problem-detected-ubuntu/
Is there a post in this thread that gives options besides having someone plug in a keyboard and dig into the system? Seems like there should be an in game resolution for this.
I know how to search, just wondering if anyone had a quick solution. What post number roughly?
Quoted from timlah79:I haven't run into this but could only find steps from ubuntu experts themselves: https://itsfoss.com/how-to-fix-system-program-problem-detected-ubuntu/
This would be handy! Not super familiar with Linux or entering commands I’m out of my element!
Quoted from Bmanpin:I know how to search, just wondering if anyone had a quick solution. What post number roughly?
Search for this in the thread
16A0E4DD-064C-4FD5-A4ED-5BDDEA61292A (resized).pngQuoted from Bmanpin:Hey dudes, I might be late to the party but does anybody have any ideas in regards to this? Am I buying a USB keyboard to get this to go away?
Made a FAQ on this:
https://www.dropbox.com/s/va6ipxwx7x8mt4s/System%20error%20pop-up%20FAQ.pdf?dl=0
I have gathered all my FAQ’s in 1 document 128 pages which I expect to release this weekend. So than it will be one link always containing all info-knowledge I have.
Quoted from Rensh:Made a FAQ on this:
Very helpful thank you very much for this I’ll give it a go later today.
Does anyone know if it is possible to add light up flipper buttons? Specifically if any of the brite-button versions would work?
any
Quoted from Bmanpin:Next dumb question…What USB port can I use for the keyboard?
This page was printed from https://pinside.com/pinball/forum/topic/the-big-lebowski-official-club-thread/page/43 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
