Quoted from TomDK:I play my machine on 6,5 , works fine and, yes ... fast.
Did your flipperbats ever break in in hold mode ?
Cheers
Tom
Hmm weird, my bats have no issue holding multiple balls.
Cheers
Tom
No, I have really problems ... for example the video, I also swapped the coils with other ones with no success, maybe I will bridge the "Hold Power" to prevent this:
It always happens if a ball dont make it the "Dude Ramp", i8f it comes from the top of the ramp back, the flipperbat will collapse.
Same if I catch a ball in multiball, hold it and a second ball comes to the bat ... collapse.
https://share.icloud.com/photos/0CnSghfjMT5scTkOp7cTnAYDQ
For the bug list:
Only Walter-Mode is activated, no ball lightning: WalterMode with no sound. End of Mode ... music back.
I see twice the flipper responding as I would expect (with a hit the flipper goes a little down but recovers immediate) but the third time the flipper goes not only totally down but also doesn’t come up again. Did you stop pressing the flipper button?
Quoted from TomDK:.....
For the bug list:
Known bug. I call it the no music bug. As soon as the music changes its back again.
It’s line 39 on the bug list.
Quoted from Rensh:I see twice the flipper responding as I would expect (with a hit the flipper goes a little down but recovers immediate) but the third time the flipper goes not only totally down but also doesn’t come up again. Did you stop pressing the flipper button?
No, I still presset the button. I throw the ball manual by hand to show this. It goes down and stays down .. this is the reason why balls get mostly lost on this behavior. In the moment the ball reaches the "ball out switch" it cuts down all power.
Bug-List:
Upss .. will print it out and bring to the pin
I am also missing adjustments for ExtraBall ... I play with 3 balls and an extraball at 10 Millions would be a pleasure .
Bug-List:
Extra ball is not coded yet. Can only get it as a mystery award.
OK. I see what you mean as a problem with the hold function ...
Its under investigation with DP. They thinking of a software solution to bring more strength to the hold function of the coil. If you connect the power part to the hold part it’s expected the Electronics will have no problem as The used transistors are very powerful but the coil can burn up.
1 spare motherboard left - direct replacement!
Other TBL mods here:
Quoted from Dkjimbo:Thinking about copper. That one guys machine looked great with copper ramps, legs and lockdown bar, rails. Why not take it a step further and do ALL the exposed metal in copper??
Yes, every piece of metal on my machine is copper plated. The only things that are not copper plated are on the underside of the playfield. Chris at pinball plating can help you. PM me if you have any questions...
IMG_2373 (resized).JPEGIMG_2375 (resized).JPEGIMG_2376 (resized).JPEGIMG_2382 (resized).JPEGIMG_2383 (resized).JPEGIMG_2384 (resized).JPEGIMG_2385 (resized).JPEGIMG_2386 (resized).JPEGa1 (resized).jpga2 (resized).jpga3 (resized).jpga4 (resized).jpgQuoted from cpr9999:1 spare motherboard left - direct replacement!
Other TBL mods here:Great MOD's... I am glad I got them for my TBL
Mod - For Sale
The Big Lebowski - Mods
New “I am selling a number of mods for TBL.
1. Doobie (Joint) Mod: $35
2. Decal stickers: $40
3. Left ramp clip: $15
4. Spare backup harddrive: $100
5. Spare Audio circuit boa...”27 days ago
Saukville, WI
1
cpr9999
Quoted from TomDK:No, I still presset the button. I throw the ball manual by hand to show this. It goes down and stays down .. this is the reason why balls get mostly lost on this behavior. In the moment the ball reaches the "ball out switch" it cuts down all power.
Bug-List:
Check the diodes on your flipper coils. I had the same issue with my left flipper
Quoted from Scott9:Yes, every piece of metal on my machine is copper plated. The only things that are not copper plated are on the underside of the playfield. Chris at pinball plating can help you. PM me if you have any questions... [quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Just WOW. Looks amazing well done.
Quoted from kidchrisso:The stand up's metal is shit, it bends easily. Barry is supposed to have new ones coming.
