Quoted from Concretehardt:I didn't get this email can someone fill me in on this, also where do I go to download the updated code?
Before you start playing the game, please make sure you install the latest software version. If you don’t do this, the slingshot coils in your machine won’t function properly, so please update the software before playing.
To check your current version, please go into the service menu and down to "Software Menu > Current Version".
If you have software version 0.41, you need to do all updates as instructed below.
If you have version 0.42, you need to download and install 0.43, 0.44 and 0.45
If you have version 0.43, you need to download and install 0.44 and 0.45
And if you have version 0.44 you only need to do download and install 0.45.
After installing version 0.45 we have only one thing left to say: F*ck it Dude, let’s play pinball!
Update instructions:
Download the .zip files you need (without renaming the files and without extracting the zips - some browsers have a setting to do this automatically, so disable that if needed).
Download Update 0.42 (19 MB)
Download Update 0.43 (389 MB)
Download Update 0.44 (64 MB)
Download Update 0.45 (40 MB)
Copy these .zip files to the root of a USB stick (meaning not in a subfolder).
Start your pinball machine and insert the USB stick in the right front USB port of the computer in the backbox
Now we will install the updates one by one. The nature of the updates dictates that they need to be installed in order.
Installing version 0.42:
- Enter the Service Menu and go down to "Software Menu" -> "USB Update".
- Now you should see update 0.42 (and the others) listed. If not, retry after reseating the usb stick.
- Select 0.42.
- Wait for "copying" and "installing" to finish. The menu will then jump to where you can "Select" the new version.
- Select the new version and confirm the NO / YES question by pressing the "right" (Volume +) button.
- The game will restart using version 0.42.
Installing version 0.43:
- Now you should see update 0.43 listed. If not, retry after reseating the usb stick.
- Select 0.43.
- Wait for "Preparing delta update", "Copying" and "Installing" to finish. The menu will then jump to where you can "Select" the new version.
- The game will restart using version 0.43.
Installing version 0.44:
- Now you should see update 0.44 listed. If not, retry after reseating the usb stick.
- Select 0.44.
- The game will restart using version 0.44.
Installing version 0.45:
- Now you should see update 0.45 listed. If not, retry after reseating the usb stick.
- Select 0.45.
- The game will restart using version 0.45.
Make sure to enter Service Menu and then "Adjustment Menu > Coil Strengths > Slingshot Left & Right" and change both values to 25ms. If you don't do this the slingshots will be very weak.
Code Links:
.42
http://dutchpinball.us3.list-manage.com/track/click?u=9eee7a6360316059f8bee9561&id=715bac9af7&e=fa09a9b14a
.43
http://dutchpinball.us3.list-manage2.com/track/click?u=9eee7a6360316059f8bee9561&id=567d814c4b&e=fa09a9b14a
.44
http://dutchpinball.us3.list-manage.com/track/click?u=9eee7a6360316059f8bee9561&id=cb43729332&e=fa09a9b14a
.45
http://dutchpinball.us3.list-manage1.com/track/click?u=9eee7a6360316059f8bee9561&id=36a27ab316&e=fa09a9b14a