Exactly this. Someone was over today to help me out, we took out the two standups next to the left ramp, they were bent back like a mofo, bent 'em back and reinstalled, within two games they were shooting balls into the glass again, probably because they're re-bent already.
We also took off the roof of the bowling alley, adjusted the car and the two handicap standups, and within two games the car stopped registering some hits again.
Which is to say nothing of the airballs off the left ramp which will probably need a custom PETG airball protector all the way down to fix it.
Touchy, touchy game.
Those switches need to be replaced with reinforced ones like stern uses where that metal plate has a Small return leg turned backward along the entire length that adds rigidity.
Any updates on updates?
I hear the game is a blast to play, but no one can get to a wizard mode because the code is incomplete.
I'd this going to be addressed?
Dude!
Quoted from Scott9:Check the diodes on your flipper coils. I had the same issue with my left flipper
I already swapped the whole coil with one from my stock with the same results.
The flipperfinger stays down and I’ll only get up again if the ball is not lost and I repress the button.
Edit: no diodes on the coils from factory ! Should there be diodes or are they on the powerboard integrated ...
VALIS666
Yes there are several small issues you might also have on a machine from the 2 big players and, for sure, on all machines from the small firms building the games with love.
I had to work on Houdini, Bit on Alien , on the TBL and even on some games from the major players. My biggest pia game was a GoT Prem which was every second week off for needing spareparts.
So on a pin like TBL you should expect small issues .... and Service on the bigger ones. That’s why the USA games come from a big distributor .
So enjoy the game , software will follow .
AB494190-A4D7-49E3-8E45-4DAB11F015E2 (resized).jpegBFC20972-C3B3-47D7-8505-C73F03EFB05E (resized).jpegCFB620EC-FC1B-4A59-9B85-175F76F373F8 (resized).jpeg
Quoted from Robertstone0407:Anyone had issues where their bowling alley wasn’t accurately reflecting strikes etc?
I know when I hit the 7 pin it doesn't register. Anyone worked on the bowling alley yet?
Quoted from TUFLYF:Is there a place in the game to plug in the topper?
Yep, check back in this thread.
Quoted from cpr9999:Yep, check back in this thread.
Thanks. Mine came with a AC wall plug.
Me like shiny things
2F4D54C3-BA19-40D9-82F5-5E3DAF02341C (resized).jpeg4BC5FA93-8E57-4EB3-864A-F0975567A983 (resized).jpeg83D2D20E-2569-4749-8A45-701D489793DD (resized).jpegA5FD2A8D-3793-49F9-A6A8-E5C7DA14C1BE (resized).jpegA81EB949-B82C-488C-91A0-6A7351DDF1F8 (resized).jpegDAB8E924-E3B0-415E-A93A-312A6FCD2239 (resized).jpegQuoted from TUFLYF:Is there a place to buy a replacement lockdown bar?
Call Cointaker
Pinballplating.com
Before I contact Barry, has anyone here had a problem with the rug sometimes when rolling back out, it seems to come out about a few mm more than should and wont register hits as in no green or red light occurs. When you drain the ball and machine resets for next ball or next players ball, you can see the rug move back a couple mm s and it registers how it should. Why does it roll back out too far "occasionally" and has anyone else seen this and or fixed it as have no idea where to begin cheers !
Rensh perhaps you could help here since you seem to be the Barry ambassador? It seems its random but could be after resetting a specific rug mode although if no one else is seeing this then doubt it. Also once hit the scoop beside it which made it work again but perhaps that jarred it back the 2 mm or whatever that little bit is ? Cheers Rensh I may need a whole new rug mech as this being happening since day1 but would be very hard to catch in QC before it shipped
Sorry to read about your issues.
My first guess is that the rug mechanism needs some re-aligning. If the rug rolls out a little to much it’s jammed a little and doesn’t register hits as it should. Likely the height should be adjusted of the motor. In attacked picture you can see the screws which need to be loosened a little to be able to adjust.
How is it running in Testmode? Smoothly up and down?
Pls note it’s my first guess.
04B0D63F-968D-4C9F-AD7B-D9F3457DD528 (resized).jpegQuoted from Rensh:Sorry to read about your issues.
yes so Rensh i notice the rug usually returns fully out then moves a couple of mm back and is position to register hits again. some times it rolls out and does not make that slight move backwards which then makes it not work. so if rolls all the way out and does not set back a couple mm the thing wont register hits till ball drains and rug resets itself make sense?
it has also become useless registering hits about half way through the hitting the rug rug mode. so that is a little twist in me figuring out where to look
one more note, when i push on the rug by hand, when not working it is not jammed and moves back a little when pushed by ball or hand. This does not correct the issue and remains not registering
also when I go into switch tests the machine goes wonky in that it keeps clicking away like im scrolling to where i want to go however It wont let me get there by using flippers or the buttons. In all other areas besides switch tests this does not happen?
Quoted from cpr9999:Been slow in this thread lately.
Any new owners?
Got one bought and paid for. Just waiting on the word from CT.
Quoted from ToucanF16:Got one bought and paid for. Just waiting on the word from CT.
I'm in the same boat. Paid in full about 7 weeks ago and still no word about shipping.
It seems hard to believe that there are 4 of these going out every week.
backlog
Quoted from okgrak:I'm in the same boat. Paid in full about 7 weeks ago and still no word about shipping.
Quoted from luvthatapex2:backlog
That doesn't explain why they are collecting payments in full when claiming that they are taking payments only when games are ready to ship.
Quoted from okgrak:That doesn't explain why they are collecting payments in full when claiming that they are taking payments only when games are ready to ship.
I got mine about 10 weeks or so after payment in full.
It was posted but a week or so ago that he is Moving the factory and shutting down for a month or more. Could be as mentioned for the delay.
Well Dudes ... it took a while (2,283 days since sending my preorder payment to DP in July 2014 to be exact), but I'm very happy to report that I have now finally joined this club! I'm enjoying my TBL Early Achiever Edition #59 and it's everything I have hoped for since getting excited about the game when it was just a rumor.
My thanks to all the Pinsiders - particularly Rensh - that have provided positive support throughout the years of waiting, Coin Taker, those that have enabled DP to keep going by buying new games, and Barry at Dutch Pinball for hanging in there and working to fulfill his commitment to EA's! I wish continued TBL sales success to DP and acceleration of the manufacturing of EAs' games as there are still 120 or more behind me awaiting theirs.
Yeah, this is a particularly frustrating aspect. I'm still on the list as well, but to know that full payments are being taken, and then waits up to 10 WEEKS are happening....after being told that payment is only collected when games are on the way.
Well....that, and not being able to get an answer, as to place on the 'list'. And yes, I've emailed and asked, plenty of times.
But this is a thing with your distributor.
I think DHl needs also some weeks for delivery, I will not blame but in this Corona-days there is a import/export delay everywhere and specially in/out USA !
So if your distri ask for the money its not DP guilt.
Waiting tome 2-3 montah for fresh order is normal. This machines are not in stock and yes, the movement to a new hall. But I have no input if this is already going on. Mostly contracts in NL and Germany end to end of a month.
Also there are also orders from Europe ... no one knows how many. At least 2 friends ordered also after they played my TBL.
Take your time ....
The moving to a new factory is not yet in place. The final dots on the rental contract are being discussed right now. If everything goes well this should be taken care of by next week.
Production is up at the moment like approx 4 pcs every 6-7 working days.
DP only requires payment when unit is ready and just prior to shipment. Ofcourse shipping takes time and the distributor needs also some processingtime so like 3-5 weeks from payment till receiving doesn’t sound strange but 10?
Oh, I'm not blaming DP here, I don't want it to be read that way. I know once it is out of their hands, that is that.
Quoted from Rensh:The moving to a new factory is not yet in place. The final dots on the rental contract are being discussed right now. If everything goes well this should be taken care of by next week.
Mine was more like 12-14 weeks between payment to CT and getting my TBL.
This page was printed from https://pinside.com/pinball/forum/topic/the-big-lebowski-official-club-thread/page/31 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
